01-08-2018, 03:01 PM | #1 |
Rep 2,654
PUMA case opened on my 335
So I've been having some weird issues with my transmission for a few weeks. When in Sport or Sport + mode coasting on highway in a higher gear (6th 7th), stepping on the gas to overtake results in a "clunk" while downshifting. There's hesitation, a clunk, then the transmission recovers.
I've taken the car to the dealer twice now for this and the third time (now) I get the following message from the SA: "We have performed an oil balancing test to check the fluid in the trans and filed an PUMA case for this issue. PUMA takes a few days to get a result to expect the keep the loaner for a few days. Just so you know, PUMA are the BMW engineers essentially taking over the repairs. Hang tight, they are looking into it." Not sure what hat to think here. I've never had a PUMA case opened on my behalf and don't know what to expect. Anyone here have a similar experience with PUMA?
01-08-2018, 03:09 PM | #2 |
Rep 1,615
I want to bust on that name sooooo badly but it's you so I will hold back sir
Never heard of them myself....sub'd. Best of luck with this and hopefully it results in a new transmission!
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life? |
01-08-2018, 03:19 PM | #3 | |
Rep 2,654
I've had nothing but bad luck with this car so far. 4 months and I've had the following: Catalytic converter swapped, injector swapped, horn swapped, door actuator swapped, blower motor swapped and now the trans.
01-08-2018, 03:26 PM | #4 |
Rep 2,654
So I complained a bit to the SA (who's great by the way). Just a little frustrated with all the issues and suggested that they should just authorize a swap and got this back:
"I would just like to review PUMA's thoughts before I push for a new trans for you. Let me get back to you tomorrow on that." The dealer has been great so far, absolutely zero complaints. I just feel that BMW should be a bit more stringent when CPO'ing cars. I feel like at least the transmission issue could have been spotted before selling the car.
jeffc83725.00 |
01-08-2018, 03:34 PM | #5 |
Rep 1,502
Sorry to hear you're having so many issues with a CPO - that really sucks. Too bad there's no lemon laws / buyback for CPO. My own 2014 335i has been pretty solid since I bought it new, so you just drew a short straw unfortunately.
PUMA is the standard "kick it upstairs" procedure, when the dealer calls in BMW corporate for technical help. I don't believe BMW repairs transmissions as such; if the engineer determines the cause is internal to the tranny, he has the authority to order a swap for a new/rebuilt tranny. OTOH, I've seen posts where the PUMA engineer decided there was no issue and that was the end of the matter as far as BMW is concerned (i.e. you're screwed, no further appeal). That shouldn't be the case here since you have an easily reproducible issue. |
01-08-2018, 03:36 PM | #6 | |
Rep 3,947
My GF's X3 35i has a rough 3 to 2 and 2 to 1 downshift and her car has approximately 40,000 miles on the ZF 8HP45. |
01-08-2018, 03:52 PM | #7 |
Rep 190,805
Sorry about that and good luck
01-08-2018, 03:57 PM | #8 | |
Rep 2,654
01-08-2018, 05:11 PM | #9 | ||
Rep 1,615
And I don't blame you one bit for being frustrated as this is one major reason why I switched to BMW!
01-08-2018, 06:58 PM | #10 |
Rep 10,473
At least New York has a Lemon Law for used cars. Most States do not.
Unfortunately for you, it’s 2 years from original delivery date (well passed for a 2014) or under 18,000 miles (I suspect your Odometer is over this as well), whichever happens first |
ceedawg467.50 |
01-09-2018, 12:05 PM | #11 |
Rep 2,654
Sounds like I'll be at the mercy of the dealer to do the right thing here
01-09-2018, 04:25 PM | #12 |
Rep 524
I had a puma case on my e90. check engine light throwing the same code 3 times over 3 months, 3 different repairs that didn't work, puma case opened, bmw instructed dealer that cylinder head probably had a crack, dealer took apart engine to find.... crack in the cylinder head. cylinder head replaced, check engine light never came back
good luck OP, puma case worked for me |
01-09-2018, 05:19 PM | #13 | |
Rep 2,654
01-10-2018, 05:20 PM | #14 |
Rep 2,654
Dealer got back to me today. They swapped out my paddle shifters and control unit and reset adaptations on the transmission software. They asked me to drive the car for 150 miles at least and report back to them.
Anyone ever get their adaptations reset?
01-11-2018, 08:33 AM | #15 |
Rep 4,724
I did on my E92 335. I felt like it was not shifting properly, and it worked. This was on the old 6 speed ZF.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
01-11-2018, 05:22 PM | #16 |
Rep 1,342
Had my transmission swapped in the 1st year of ownership due to laggy shifting...noticeable delay between lower gears. The whole saga, including having to threaten BMWNA with lemon law, is documented in another thread.
They also reset the transmission adaptations. I actually learned how to do it myself with a program called BMWAI (also in another thread). But, alas, this did not help in my case. Took them awhile...6 visits later I had a new transmission. Sorry to hear of your troubles. My '14 has been pretty solid since. |
01-14-2018, 09:04 PM | #17 |
Rep 605
I had my transmission fully replaced under warranty, leak towards the tailshaft. They were in contact with BMW and they recommended to swap out the transmission for a new one due to the leak being in the tailshaft. I don't know if it was a Puma case or not but they followed BMW's recommendation for a full replacement and they had the car for about a week and a half testing and inspecting things. When they found out it took a liter to fill fluid back up they kept the car a while to check things out. I was getting hard downshifts coming to a stop on cold starts sometimes with a light clunk, and delay on changing gears occasionally before I took it in.
01-14-2018, 09:27 PM | #18 |
Rep 10,352
Getting a new transmission is a process so just try to be patient and remember that it is BMWNA who pays the dealer for warranty work.
Dealers don't do a whole lot on CPO cars. It's basically an OE extended warranty for low mileage lease turn-in's. Unless they've changed, when BMW does a transmission replacement it's going to be a remanufactured unit but rest assured that the internals are brand new. It's the housing that is not new. On a side note I would ask the SA to see if they'll tell you whether or not the car was flagged for having a tune by the initial owner.
"Drive more, worry less. "
01-15-2018, 06:04 AM | #19 | |
Rep 2,654
01-25-2018, 01:40 PM | #20 |
Rep 2,654
Dealer had my car for a few days and reset transmission adaptations to see if this would resolve the issues I have been experiencing. Asked me to drive the car for about 150 miles, which I have, but the issues still persist. Resetting adaptations actually seems to have made it worse. I emailed them today and am waiting on a reply:
Hey XXXXXX – How are you man? I hate to keep bothering you with these issues but I really have to get this resolved. I’ve driven the car a few hundred miles like you guys asked but there’s definitely something wrong. The car continues to lurch while switching gears and never really seems to know where it wants to be. Accelerating in Sport mode it continues to bang into gear. Resetting adaptations on the transmission seems to have actually made it worse. It’s come to the point where I wont drive my kids around in in because I don’t feel comfortable. I’m honestly at a loss and don’t know what to do. XXXX the foreman felt it as well, maybe he can chime in? He seemed very knowledgeable on the platform. Please let me know what next steps are. Maybe get BMWNA involved to fast rack some sort of resolution? Based on the amount of things that have already gone wrong with this car maybe they’ll be inclined to step up to the plate. I look forward to hearing back. |
01-25-2018, 01:52 PM | #21 |
Rep 2,654
01-25-2018, 04:22 PM | #22 | |
World's Foremost Authority
1181
Rep 4,535
Drives: M4 Cab - Cayenne GTS - Jag XK
Location: Upper East Side Manhattan - Boca Raton FL - Lime Rock CT
Drivers Club at Lime Rock - International Motorsports Research Center - Society of Automotive Historians - Madison Avenue Sports Car Driving and Chowder Society (0nly a VP) - BMWCCA - Porsche Club of America - M Gruppe - Polish Race Drivers of America (PDRA) - Glen Club (Watkins Glen International) - Jaguar Club of Southern New England |
jeffc83725.00 |
