08-18-2014, 09:22 AM | #1 |
Rep 10
2 questions about internal power...
Hi everyone,
I have two questions about internal power in my 2013 BMW 335ix, and I'm really hoping someone can help me with it -- the digital manual isn't much of a help I'm afraid. 1. If you're parked with the engine off - how do you turn on just the electronics (IE: radio) without turning on the entire engine and off again? (Basically accessory only power) 2. I was recently given a plug-in cooler for an upcoming road trip. I know BMW generally shuts off power to all its outlets, but is there one in the car that at least runs longer than when I shut off the car? (Glove box, centre console, front dash, and rear) Many thanks! |
08-18-2014, 09:36 AM | #2 |
Rep 34
1. You just press the volume knob on the radio - works in my 428i.
2. My understanding is they all get turned off after 5-10 minutes. I think I'll get a permanently powered outlet installed in the boot (er sorry, I mean trunk in US speak) for my fridge. The only problem I envisage is this will bypass the battery conservation electronics and I'll have to be careful not to forget and leave it on too long. |
08-18-2014, 11:52 AM | #4 |
Rep 70
In my case, it turns all of the warning lights on and says ignition is on. It also tells me to depress the brake to start the car. So your suggestion is not 100% correct.
08-18-2014, 12:07 PM | #5 |
Rep 1,051
? That is how it works. What exaclty are you expecting?
2023 X5MC | Donington Grey | Black
08-18-2014, 01:30 PM | #6 |
Rep 312
Agree with another poster - what are you expecting it to do? You car will either supply power with the engine running, supply power without the engine running, or supply no power at all.
08-18-2014, 01:36 PM | #7 |
Rep 205
Drives: 2014 335xi MSport
I think hes expecting the power to be available without all the lights and warnings, just like it is when you press once to just turn off the engine after its been running.
I never tried pressing the radio button with the car off though. Would be cool if that works too.
2014 335i xdrive MSport AW/CR, SAT, Prem, Tech, HK, DHP, MPPK, MPE, NWA, KMFDM, etc... |
08-18-2014, 02:20 PM | #8 |
Rep 70
Accessory mode which doesn't require the ignition to be on.
Current: 2016 F82 ///M4, Austin Yellow
Previous: 2017 ///M240i, Mineral Grey, Coral Red leather, 2014 328i Sport line, Glacier Silver, Black leather |
08-18-2014, 02:32 PM | #9 |
Rep 1,051
I'll test mine today. I believe the radio does work by just pushing the power button.
08-18-2014, 02:42 PM | #10 |
Rep 10
Heh -- thanks for the replies, a few were a bit funny. Yeah, essentially, I'm expecting some kind of mode that BMW does much like GM's and others called Retained Accessory Power. If it doesn't exist, I'd be pretty surprised. All things considered, just pressing the start button without brake just starts everything up except for the engine itself along with all the warning lights.
Too bad about the outlets. Oh well. |
08-18-2014, 03:12 PM | #11 |
Rep 1,232
I don't understand this post, if the outlets stayed on for more than 10-15min after the car is off and you have something plugged in then it will end up draining your car battery anyways... That's why they eventually shut off
08-19-2014, 02:00 PM | #12 |
msej449
514
Rep 717
Drives: M235i Convertible +LSD 2016
On my F31 there's a power outlet just above the front passenger's knees. Only found out about it on another forum. You need to virtually lie on the floor to see it. I think it runs for 10 minutes like the one on the rear console and F31 rear load area outlets. I also have an old car refrigerator that I connect to one of the latter two. It stays on when the engine goes off, but only for ten minutes, as has been said (but you'd not want it draining for any longer anyway). I keep a BMW rechargeable mini-torch in the footwell socket for emergencies.
2016 M235i Convertible Estoril Blue & Oyster
2023 Peugeot e-208 GT (electric) |
