08-07-2014, 07:57 AM | #1 |
Rep 85
F32 M Performance rear diffuser
Hi All,
I want to order the M performance rear diffuser.. Fast question. Does it come in black matt standard? I don't want to have to spray it at all and was planning to install it on the car all black as I think it would look good with the M performance side foils and black tinted roof on my EB2 F32. Does anyone have a picture of t installed on an EB F32? Never seen one. Always been partially painted... I just want to be sure before I order the part. Cheers |
08-07-2014, 09:33 AM | #2 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
They are Matt Black
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
08-07-2014, 10:38 PM | #7 |
Rep 207
08-12-2014, 08:20 PM | #9 |
Rep 435
its very easy there are 2 bolts on each side and then 3 down the middle. some of the guides I read there were push pins, there were not on my 2014 f32. once you have the bolts out it pulls out. you can look at your new part for reference as to where the tabs are.
put the new one in, snap the tabs and fasten the bolts. it took me about 10 minutes by myself. |
08-13-2014, 12:57 PM | #10 | |
Rep 85
So I got the part. Do I have to cut the piece where the exhaust goes? Also I have some small metal fixture components and what looks like a rubber seal.... Not quite sure where these go. Any clue? |
08-13-2014, 01:54 PM | #12 | |
Rep 85
However I think I need to cut away the piece blocking where the pipes need to be mounted... Is this right? |
08-13-2014, 02:13 PM | #14 |
Rep 195
Drives: 435i XDrive M Sport MPPK+MPE
Yes it's right. You need to cut away that piece.
I receive and install it yesterday. Can anyone tell me what is the purpose of the white cord like a rubber seal ? I have installed the diffuser without take it... There is the picture of the diffuser on the car:
08-13-2014, 04:32 PM | #15 | |
Rep 36
It's used to mask around the middle part when painting. (in the groove) |
F20MAW73874.50 |
08-13-2014, 08:16 PM | #16 |
Rep 435
that is correct, if you read the official document it lists that rubber strip as masking tape. I assumed it was some sort of buffer for between the 2 pieces at first also but that is not the case it is for painting.
08-14-2014, 10:10 AM | #19 |
Rep 17
08-14-2014, 11:29 AM | #21 |
Rep 195
I think that using a Dremel is risky...
I use a knife like that and it was an easy and perfect cut job !
08-14-2014, 04:56 PM | #22 |
Rep 85
I had already installed it by the time I saw this...
Dremel cut through like butter. No problems and a super clean finish. Some pics to help others out. |
