BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Limits of the N20 engine? Beyond 27psi
      12-04-2017, 05:43 PM   #1
take1step
Drives: 16’ 428ix PS2
Post Limits of the N20 engine? Beyond 27psi
It's been a few months now I've been running the Pure Stage 2 turbo on my 2016 428xi at 25 psi. I recently updated the JB4 firmware to "N20_OBDII_EWG_5_T2.hex" and like some others here my default boost safety changed to 36 psi and the N20 tmap sensor turned on.
I knew the car could push more and with this new range of PSI from the JB4, I did a few runs on map 6, targeting 27 psi & 30 psi and then on Map 7 (30+psi). I haven't really seen or read about other people raising the boost on the N20's, but I've posted a few logs for references and a list of my mods below.
It seems like 27 psi is the limit these little engines are happy with. On the 30 psi Map 6 run and the Map 7 run, I was getting misfires around 55k RPM and 45k RPM respectively and had to let off the throttle. It wasn't any better if I tried raising Meth additive to 75. That being said, I had a few runs reach 30+ psi but it was very inconsistent, if anybody has any other input to safely increase boost, it would be appreciated.
Mods: Pure Stage 2 Turbo, JB4, Eurocharged Back End Flash, Fuelit LPFP, ER turbo CP, BMS Methanol Injection kit (50:50), Injen Intake, Wagner Catless DP, AWE Quadtip Exhaust. BMS spacers, H&R springs. 94 Oct pump gas
      12-04-2017, 06:38 PM   #2
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
I'm actually surprised you're brave enough to run an upgraded turbo with that fragile engine and without building it.
You'll probably have to get your EC BEF revised for higher boost. The misfires you're getting may be coming from running too rich up top or your spark plugs aren't gapped correctly or not iridium.
Try unplugging the MAF and do the run again, if it still misfires, then it's either the tune or plugs.
2013 335i xDrive
Bootmod3 S2, Pure Stage 2, Pure Inlet, GFB DV+, ER CP/TIC CP, ER Catless DP, CTS Turbo FMIC, Borla ATAK, Dinan Springs, Dinan Shockware
      12-04-2017, 08:26 PM   #3
take1step
I think youíre right, most likely tune. Iíll have to bring it back to EC in the spring for a reflash. The plugs are iridium but might need to be gapped a little more as well. Appreciate the input, maybe Iíll see you at a track day next year
      12-04-2017, 08:45 PM   #4
ckpaden
Drives: 2015 320i
More boost does not necessary mean more power if your running outside the efficiency range of the turbo. Running higher boost ranges will increase the chances of you blowing the motor. The difference here is the water injection has been tuned by someone who knows what they are doing. The advantage of water injection is its able to cool the intake temps by running the higher boost level and make up for the car running lean. The problem with these engines is they run hot and proper cooling is essential.
      12-04-2017, 09:44 PM   #5
F30_Adler
F30_Adler's Avatar
18
Drives: 2012 328i Sportline
I would not run anything over 23/24 psi on an N20 without rebuilding it forged. Anytime I have heard of the N20 running higher PSI than 23/24 stock it bricks the engine.
      12-04-2017, 09:48 PM   #6
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
I would recommend .018 gap, I believe your stock n20 plugs should be good as it's slready iridium.
Just run safe and efficient boost till you get the revision
      12-04-2017, 11:20 PM   #7
take1step
Will do, I’ll be keeping boost around 24/25 psi until I could put it on a Dyno again and tune it safely. Some cooling mods might be necessary eventually. Thanks for the support
      12-06-2017, 12:37 AM   #8
Stubok
Drives: Melbourne Red F30 328i M Sport
Wow that's aggressive! I've long suspected that it's Tuning that killed other engines.
Did you also replace your FMIC? Or is that stock? I guess the meth keeps your charge cool.
You should get Bootmod3, then you can adjust the tune in the fly with a tuner over OBD, and won't have to keep removing the DME each time you want to revise.
      12-06-2017, 09:30 PM   #9
take1step
The FMIC is stock for now. But Iíll most likely upgrade next year depending on how temps get in summer weather.
I was looking into Bootmod3, but I donít think Protuning Freaks does custom Dyno tuning. So I drove to Toronto (from Montreal) to put my car on Eurocharged Dyno for a custom tune.
Youíre right that the tune you have will make or break the engine, so I really wanted to get a custom dyno tune and make sure everything was running optimally.
      12-06-2017, 11:02 PM   #10
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
They do custom dyno tuning. They can also do remote custom tuning as well as it's the same thing.
      12-07-2017, 12:24 AM   #11
take1step
I’ll have to see if they could build on my current tune if I make the switch.
Once you get near the power threshold of the engine, the power differences won’t be that significant. More boost and timing won’t necessarily result in more power so the dyno is important, but anyways what do I know lol, that’s why I’d rather let the experts handle it. But they both offer similar services.
boost, jb4, ps2, psi, turbo
