09-16-2013, 11:43 AM | #4643 |
Rep 40,789
Yes, this is quite simple. When a new Map is released, you buy the Media only version from dealership or Tischer BWM (www.getbmwparts.com) for about $40, or download it for free online after it is posted, then buy FSC Code from FSC Code seller for about $50 for CIC or $150 for NBT, then udpate your maps via the cars USB Port.
Or, do it the BMW way, and go to your Dealer and pay anywhere between $300 and $500 to have them update it.
09-16-2013, 11:47 AM | #4644 | |
Rep 387
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive WE ARE! |
09-16-2013, 12:06 PM | #4645 |
Rep 40,789
Yes. The FSC Code is Car VIN, Map Year, Map Region, and Map Type (CIC, NBT, etc.) specific. Change any of those variables, and you need a new FSC Code.
09-16-2013, 12:27 PM | #4646 |
Rep 387
That's a shame.. any idea where to get one for cheap?
09-16-2013, 12:34 PM | #4647 |
Rep 40,789
Yes. Send me a PM if you need one.
But, you have a 2013 F30, so I assume you also have 2013 North American Premium Maps now, and will not need to update until 2014 Maps are released.
09-16-2013, 12:38 PM | #4648 |
Rep 387
As far as I know I have the latest version right now, but there is a road that has been in existence for 2 years that's not yet in the maps... which is just mind boggling. But in the future when they release the maps I will definitely contact you.. thanks.
09-16-2013, 01:49 PM | #4650 |
Rep 304
09-16-2013, 02:07 PM | #4651 | |
Rep 40,789
09-16-2013, 02:41 PM | #4653 |
Rep 40,789
PM sent.
09-16-2013, 07:05 PM | #4654 | |
Rep 376
09-17-2013, 06:12 AM | #4655 |
Rep 5
Hello Mr.shawnsheridan.
I had my F30 repaired today. I check when I-LEVEL had been upgraded to F020-13-07-506. Can you tell us about the versions of psdzdata fit in this? I have a est token paid already. Thank you. ita323i@gmail.com |
09-17-2013, 06:51 AM | #4656 |
Rep 387
The part I'm confused about is what functionality do you lose on a US car by activating this? I have seen posts that you have choose this or BMW Assist.. which seems like a no brainer, until you crash into something and need BMW Assist.
09-17-2013, 07:56 AM | #4657 | |
Rep 40,789
09-19-2013, 05:58 AM | #4658 | |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
I have read the manual Programming ECU with E-SYS 3.8, but it was written so complicated. PS. I understand the risk of "bricking" ECU when it is flashing but I still want to learn the ECU flashing procedure. PPS. Where can I download PDX templates? |
09-19-2013, 06:08 AM | #4659 | |
Rep 40,789
Here are the basic steps, using Kombi as an example: Go to Comfort Mode => TAL-Calculating - Read and Save FA - Activate FA - Read and Save SVT Actual as SVT_ist - Create an SVT Target Under KIS/SVT Target Calculation Strategy, select Complete Flash Select I-Step (shipm.) to match your original I-Level as read and shown in VCM I-Step (Shipment) I-Step (target.) will be unselectable as it is fixed based on current PSdZData I-Level Do a KIS/SVT Target Calculation and Save as SVT_soll - Do a TAL Calculation and Save as SVT_tal Go to Expert Mode => TAL-Processing Load TAL (SVT_tal) Load SVT Target (SVT_soll) Select "Read FA" button. Check radio button for "read VIN out of FA" On ECU Tab, uncheck let top box in column "All" (All checked boxes should toggle to unchecked) On ID Base Row for Kombi, make check boxes in blFlash, swDeploy, cdDeploy, and ibaDeploy columns. Press Check software availability Press Start and it will proceed with processing TAL to flash Kombi with new firmware.
09-19-2013, 06:23 AM | #4660 |
Rep 122
09-19-2013, 06:57 AM | #4661 | |
Rep 387
Yes, the whole system turns off, including the window rolling down.. I just coded this and tested it yesterday. It's a deal breaker for me, I would rather have the windows work all the time and remember to turn the radio off.
09-19-2013, 07:37 AM | #4662 |
Rep 40,789
When you flash, it will be to the I-Level based on the PSdZData version you are using. You can flash only one, and leave the others at their I-Level.
09-19-2013, 08:50 AM | #4663 | |
Rep 122
09-19-2013, 01:03 PM | #4664 |
Rep 40,789
That is how it is supposed to work, but I have not personally tried using a different VIN. I think I would leave it as "read VIN out of FA", and just edit FA for the donors VIN.
