BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Sport + vs traction off
      11-29-2012, 08:34 AM   #1
4DRS55
Drives: GTF80,718GT4,TVG80,G05X5
Do not know why BMW has it set up this way, when u have the traction completely off the car shows sport oriented suspension but throttle response is softened (seems like throttle in comfort mode) unlike the sport or sport +, why?
      11-29-2012, 08:37 AM   #2
jtuds
Drives: 335rwd Dinan S2
I don't think it is supposed to be that way....maybe it's just your perception.
      11-29-2012, 10:05 AM   #3
Bertus
Drives: 2007 330i Steptronic
A good reason for that is that it will make breaking traction harder - ie. a deliberate push of the throttle so you don't get caught off guard.
      11-29-2012, 10:06 AM   #4
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Yea.. stupid setting
M Sport Line Estoril Blue
      11-29-2012, 10:10 AM   #5
Vitoco
Infidel
Vitoco's Avatar
122
So, were u in Sport or Sport + prior to turning DSC off? Or were you in Comfort, then turning it off? Cause I donīt think turning DSC off changes whatever throttle-mode youīre in so unless you actually were in Sport, the throttle response shouldnīt get sportier. I donīt know this for a fact but it seems logical to me..
      11-29-2012, 10:26 AM   #6
pohlease
Drives: 2012 F30 Sport
The original poster is correct I've experienced the same thing. Turning off traction control seems to take the car out of sport mode. What I found works is to push the shifter into manual shifting. If you don't shift yourself the car will shift as if it is in the sport setting.
      11-29-2012, 10:56 AM   #7
ilhan1103
ilhan1103's Avatar
Drives: f30 318 2012
2012 318D  [0.00]
Can confirm here. Turning off traction control completely puts you back in comfort mode.
      11-29-2012, 11:41 AM   #8
xDrive35i
xDrive35i's Avatar
Drives: Porsche Macan S
DSC remains on when DTC is activated either by enabling SPORT+ or by pressing the DSC button once. SPORT+ automatically enables DTC so you can get tail happy, but DTC's other function is to provide a greater slip threshold on looser surfaces where momentum is key. If DSC remained on in full force, the car would instinctively cut power and apply the brakes when slippage is needed. This loose threshold, combined with default COMFORT mode (the car calls this TRACTION mode), provides for more dramatic weight transfer/squat (think: putting sandbags over the powered axles) and allows you to make more deliberate throttle inputs to get yourself out of a ditch, snow bank, or up wet/slippery inclines. (Note: if you do not have the adaptive suspension, COMFORT only applies to throttle response). DSC OFF, which requires that you hold the DSC button for a number of seconds, puts everything in SPORT and leaves managing the car's dynamics up to you.
This is why SPORT+ is simply SPORT with DTC enabled. If you press the button for DTC in SPORT or COMFORT, the car will go into TRACTION mode. But SPORT+ is the only way to turn DTC on without enabling TRACTION mode. So you can think of SPORT+ as power slide mode.
      11-29-2012, 12:05 PM   #9
4DRS55
Sport plus and tried it in sport same thing happens car says sport oriented suspension but throttle softens a bit.
      11-29-2012, 12:24 PM   #10
Vitoco
Infidel
Vitoco's Avatar
122
Hmm, maybe it's because the throttle response in Sport is too aggressive to run in DSC off-mode.. certainly interestin.
      11-29-2012, 12:27 PM   #11
Vitoco
Infidel
Vitoco's Avatar
122
I see a bunch of words and none of them an answer to anything that has been asked by the OP. DTC wasnt mentioned even once and ur explaining how it works. Am I missing your point or how is this related to Sport-Mode-pedal-response-goes-to-comfort-when-DSC-is-OFF?
      11-29-2012, 01:01 PM   #12
yellowllewellyn
Drives: 2014 335i xDrive
http://www.f30post.com/forums/showthread.php?t=773809
      11-29-2012, 01:24 PM   #13
Sprocket
Drives: BMW F31 328i
I thought the last section of the post you quoted explained it pretty well, or am I missing something..?
Melbourne Red F31 328 M sport
      11-29-2012, 04:36 PM   #14
pkimM3r
pkimM3r's Avatar
205
Holding down traction control button for a few seconds - that equals TRUE power slide mode.
Sport+ just turns dynamic traction on - a little more slip but you're not gonna be sliding all over the place.
As far as feeling like its back in comfort mode when turning traction off completely, its just the throttle. And when you are sliding like that, you want to be able to feather the gas a lot more than basically having an on/off switch of a gas pedal. Maybe its just safety.
      11-29-2012, 04:40 PM   #15
MaestroAl
Drives: 335xD
Sport+ doesn't just do DTC folks - it also sets the gearbox to manual
ZMS | ZNP | ZVI | 2VF | 2VL | 3AG | 494 | 6NS | 8TH
      11-29-2012, 04:55 PM   #16
pkimM3r
pkimM3r's Avatar
205
not YOU again lol. we post around the same time but half way across the globe from each other, what time is it there?
so it actually just bounces against the rev limiter? awesome
      11-29-2012, 05:02 PM   #17
MaestroAl
Drives: 335xD
Yes it's the only way you can get it not to change gear in the auto
And it's 23:00 over here
Oh, and my car finally arrived today. You have my express permission to fawn over it ( http://www.f30post.com/forums/showthread.php?t=775958 )
      11-29-2012, 05:05 PM   #18
Vitoco
Infidel
Vitoco's Avatar
122
Did it? It says nothing bout the throttle response so I rest my case
But I think it's been answered a few times already and basically the throttle response in Comfort is the true response and Sport is more or less an ON/OFF setting. When DSC is off, for your own safety, the throttle responds realistically. And I would assume that if in Sport, you still get the shift points and quicker shifts. Who's with me?
      11-29-2012, 05:42 PM   #19
xDrive35i
xDrive35i's Avatar
Be mindful not to refer to DSC OFF as Trac Off, because DSC is stability control.
      11-29-2012, 05:56 PM   #20
Vitoco
Infidel
Vitoco's Avatar
122
I wrote "DTC off" but of course I meant DSC, editing....
      11-29-2012, 05:58 PM   #21
4DRS55
Also when your traction and DSC is all off your e-diff (not a true lsd of course) is in the works. I believe it states that in the owners manual. It would be nice to have the peddle response as it would be in the sport+ mode for some foreplay
      11-30-2012, 01:52 AM   #22
Sprocket
Sounds logical to me, although the "traction mode" theory also seems plausible as the manual specifically refers to manually turning off DSC when trying to get moving in snowy conditions etc. Either way, a linear and realistic throttle response is wanted both when you're in mood for power slides or trying to get moving on ice.
BTW, has anyone had any sideways fun in their 328 yet? Is it powerful enough to do it? Merely curious...
