12-06-2016, 09:21 PM | #1 |
Rep 42
A little help needed: Snow Tire setup
Hello,
I'm interested in purchasing a snow tire setup from tirerack but became a little confused on their site so here I am. My 340i has the track package with the 18 inch stagger setup. Do i need to buy the same size snow tires for the front and back or do i keep larger tires on the back? So many choices and I don't want to make a mistake. Any recommendations would be appreciated. |
12-06-2016, 09:23 PM | #2 |
Rep 4,876
You can go staggered front and back, but it's typically recommended to do a "square" setup with the same width of tires front/back.
That gives you better traction since the fronts will carve a path that the rears follow. And wider tires in the back tend to be worse for snow (less pressure on the contact patch). |
bad karma445.00 gongtowjai106.00 |
12-06-2016, 09:28 PM | #3 |
Rep 42
Thanks! Will I have to get the car coded if I run a square setup?
Also, if I purchase the TPMS sensors from tire rack will my BMW learn them after performing a reset from the idrive? |
12-06-2016, 09:29 PM | #4 |
Rep 524
I'm running staggered winters because I already had rims. My tires show recommended against it as square setup is better in the snow (the thinner the tires the better for snow). But my staggered is fine so far
12-06-2016, 09:35 PM | #5 |
Rep 576
I purchased the BBS 18's with TPMS, square setup which is easy to rotate. You reset the sensors in the settings menu I think. Very easy, the BBS offset is also very good.
12-06-2016, 09:38 PM | #6 |
Rep 331
I'm about to pull the trigger on a set for my 335 as well. Personally I'm trying to run a squared 17" setup for the winter. Larger sidewalls for all the potholes, and overall cheaper tires. That said, 18's will look better.
2017 F80 M3 - Mineral White/Amaro Brown
2003 E46 M3 - Jet Black/Cinnamon |
12-06-2016, 09:56 PM | #7 |
Sustinendum Victoriam
80
Rep 349
I purchased a square set up for my staggered wheels. I went with the squared set up cause of the better selection; was difficult trying to find selection when using the staggered sizes. No need to code the vehicle for tire set up changes.
12-06-2016, 11:52 PM | #8 |
Rep 456
I am running a square 245/40/19 setup on my M Performance wheels. The tires I choose were the Falken Pro G4 A/S. It snowed here in Seattle on Monday and the RWD F30 did remarkably well in the the slush. Stopping power and traction were very good. I cannot wait to see how the tires do in a downpour of snow heading our way on Thursday.
12-07-2016, 12:10 AM | #9 | |
Rep 808
12-07-2016, 06:15 AM | #10 |
Rep 3,288
17's may not fit on your brakes (they do not with the blue M-Sport brakes).
12-07-2016, 06:19 AM | #11 | |
Rep 1,659
Drives: 2022 WRX World Rally Blue
Yes, your car will learn the TPMS sensors installed by TireRack.
Rick
12-07-2016, 06:24 AM | #12 | |
Rep 1,659
To me, they look just fine. I bought Rial Salerno wheels and paired them with Michelin PA2 tires in size 225/50R17.
Rick
12-07-2016, 06:28 AM | #13 |
Rep 821
No coding needed. Just do a TPMS reset through idrive. Make sure the wheels you purchase clear the performance brakes.
12-07-2016, 08:30 AM | #14 |
Rep 333
We ran 17 inch mags we picked up from tire rack with a tire/mag package on the 335i with Msport (not the brakes package) and a square set up with 225 tires...was fine, cleared the brakes...I'm running the same mags on the wagon
You want a square set up to be able to rotate and get a little more use out of the winters
2018 F80 M3 6MT (current)
2014 F31 328i Touring (sold) 2008 E92 M3 6MT (sold) 2011 E90 335xi (lease up) |
12-07-2016, 09:09 AM | #15 |
Rep 1,329
Yes, with the track pack you should get an 18" square set-up of wheels, sensors and tires from the tire rack. They can ship you the complete mounted set ready to put on your car. Call Keith at TireRack - he is the forum sponsor, and he will make sure you get something that fits your track pack brakes and help you select an available tire best suited for your use.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
gongtowjai106.00 |
12-07-2016, 10:17 AM | #16 |
Rep 2,802
Narrower tire IF you are driving in deep snow. Otherwise (dry or wet)I believe you are sacrificing grip. I'm in Ontario and rarely are we driving in deep snow. I've always gone OEM sizes fro winters...in fact I just went UP 2 sizes to 275 for winters on current car.
12-07-2016, 10:48 AM | #17 |
Rep 255
I would recommend you read over information in the wheels & tire forum, it is very helpful. I started look there about a week ago with very little knowledge and now I'm confident in the setup I'm going with. Keith also volunteered to assist me (from tirerack/com he is the moderator).
2011 X5 xDrive 50i - retired
2016 340i xDrive - retired 2020 M4 Coupe |
floydarogers690.00 |
12-07-2016, 02:52 PM | #18 |
Rep 42
Anyone know Keith's last name to ask for when I call tirerack? (Please PM it or the best way to contact him). I'm going with the Michelin set but not convinced on the rims they're selling.
12-07-2016, 02:56 PM | #19 | |
Rep 1,329
Ask him about the tires too. Use his expertise to the fullest. For my use, I would do Blizzak WS80 on the least expensive wheels they have to fit the track handling package and you are at $1400 plus tax/shipping. But he could qualify choices for your use better than I could.
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT Last edited by metallicpea; 12-07-2016 at 03:03 PM.. |
12-07-2016, 04:35 PM | #20 |
Rep 576
I did the Michelin x-ice xi3's and my wife loves them, I used them in 3 inches of snow and also find them way better than the performance snows in was using Dunlop 3d's.
My setup BBS SR's, 225/45/18's, they clear the 340i with track package, and as I said earlier, it's a great offset front and back, and it looks good. |
gongtowjai106.00 |
12-07-2016, 04:42 PM | #21 |
Rep 34
If you buy a winter tire set with cheap alloy wheels make sure you take the time to clean them well before putting them away in the spring. The finish on these wheels deteriorate quickly, then the wheel corrodes. Corrosion around the tire bead will cause leaks.
12-07-2016, 05:52 PM | #22 |
Rep 42
Thank you everyone for the information. I called Keith and placed an order for the Michelins. He said when you select the track package on their site you will only be shown rims which clear the brakes.
Excited to put these on and not fly everywhere when the tires are cold. |
