BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Best pads for my car
      09-26-2017, 07:15 PM   #1
Chicken_Joe
Chicken_Joe's Avatar
Drives: 2013 F30 335i M Sport. EB 6M
I have a 2013 335 M Sport RWD without the blue brakes. I wanted to get better performing pads to match my driving style without having to shell out serious coin. I have a quote from Turner Motorsports that should work but they are oem pads I believe from a different kit if that makes sense. I know some people in here run hawk, pagid, etc on their cars and need opinions. This is the turner product list.
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, JB4, ER CP, VRSF DP. Dinan Shockware. Varis Japan carbon front lip. Carbon M Performance rear diffuser. Vvroom custom carbon side fins. Firehawk Indy 500 225/40/19 and 255/35/19
      09-27-2017, 11:59 PM   #2
cesarortiz23
cesarortiz23's Avatar
Drives: f30 335i / e82 135i
Looking for the same answer
I have a 2012 335i with
un finished (grey) brake brembo caliper
and also looking for some better front brake pads that are a bit more aggressive
I have just regular pads from r1 concept
I have there rotors aswell they are slotted
I just need a better pad I believe
2012 f30 335i lowered on h&r super sport springs on stance sc-6 wheels
e82 135i dct build in progress
      09-28-2017, 12:17 AM   #3
Tchao
Boost Addict
Tchao's Avatar
Drives: E30, E82, F30
EBC has pads for the standard 335i brakes (grey calipers)
Red Stuff:
https://www.shopebcbrakes.com/EBC-Re...es/p99668?sku=
Yellow Stuff
https://www.shopebcbrakes.com/EBC-Ye...es/p99672?sku=
Remember our front pads are the same as Msport & M3 brakes. The rear pads is whats killing us. A few people have posted that E90 335i rear pads fit, and from countless images they look like it would.
N55 PWG | Three Pedal Club | E30TU
      09-28-2017, 11:48 AM   #4
stxf30
stxf30's Avatar
Drives: '13 F30 335i MSport
Pads
These are next on my list, while maybe not a street/track pad, they perform well and have minimal dust.
EUR918 - Front https://www.carid.com/akebono/euro-u...pn-eur918.html
EUR1610 - Rear https://www.carid.com/akebono/euro-u...n-eur1610.html
2013 GSM 335i MSport | Sport Auto | JB4 | ER Charge Pipe | Challenge Down Pipe | AFE Momentum Pro5R | H&R Sports | MP Lip, Wing, & Rear diffuser
      09-28-2017, 12:34 PM   #5
Whistlefist
Drives: 2014 335i Msport
I've had the EBC Red Stuff on other cars. Good performance for street, but maybe not a track pad. If you are hauling ass on the freeway, they will slow you down quick, but they may fade with repeated aggressive stops and track driving. They do dust less and are quiet when cold so those are big positives for a street car.
EBC does make a rear set for the single piston calipers. DP32131C is the part number.
      09-28-2017, 06:17 PM   #6
Chicken_Joe
Update on my situation. I figured that I may as well do rotors for better cooling and lines while I?m there so this is the updated items. It?s so expensive so I may need to think for a little. I know stop tech has a package with pads and rotors i just want to make sure I have that same oem brake feel with the added stopping power.
https://www.turnermotorsport.com/Car...salesrep=ishea
      09-29-2017, 12:50 AM   #7
Tchao
Boost Addict
Tchao's Avatar
The only way youre gonna get better cooling is either improved duct work, or bigger (thicker) rotors.
Fancy slots and drills wont do much unless you use it in a severe duty track environment.
They are purely for the cool points. Plus they eat up pads faster.
Best bet is a blank rotor from BMW, Zimmerman, Brembo, R1 etc....and a set of pads that match your need.
EBC yellows are entry level track pads, but they dust like OEM. They are comparable to HP+'s minus the cold bite of the hawks, which also dust like a Mofo. Unfortunately I do not think there is a HP+ pad for us gray caliper peeps yet.
I know, it was in my link lol. Theres yellows too
      09-29-2017, 11:04 AM   #8
xxxjecxxx2
xxxjecxxx2's Avatar
Drives: F30 335i M Sport
I just did my rear brakes went with OEM. I I took my rotors off in the front and brought them o'reilly to have them turned. This made a huge difference in the steering wheel shake when braking.
JB4 FF | E85 | FTP CP | VRSF DP | N55 | BMS INTAKE | DV+ | ER IC
      09-30-2017, 03:57 AM   #9
Lancelot
France
158
Drives: 2014 M Sport ActiveHybrid3
If i'm not mistaken your rear calipers are floating Bosch calipers and will not accept what you're about to order for M Sport brakes, which are 2 piston fixed calipers (blue or aftermarket yellow/orange/red)
2014 M Sport ActiveHybrid 3
M Performance BBK - F80 CFRP struts brace - Quaife LSD - KW DDC coilovers - Akrapovic Exhaust - HJS EU6 downpipe - Wagner Evo2 Comp IC - BMC air filter - Powerflex Black Subframe Bushings - Bimmertech amp with Focal speakers
      09-30-2017, 08:08 AM   #10
Chicken_Joe
I talked to the Turner guy about that but he told me those calipers would take those pads
      10-06-2017, 08:38 PM   #11
xxxjecxxx2
xxxjecxxx2's Avatar
All the pads shown in the pictures of your cart are correct.
      10-06-2017, 10:07 PM   #12
afranke
Drives: 2013 ActiveHybrid 3
Sorry to jack the thread, but on a related note I recently converted to the blue M brakes all around, and while they seem to function perfectly fine, I can hear what sounds like the pads rubbing on the rotors while driving.
When I took the wheel off and rotated the disc manually, I could hear the rubbing until I pulled the pads back and compressed the piston. Is there some adjustment I'm missing or is this a function of having rotors with dimples/slots on this car?
I did a BBK swap on my Volvo S60 years ago and don't recall this being an issue.
2013 ActiveHybrid 3 (335ih) N55 PWG Meisterschaft GT catback Wagner tuning catless DP and Stage 2 Evo Comp Intercooler ER chargepipes BMS intake io2V3 O2 simulator Pure Stage 2 turbo with high-flow inlet and DV upgrade Fuel-It Stage 2 LPFP JB4 ISO firmware Fuel-It DIY PI Kit bootmod3
      10-07-2017, 02:27 AM   #13
Chicken_Joe
How did you upgrade to the blue pads? Is there a link you got for the calipers? I was thinking of doing M Performance takes but they are so expensive and actually on a nationwide freeze until 10/10
      10-07-2017, 02:50 AM   #14
afranke
I got a lightly used kit from a member on the forums here awhile back that included calipers, two sets of pads, new rotors, and ECS braided lines for all four corners. I've ordered new pad springs and guide bolts just to see if that helps.
EDIT: It was actually the ones in this thread: http://f30.bimmerpost.com/forums/sho....php?t=1352442
      10-13-2017, 04:24 PM   #15
FutureHendr1x
Drives: F30 335 Msport
+1 on the EBC red stuff, they bite pretty good for street use, and NO DUST. I had them on my mk7
      10-16-2017, 07:54 AM   #16
wdeerfield
A family of bimmers
Drives: '13 f30, '11 f10
they seem only rated up to 250hp
2013 EB/CR 335i xdrive | DHP | Coded | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
      10-16-2017, 03:14 PM   #17
YR430D
YR430D's Avatar
Drives: BMW 430D
I read on the turner motorsport page that M sport pads offer better feel and bite than M performance. Is that true of the discs? Better to go the M sport non dimpled and grooved over the M performance?
      10-16-2017, 03:16 PM   #18
bimmer456
Drives: 340i
My brakes were pulsating and I had them replaced for free now thy feel great.
      10-17-2017, 01:12 PM   #19
Bestodabest
Drives: 2014 435i Xdrive
This. Also, before swapping your rotors, use a vernier caliper to measure the wear. Usually rotors outlast a set of pads (assuming they're not warped or worn irregularly). If there's still plenty of material left, consider having the rotors turned. Otherwise, stick with blanks as Tchao suggested.
Upgraded brake lines outside of a track environment is a waste of money; stainless steel braided lines are also more prone to damage (dirt and debris find their way in between braids and damage the line).
      10-17-2017, 02:07 PM   #20
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
Grab stoptechs, they're probably the best pads I've used so far. minimal dust and great bite.
Wrong again, most if not all stainless steel braided lines are coated to prevent that. Stoptech's lines are lines are coated with a clear abrasion resistant PVC cover.
2013 335i xDrive
Bootmod3 S2, Pure Stage 2, Pure Inlet, GFB DV+, ER CP/TIC CP, ER Catless DP, CTS Turbo FMIC, Borla ATAK, Dinan Springs, Dinan Shockware
      10-17-2017, 02:11 PM   #21
Bestodabest
Abrasion "resistant"... key wording. Should I just tag you in all of my posts so you could follow me around and scrutinize every technicality?
      10-17-2017, 03:09 PM   #22
Chicken_Joe
To be fair resistant is a strong word. For example, Rolex does not say on the Submariner that it?s water proffer to 300M they say water resistant to 300m.
daddys car, mommys car
