06-27-2014, 01:13 PM | #1 |
Rep 14
US Import (US => ECE) - Problem with HU (FA Stay US)
Hey
A friend of mine bought a US 328i and I've started coding the car. I've added SA801 (National Version Germany) and a few other German Settings (Extra package, EU Specific, Language Version, Area Code, ...). I saved the FA, wrote it to the car and did a complete coding. All worked fine, execpt for HU (No Navi, just Radio). E-Sys shows: "DataGroup SYSTEM_EINSTELLUNGEN, Function COUNTRY: More than one condition parameter is active: [deutschland, us]" I checked FA again ... under point "Laenderausfuerung_PKW" there is "801_DEUTSCHLAND", but point "Ausfuehrung" still shows US ... my car has ECE instead. Can I change this to ECE? And if, in which way? All is working with german settings except the HU ... so the speed limit warning is in mph instead of kmh, ECO Pro settings the same ... even the cruise control is in miles on a km Speedo/Kombi. I've switched all settings visible to km/h or km where it was mph/miles ... but no luck, still in mph. Radio is working fine with german settings & frequency! So can someone tell me how i change the US to ECE in FA? Kind regards Marcus |
06-27-2014, 01:38 PM | #2 |
Rep 297
I don't understand... so your German friend (I'm guessing living in Germany) purchased a US car and exported it to Germany? Are the 328's cheaper in the states after being built in Germany? I noticed going through all the modules that there are a lot of different places for language. Some were in the ECU, which could possibly cause some of the conversion problems? Might want to do a search (think this can be done) on each module for "mph" and see if something shows that you missed..
06-27-2014, 01:45 PM | #3 |
Rep 14
He bought the car as it was/is from another guy ... this guy did the import and conversion of Headlights and other Hardware to meet german TÜV rules.
After he bought the car he noticed the car was a US Import (problems with Radio Frequencys and some settings regarding DRL) ... but it was much cheaper than a german car so he doesn't mind. I've set all to german Settings (KM/H instead of MPH, km instead of miles...), but some settings remain US ... so i wanted to change the FA and do a default FA coding. Worked just fine, except the Radio ... and this due to problem that FA states is a US Car with German Package ... but I've to change it to a EC/ECE Car with German Package and all problems will disapper (hopefully) With a few "bugs" the car IS german right now, but i want to fix this bugs ... to get a clean FA with all default settings to establish a "clean" solution and no "we change all things we can FIND to ECE" ... because i think some settings aren't that obvious |
06-28-2014, 05:09 AM | #4 |
Rep 40,768
In FA, what is the Type Code (e.g. FA => FZAuftrag => Type => Typschlussel=3C13)?
As for the Radio, you don't say what the issue is, but I suspect the issue is tuning in 200 Khz (U.S.) instead of 100 Khz (ECE) increments. Have you tried coding the following? RADIO_COUNTRY = ECE FM_DEEMPHASIS = 50us
06-28-2014, 05:17 AM | #5 |
Rep 14
Hi!
Thanks for your help (again) shawn, this was indeed a problem at first, but fixed this with your posted config. The remaining problem is: All Speed Settings in Radio/iDrive & Kombi/Speedo are in Miles (and Miles per Hour). Like Eco Pro, Speedwarning, Cruise Control, etc. Another friend gave me the typeKey hint a hour ago and i think this will help me/my friend. But testing this will take a few days ... my friend is now on a short trip As always ... great community! I'll give feedback when I'm ready with the coding this US 328i, to help other users |
06-28-2014, 06:35 AM | #6 |
Rep 40,768
Try adding Option 548 Kilometer-calibrated speedometer to FA and VO Coding Kombi and Head Unit.
06-28-2014, 06:39 AM | #7 |
Rep 14
Hmm I tried it with this Option AND German Version (SA801) ... but that caused the problems with the Head Unit ... so first I'll try just KM Speedo when he's back ... and if that doesn't work, I'll change Typekey to Europe 328i instead of US and try again with SA801
06-28-2014, 06:40 AM | #8 |
Rep 40,768
Good luck.
07-18-2014, 06:24 AM | #10 |
Rep 14
Hi!
First of all ... thanks for your support, i worked on this car yesterday. After changing the FA to ECE instead of US all worked fine, except the "Speedwarning" in HU. It stays with mph instead of kmh ... but i think this is due to the Speedo. The guy who sold the car to my friend & imported the car from US had some "tricky" solutions . To meet german rights you need to have e rear foglight ... in US not. So he switched the lights, but not the lightswitch on the left side. He just modified the original switch to have a button and curved the lamp logo right into the plastik . Looks very funny, was my first eyecatcher And for the speedo i think he just modified the plate to show german units (KM/h) ... the consumption line is "wrong". In my car the scale is from 0 to 20 and increasing to display consumption in l/100 km ... but his scale decreases from 30 to 0 with km/l. So it meets the us settings of miles per gallon. He has a "Low" Speedo without the LC Display on the bottom right. My theory is, due to the US Speedo, the HU just show mph instead of kmh because the Speedo works in MPH. I've coded the car with German Speed FA, but no change ... so i think its a hardware link or something like this. But he won't switch his speedo, because all works fine ... and he never uses the Speedwarning ... just ignoring the mph and is happy to have a "german" car after all |
10-03-2014, 03:19 PM | #11 |
Rep 1
Messed up radio
Crazyiven,
I changed my Radio_Country=ece, and FM_DEEMPHASIS=50us. My problem now is that the display added "MHz" after the channel frequency, and now shows too many characters, so the numbers get jarbled with the check mark and the numbers identifying the order of the stations. Do you have this problem with your radio? The stations are now organized in alphabetical order too instead of ascending numerically. Is there a solution for this? Am I missing some other setting? Thanks |
10-15-2014, 07:03 AM | #14 |
Rep 14
I meant ther're more settings than the one samer25 mentioned ... so you need so set the fa to a german car and recode the complete car ... and then change back the airbag module!
10-16-2014, 12:14 AM | #17 | |
Rep 50
is this CAFD file ? ACSM it's module for airbags ? My plan for coding car US ->EU: Change in FA parameter typeshlussen to EU (3A57 -> 3A55). Then recode whole car except the ACSM. Is this correct? |
11-17-2014, 05:56 PM | #19 |
Rep 50
In US cars is dual-stage airbag, in Europe is one-stage.
What is different in CAFD file in airbag configuration between US and ECE. Is coding car from US to ECE will change configuration for airbag (dual-stage => one-stage) ? |
08-22-2015, 03:19 AM | #20 |
Rep 1,123
Reviving this thread...
I'm trying to code radio to EU for a 2016 M3. On my 2014 435ix the schlüsselnumber didn't have to be changed to EU. I only changed HU > radio_country and deemphasis. This didn't work on the M3. Is there something new? |
11-16-2015, 01:09 PM | #21 | |
Rep 1,123
When I do this on a 2016 M3 the frequecies show up correct, but the radio has no sound anymore. Am I missing something? I'm changing Radio Country, FM Deemphasis.
11-16-2015, 01:48 PM | #22 |
Rep 75
someone changed it for me on the usa 428i - not sure about the process...
btw did you manage to change mls/h to km/h in your cruise control (kombi still shows mls)?...i am struggling with this one
bmw 428i (us->eu)
