04-09-2014, 05:20 PM | #1 |
Rep 40
Tune 320i with 328i oppgrade..?
Just curious....
I understand 320i and 328i is the same engine....at least almost same. What happend If I buy tuningkit for 328i and use this in a 320i? For example with product from BMS. |
04-09-2014, 06:02 PM | #2 |
Rep 346
I expect it either wouldn't work, or you'd do something bad to your engine. It's a myth that the 328i and 320i have almost the same engine. They are different. They have different compression ratios so they'll have to have different fuelling and charge parameters.
Following responses indicate I am wrong. I assumed that the BMS module ran a different level of modification for each engine and you had to get a separate 320i module. Yes, I'm admitting I was wrong on the internet. Buy gold and prep the fall out shelter. Last edited by ilovewagons; 04-09-2014 at 10:28 PM.. |
04-09-2014, 06:47 PM | #3 | |
Rep 3,566
I have Stage 1 in my 328i and it's terrific. Go for it!
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
