03-15-2018, 05:10 AM | #1 |
Rep 356
Charge pipe blew today , found one for a manual but im auto
Well guys i finally joing the blowen charge pipe club, i was lucky to find a free one the same day but is for a manual car and mine is auto so no vacum plug f*ck!!!!!
Any ideas ? Can i use the car with the vacum disconnected until the new one comes in maybe a week from now? If not maybe cut the new and the old and use a rubber coupling is what im thinking Thanks |
03-15-2018, 02:21 PM | #4 | |
Rep 10,473
Or I’ll sell you my OEM Part from 335i Auto. This is exactly why members should have purchased part with free shipping during Black Friday deals. |
03-15-2018, 07:08 PM | #5 |
Rep 153
Mine just blew on my 335i this past Monday...
Had the indie replace it and put new plugs in at the same time (I have just under 53K miles on the odometer). Now cylinders 3 and 5 are intermittently dropping out (which also triggers limp mode) and they couldn't figure out why. So it's been over at the the local dealer for 1.5 days and they haven't diagnosed it either, and I'm racking up rental car charges too (dealer had no loaners available). Sigh... |
03-15-2018, 07:39 PM | #6 | |
Rep 1,934
Put ignition coils 3 and 5 in cylinders 2 and 4. Clear the codes. If the same error code re-appears, but then reads cylinders 2 and 4, you can safely assume those two ignition coils are bad. Orrrrrrrr.... Just replace them all at once?
03-15-2018, 07:47 PM | #7 | |
Rep 1,953
Drives: 2013 328i xDrive
03-21-2018, 12:31 AM | #9 | |
Rep 153
According to the dealer, when coil packs go bad the can take out the spark plugs too. So if you swap the coil packs without swapping the spark plugs too, then you may have just blown two more spark plugs and made the problem worse. If the dealer is correct, then it'd be best to swap coil packs and plugs together and see if the problem moves with them. Because of this, they replaced all of the new plugs that the indie put in with another set of new plugs, and also replaced the coil packs on the two cylinders that were dropping out (3 and 5). Car seems fine now (idles smoother and seems to have a little more seat-of-the-pants torque too). They also replaced a leaking valve cover gasket (under CA emissions warranty) and the internal gas tank pump (BMW recall). She's all fixed up and runnin' good now! Last edited by VCuomo; 03-21-2018 at 06:20 PM.. |
cjack29.50 |
03-21-2018, 09:56 AM | #10 | ||
Rep 1,934
03-21-2018, 06:17 PM | #11 | |
Rep 153
03-26-2018, 05:53 PM | #12 |
Rep 190,750
Yep ^^
