BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Yellow Factory Halogen to White Halogens
      06-18-2015, 10:22 PM   #45
slugmaster
This thread was very helpful for me and I wanted to share what I went with.
For the low beams, I used philips crystal white. It is a new bulb rated at 4300 K and supposedly 60% brighter. This is higher than the current Osram and philips CV ultra. I got it on powerbulbs website. They are brighter and whiter than stock.
On the DRL I got the following on amazon. They are LED, no flickering that I can see or errors. Not as bright as you might think, but they are only on during the day so I am not sure. The light is white.
http://www.amazon.com/gp/product/B00...ilpage_o01_s00
There is another model by same seller that is $5 more and probably brighter.
On installing low beams, here is my two cents. I jacked the car up but did not take of the wheels. This added enough clearance for me as the wheels stayed on the ground. I bent the brackets to take the bulbs out. Don't worry about the bulb being loose when putting in the new ones. Mine were, and I simple took the bulbs out and bent more. Repeat until it is tight enough to your liking. Also, the bulbs are keyed at the base. I did not know this and could not figure out why they would not go back in initially. As I recall, the flat part of the base goes up.
      06-18-2015, 10:24 PM   #46
slugmaster
I ordered the PA parking light also from the ebay seller in Taiwan. Should arrive in a couple of days. I'll post how it works out.
      06-20-2015, 11:32 PM   #47
ATL0501
ATL0501's Avatar
Drives: '21 540 Msport
So just received the Philips Diamond Vision (DV). They look amazing and perfect white with hint of blue. Visibility in rain compared to Crystal Vision (CV) (on passenger side) feels very similar if not the same. Also this is with the PA parking light LEDs (which have error but go away after a minute or two). The CV seemed much whiter than stock but compared to DV they are insanely yellow lol! Overall very happy with outcome
Besides the cutoff lines, the color temp looks close to the xenons on the F10 sitting in the garage surprisingly.
Bernina Grey Amber Effect 21 540 Msport
Carbon Black/Cognac 21 X3 x30i M sport
Black Sapphire 14 328Xi M sport
      06-28-2015, 05:43 PM   #48
slugmaster
Just wanted to post an update. The PA bulb for the parking light throws error for me. If you use auto start/stop you will get more errors after startup.
I ended up buying this, which has a separate error canceller. It gets hot, and in retrospect I would just get the car coded.
http://www.amazon.com/iJDMTOY-CAN-bu...6w+bmw+f30+led
Or if you want to stick to a whiter halogen, you can do philips blue vision.
http://www.powerbulbs.com/us/product...idelight-bulbs
Hope this helps!
      06-29-2015, 12:47 AM   #49
whoisthis
Drives: bmw
it was impossible for me to bend it back..you guys must have a strong grip lol
Did you guys use any tools to install/uninstall low beam?
Do I remove the harness first, then bend the bottom two clips because i don't think you can really get to bottom 2 clips with the harness on.
F30 328i sedan
      06-29-2015, 10:49 PM   #50
slugmaster
I did not use any tools. Bending the clips to take out the bulbs is the easy part. You only need to bend it like 1 mm or less and it loosens up. I removed the harness first.
It is harder to bend the clips back in place when putting the new bulbs in.
      06-29-2015, 11:13 PM   #51
whoisthis
Drives: bmw
It was SO MUCH easier with the wheels out. But i gotta do the installation again because EIKO bulb i bought is tooooo yellow.
Philips DV is coming tomorrow.
F30 328i sedan
      06-30-2015, 06:27 AM   #52
ATL0501
ATL0501's Avatar
I had no problems the second time. First time was cautious bending clips back and I left the wheel on just turned all the way. Just remember the way you take out the bulbs so you put them in same way.
And great choice with DV. Also get the parking light so it works perfectly
      07-02-2015, 03:41 AM   #53
whoisthis
Drives: bmw
DV is perfect. Exactly what i wanted.
I already have the parking light LED from IJDMTOY. It sucks.. They say it's xenon white but it's more like purple, close to 10000k - 12000k
I guess this Purple is their definition of HINT of blue.
F30 328i sedan
      07-02-2015, 04:53 AM   #54
ATL0501
ATL0501's Avatar
http://s785.photobucket.com/user/bombguard1/media/20150701_151633_zpscb6p6kcb.jpg.html][IMG]http://i785.photobucket.com/albums/y...pscb6p6kcb.jpg[/IMG][/URL]
http://s785.photobucket.com/user/bombguard1/media/20150701_151629_zpsnqx6tlkc.jpg.html][IMG]http://i785.photobucket.com/albums/y...psnqx6tlkc.jpg[/IMG][/URL]
I got the LED as mentioned above but they do throw error code. They look much better than the ijdm. White with slightly blue. Makes lights look great. That's the other reason I never got the DRL since they too purple which I just don't like
      07-02-2015, 01:52 PM   #55
whoisthis
Drives: bmw
Actually DRL i bought from IJDMTOY looks White. But the parking light H6W i got from IJDMTOY is Purple even though its suppose to be white.
And It throws code. Such a crap..
F30 328i sedan
      07-02-2015, 03:40 PM   #56
ATL0501
ATL0501's Avatar
Oh nice I guess ijdm finally developed a purer bulb not that 6500k they offered. Does that DRL flash on startup or periodically while driving?
      07-03-2015, 01:54 AM   #57
whoisthis
Drives: bmw
i don't know about DRL but parking LED flashes randomly while driving.
Just..don't get H6W LED from IJDM
F30 328i sedan
      07-03-2015, 03:40 AM   #58
ATL0501
ATL0501's Avatar
Yeah I already have parking light from PA it's perfect and sometimes flashes during startup but hardly noticeable since it's a 3W. Now I need a White DRL with resistor. Can't have it flash while driving. During startup it's fine to flash
      07-03-2015, 02:11 PM   #59
whoisthis
Drives: bmw
Do you have a link to where you bought the parking light?
F30 328i sedan
      07-03-2015, 03:41 PM   #60
ATL0501
ATL0501's Avatar
Yessir. I posted it on previous page but they do give error but I live with it lol
      07-03-2015, 09:27 PM   #61
whoisthis
Drives: bmw
im going to try to return my IJDMTOY H6W and buy the one you linked. I can code mine to get rid of the error. As long as it doesn't flicker while driving like IJDMTOY, im fine
F30 328i sedan
      07-03-2015, 09:31 PM   #62
ATL0501
ATL0501's Avatar
I'm not sure of flickering while driving. I have not seen any but it does during start up for like 1second
      07-03-2015, 10:56 PM   #63
slugmaster
Which ijdmtoy did you get? The one I got with an external error canceler doesn't throw error or flicker. Is it this one?
      07-03-2015, 11:14 PM   #64
whoisthis
Drives: bmw
Mine doesnt have the external canceler but its still suppose to not throw a code.
      07-04-2015, 08:32 AM   #65
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
SlugMaster, WhoIsThis & Atl0501,
Not meaning to be pain, but there are two separate aspects that we have entwined in this discussions:
• First, if LED bulb does not have resistor (built in or hooked in), the bulb will flicker -- think that has to do with normal variations in current (which for incandescent bulb would merely be a variation in intensity) -- and may cause errors.
• Second, BMWs have two built-in diagnostics to check whether the bulb is working: cold (at start up); and warm (periodically, think it is every 4 minutes). If the car gets nothing back, then there is an error code or something to indicate a bad bulb.
For the first aspect, getting error-free bulbs will be the cure; while coding is the only way to overcome the second, which you can operate the car safely with no problems (I know I did for a couple of weeks).
BTW, while there three items to code for each LED you install, it is not difficult -- will be happy to provide further details
Hope that helps!
Have attached my Bulb Chart
Al
Retired: 2014 328i
BMW CCA
      07-04-2015, 03:30 PM   #66
slugmaster
Thanks for the offer ro_f30! On my parking light, with the external canceller, there is no flicker at startup or strobing after. Also no error in dash. On the day time running light, I get flicker at startup. Does anyone know the circuit in the canceller? I am guessing it is resister and capacitor, or some IC mix with active components.
I use the headlights on auto, which usually starts up with the low beams on. I think this is why I rarely notice the DRL flickering, as it only turns on after you start driving and not in cold check. The parking light is almost always on though, and if it flickers at startup it will probably be noticeable.
Anyway, I am going to get the car coded. I think this is a better soln. If I attempt to do this myself I will PM. Not sure how hard it is or to get the cable.
