BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Pure Turbo stage 1 vs stage 2
      07-23-2015, 05:17 PM   #1
M-terkait
M-terkait's Avatar
Kuwait
110
Drives: F30 335i 3/13
Send a message via Skype™ to M-terkait
Pure Turbo Stage 1
Stage 1 was a blast to drive, definitely better than stock after 4k RPM but still lacks the last thousand rpm, I have been running 93 octane full bolt-ons ( using Jb4 ) without methanol and i guess it's time for Stage 2 to go in.. Stage 1 was nice but if stage 2 was there a year ago i would have went straight to it.
here are some images to compare between both.
sorry but that what an Iphone 6 can do.
Pure Turbo Stage 2
the big boy goes in Saturday morning, i'll post more pictures about DV+. on Saturday!.
PureTurbo
      07-23-2015, 05:49 PM   #2
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
Nice !!
Let us know how it goes
      07-23-2015, 08:18 PM   #3
_bdiddyb_
Drives: 2013 335i
Question: PureTurbo sent u the kit with instructions? After all it's supposed to be "bolt-on". And also, did you have to get a specially programmed JB4 for it? I'd rather not take it to any shop for installation; I prefer to do this myself. Otherwise, I will have to just take it to PureTurbo, since they are not too far from me.
      07-23-2015, 08:23 PM   #4
M-terkait
M-terkait's Avatar
Kuwait
110
No instructions, I would take it to pureturbos if possible, atleast you know it will be in good hands; will set boost targets later on sunday before starting it.
PureTurbo
      07-23-2015, 08:30 PM   #5
_bdiddyb_
Drives: 2013 335i
Wait a minute, you're in Kuwait. Your shop KNOWS how to install it? Did they needed to contact Pureturbo for instructions?
      07-23-2015, 08:32 PM   #6
M-terkait
M-terkait's Avatar
Kuwait
110
No, but removed steering axle, water tank, intake other stuff in the way to the turbo then remove 9 upper bolts and lower 6 bolts
get the turbo-fold out.
PureTurbo
      07-23-2015, 08:50 PM   #7
av689
Drives: ESBII F30 328xi
Thumbs up and good luck
      07-23-2015, 11:13 PM   #8
obriennathaniel
@obriennathaniel_f30 on Instagram
obriennathaniel's Avatar
Drives: 582whp/596wtq '13 335i
its a pretty straight forward install, nothing tricky about it. just very tedious and time consuming.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | JB4/BM3 | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
dv+, jb4, n55, pureturbo, turbo
