05-27-2016, 03:22 PM | #1 |
Rep 195
Applying Sealant to cleaned car question!
My first time applying a protective synthetic sealant to a car was yesterday. What i found is that it does not glide across the car paint easily.
I used meguiars synthetic wax sealant mirror glaze 20 on a foam applicator sponge. i just claybar the car before. my other question is can you use spray wax to lubricate the surface or prime the foam pad or will this interfere with synthetic wax. |
05-27-2016, 04:47 PM | #3 | |
National Championship #17 and Counting!
793
Rep 1,508
In fact, the paint needs to be 100% clean or as close as possible before polish, sealant, and/or wax application. Best to use a citrus car shampoo, but just make sure you don't use dish soap or a car shampoo with wax mixed in. The car should be washed thoroughly between each step. To remove old wax, polish, clay lube, etc, you should use a pre-wax cleaner or paint prep before polish, then after polish before sealant/wax. Your sealant didn't adhere because it wasn't actually on your paint, it sat on a layer of spray wax. You'll need to do this process over again, but you know from now on the proper steps.
2018 i3s - Melbourne Red, Tera World, Ceramic Film all windows
Packs: Technology, Driver Assistance, HK Audio, Park Distance Control |
05-27-2016, 10:45 PM | #4 | |
Rep 195
I did wash thoroughly before clay. I thought that was a given |
05-28-2016, 06:46 AM | #5 | ||
793
Rep 1,508
During a paint correction, I use a waterless wash from a spray bottle, wiping down to dry as I go. Before sealant, I apply a pre-wax cleaner to ensure sealant adhesiveness to the paint. My sealant is Wolfgang's 3.0.
05-28-2016, 02:21 PM | #7 |
Rep 243
After you clay bar the car, you should polish it first and then apply a sealant. I highly recommend Klasse sealant.
Also, did you put your hand in a plastic bag and run it across your paint to see if you effectively removed the contamination with the clay bar? If your surface is prepped properly, your sealant should slide on. |
05-29-2016, 09:35 AM | #8 |
Rep 2,953
I'd also suggest polishing before waxing or sealing. I'd try sonax PNS over klasse SG though. Goes on and wipes off easier plus it's in an aerosol type spray
