07-08-2015, 01:56 PM | #1 |
Rep 740
Chassis – Drive Moderately
I did some research on a little issue I experienced. But could not find anything definitive.
Anyone else experience the below? I was driving, and a warning sprang up on the IDrive screen: Chassis – Drive Moderately. I have DHP on my 435. From initial research I learned that this could be a fault with DHP. It went away when I turned the car off and back on. Week later it happened again. In total I’d say perhaps on 5 different occasions did the warning illuminate. I would assume if anything was wrong, the issue would constant, and not go away and come back. Also from little research, some folks stated that after taking their vehicle into the dealership, no code could be found or problem replicated. Did anyone else experience this issue with their chassis? Any outcome? Thanks! |
07-29-2015, 10:08 AM | #2 |
Rep 364
I'm experiencing the exact same thing.
Bringing it in next week. Will let you know what they say.
ED Pickup 9/14:
2014 335msport, MG, Black Leather, Tech, DHP, MSport Brakes, 6mt, Borla S Type 2023 G87 BG, 6MT, Bi Color, Red Calipers |
07-29-2015, 11:09 AM | #3 |
Rep 190,777
I recommend you take your car to the dealership so they can check it out.
07-31-2015, 09:01 AM | #4 | |
Rep 740
I gotta be honest, I am actually afraid of taking this car long trips or just having around bc i never know what will happen or what will breakdown. This car shut down on me, over-heated, 9 tires changed, noises coming from the vent and rattling from engine bay, creaking and cracking, weird steering wheel vibration and noises, and all in the past year and half. F this. Really tired of it. I've known all this, and what to expect from BMW. However, now that I am more reliant on using the car for more than the weekend warrior, i must say, im uneasy having this bimmer at my disposal for everyday use. |
07-31-2015, 10:32 AM | #5 | |
Rep 190,777
08-02-2015, 12:30 AM | #6 |
Rep 24
I have had the same issue on my 2015 M235i with less than 600 miles on it. See http://www.2addicts.com/forums/showthread.php?t=1157093
08-02-2015, 07:09 AM | #7 | ||
National Championship #17 and Counting!
793
Rep 1,508
I say take it in just to document. See what our state's lemon laws are and try to get BMW to buy the car back from you. Worth a shot. The creaking sounds seem normal unfortunately. My BMWs have all been a little noisy in the suspension area.
2018 i3s - Melbourne Red, Tera World, Ceramic Film all windows
Packs: Technology, Driver Assistance, HK Audio, Park Distance Control |
08-03-2015, 07:44 AM | #8 | |
Rep 6,990
08-03-2015, 08:59 AM | #9 | |
Rep 6,299
Mine had that issue about 3 months into ownership, replaced that under warranty and all was well. |
08-03-2015, 02:23 PM | #10 |
Rep 740
dude let me ask you, for your faulty sensor, did they say what this faulty sensor could cause? (not What caused it, rather what its not doing as its supposed to)...thanks
08-03-2015, 02:24 PM | #11 | |
Rep 6,299
I can try to take a look at the work order when I get home to see if that has any extra info. I'll keep you posted. |
08-03-2015, 06:24 PM | #12 |
Rep 693
It affects the stability system IIRC, might link in to some other stuff as well, probably shares info with the ABS. Which is weird, cause ABS doesn't work on ice which is where you would think an acceleration sensor would shine.
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded) 2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O 2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O 1983 Porsche 944 All stock |
08-04-2015, 09:29 AM | #13 |
Rep 740
as in traction control function of this BMW?
08-04-2015, 12:23 PM | #14 |
Rep 693
Traction control SHOULD be handled directly by the ABS wheel sensor. Stability control is different and is designed to keep body roll and over steer in check.
I am not intimately familiar with exactly how BMW programs their systems but an acceleration sensor senses inertia which is a prime requirement for stability (and Airbag systems but they have their own dedicated sensors).
2015 328d X-Drive Touring M-Sport (Traded) 2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O 2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O 1983 Porsche 944 All stock Last edited by Thumper333; 08-04-2015 at 03:49 PM.. |
08-04-2015, 02:58 PM | #15 | |
Rep 740
08-04-2015, 07:09 PM | #16 |
Rep 70
I had the same error, was told by dealer it's the vertical acceleration sensor related to DHP and it wasn't an safety issue. I guess it probably just affects how DHP adjusts the dampers?
12-12-2020, 08:53 AM | #18 |
Rep 16,079
It means you need to use an OBD diagnostic tool to pull the fault codes and see what's going on. Since the ABS light is on chances are it's an ABS sensor.
12-12-2020, 09:34 AM | #19 |
Rep 906
I had the same symptom on my old DHP F30.
Here's the laundry list of things done to the car to finally fix it:
Car was out of service for two months across three different visits while they were trying to figure it out. Dealer had to get help from BMW too (PUMA case).
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
