BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Front Park Distance Control (PDC) Retrofit DYI
      01-27-2018, 01:05 PM   #155
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Originally Posted by boltinvader View Post
My ISTA isnīt working...
This is the link to my VO
https://picload.org/view/ddpriidw/esys.png.html
I put 507 and 508 in it
And my Middle Console Button isnt working too. is there any solution?
Remove 507.
507 is for rear pdc only and 508 is for front and rear. You can't have both 507 and 508 vo.
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      01-31-2018, 01:43 AM   #156
boltinvader
Drives: BMW F
Originally Posted by jkwhar View Post
Remove 507.
Thx got it working
But what is the Problem with the Button in the Middle Console. It is still not working
      01-31-2018, 07:55 AM   #157
jkwhar
Thx got it working
Did you add the wire from the ICM to the center console buttons?
The instructions state that a cable should connect pin 2 on the console to the ICM and on my car that was already connected.
What the instructions are missing is pin 1 and in the end the connections should be:
Centre Console <-> ICM
PIN1 GN/GE(Green/Yellow) wire <-> PIN28
PIN2 GE/BL(Yellow/Blue) <---------> PIN6 should already be connected
PIN3 <-------------------------------> PIN13 should already be connected
      01-31-2018, 12:02 PM   #158
boltinvader
Drives: BMW F
Yes I connect these wires. Just trying to get INPA working to test the PDC Sensors
      01-31-2018, 02:11 PM   #159
jkwhar
Did you VO code the REM, ICM, and HU_NBT/HU_CIC? Sounds like you didn't code the ICM maybe?
      02-22-2018, 02:19 PM   #160
Moto-XXX
Sweden
Drives: 2013 335iA Touring M-sport
Originally Posted by Icydubloon View Post
Just did the retrofit. As a note for others, you need to connect both of the following wires for the PDC on/off switch to work.
CC PIN1 to ICM PIN28
CC PIN2 to ICM PIN6
My (new) center console switch has the buttons for traction control, sport/eco up down buttons, and the PDC button.
If you have rear PDC, the PDC button will work without having to code front PDC. This is a nice check to perform before moving on to other parts of the install/coding.
So to be able to switch of my rear PDC I only have to install the button and nothing else?
      02-22-2018, 04:32 PM   #161
Jhnblckwood
Drives: F30 2014 320i xdrive
U don't "have" too. It will engage when u put car in reverse but u also must have a rem that has the pins for pdc.
      02-22-2018, 04:33 PM   #162
Jhnblckwood
Will engage when in reverse and turn off when in drive for a certain amount of time, u can set the time with coding.
      03-08-2018, 12:51 AM   #163
r2p
Drives: BMW 340i
PDC not work
Hello
I have wired and coded everything, but i get the error:
0x803232 PDC Sensor programming faulty
All sensors in the front have the self error,
someone had that already?
Thank you for help.
      03-16-2018, 08:02 AM   #164
2ippy
Drives: 320d Tourer M Sport.
Hi chaps,
I have rear PDC only on my 2017 f31, and want to disable PDC when reversing with trailer.
Someone mentioned in this thread, no coding required, for the PDC button.
What is the part number for the PDC wire, to ICM?
Any pics of you routing the wire?
And the plug goes into the ICM? and you put the 2 wires in the correct pins on the existing loom plug, for the console PDC switch side?
      03-16-2018, 12:35 PM   #165
atzebmw
Drives: Tesla Model 3
Normally, the rear PDC automatically shuts off when you have a trailer on it.
Has the trailer hitch been retrofitted?
      03-16-2018, 02:42 PM   #166
2ippy
Yes, westfalia towbar, from a well known fitter my end.
      03-16-2018, 02:53 PM   #167
atzebmw
Was the retrofit coded?
      03-16-2018, 04:05 PM   #168
2ippy
not that i know of, dedicated wire kit. The fog lights do turn off when hooked up.
      03-16-2018, 04:36 PM   #169
atzebmw
OK, I just searched the internet and found out that if you install the retrofit kit from Westfalia, it will not shut off the PDC.
And then you can not code that either.
So like your first idea you need the PDC button.
The problem is that this cable does not exist singly, but only together with the entire retrofit harness.
Maybe someone can find out the individual part numbers for the plug and socket contacts.
I will also try to find out the part numbers
The plug then will be plugged into the PDC button and the 2 wires into the ICM.
wire green/yellow Pin 28
wire yellow/blue Pin 6
      03-16-2018, 04:44 PM   #170
2ippy
odd that you can't code it :/
isn't there already a plug for the traction control, and sport mode settings?
      03-16-2018, 04:54 PM   #171
atzebmw
Ah yes, i just saw that it is only one plug.
So you only need the pins and wires.
You also then need a new/used operating unit centre console 61319252912.
Here a picture
https://www.ecstuning.com/b-genuine-...t/61319252912/
Only for example.
You can buy it used on Ebay.
      03-16-2018, 05:23 PM   #172
atzebmw
12527522387 should be the pins the plug.
The pins for the plug at the ICM i haven't found, but it could be that they are the same.
      03-17-2018, 12:47 PM   #173
2ippy
nice if someone confirms that, before i commit to tearing it out and buying. The PDC console is Ģ50
      04-05-2018, 03:29 AM   #174
gotomoto
gotomoto's Avatar
41
Drives: F30 3.20ied
I am making my own Front PDC retrofit wiring harness. Can someone confirm the color coding for "Cable Set Front bumper 61129260019" and cable in "Install.kit, Park Distance Control,front 66202338070" are the same?
      04-24-2018, 04:26 PM   #175
avantix
avantix's Avatar
Drives: 2019 M4CS Lime Rock Grey
If anyone is looking for parts for a front and rear retrofit hit me up.
I have all the original brand new BMW parts never installed as well as 8 PDC sensors (Silverstone II) and front and rear harness.
Also have the REM module with correct pinout. Never got around to installing it.
2019 M4CS Lime Rock Grey, MP HAS, GC camber plates, MPE
      05-22-2018, 12:52 AM   #176
GlennG
Hey!
I'm having some issues with the coding. i get the error:
Transaktions-Report: Aktion: Codieren
Abort!
Failed to code the CAF "CAFD_000007A1_005_044_005" of "REM--72", because it is not present in the STV actual. [C250]
Any suggestions?
Don't know if it matters, but i'm currently running E-sys 3.27.1 and PSdZData_v.4.11.20_Lite
