BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Gas Tank Access Door Doesn't Close
      02-13-2013, 02:58 PM   #1
dude987
Drives: BMW 335i xDrive M-Sport DHP
Tried to close the gas tank access door after filling the gas tank and it wouldn't latch shut. The temperature was about 30 degree fahrenheit and the latch that catches the access door would not pop out. What happened to quality? Is anyone else having this problem? I never had this kind of a problem with a Lexus. Just a little irritating.
      02-13-2013, 03:05 PM   #2
Tsuyoi
Drives: 2013 F30 328i
Had a few complaints about this before, usually due to dirtiness/wetness of the latch area. Try cleaning surfaces and drying it, then see what happens.
      02-13-2013, 03:10 PM   #3
Frogman
Drives: 2012 F30 328i
Also make sure the cap is closed completely. There's very little clearance there.
      02-13-2013, 03:18 PM   #4
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
there are defective plastic latch thingy's out there, I had one - whole closure was replaced...it acted up more in the cold, so sounds like a similar problem.
SOLD: 2012 335i Mineral Gray
      02-13-2013, 03:43 PM   #5
jzcrna
Drives: 2019 M2 Competition
Mine did this but then resolved itself
      02-13-2013, 03:45 PM   #6
Yay-Z
Shifting to Top Gear
Yay-Z's Avatar
Drives: F10 M5/E70 X5
Were your doors unlocked?
2015 F10 M5 CP
2013 E70 X5
      02-13-2013, 03:48 PM   #7
pkimM3r
pkimM3r's Avatar
205
Was gonna say wont open or close if doors are locked.
      02-13-2013, 05:48 PM   #8
nick1212
nick1212's Avatar
Drives: '13 335i Sport 6MT - Gone soon
Make sure doors are unlocked.
Current - 2016 340xi M-Sport, BSM w/ Coral red interior, 6MT, Premium package enhanced, M-Sport package.
Previous - 2013 335i Sport Line Sapphire Black 6MT with Premium Package, Extended BT, BMW Assist & Lane Departure Warning System, M Sport Suspension & VSS
      02-13-2013, 10:17 PM   #9
dude987
Did not know this. Passenger door was locked and driver door was unlocked. Will have to check it out.
      02-14-2013, 07:39 AM   #10
BMWrules7
Drives: 2015, 740 LdX, Alpine White
Originally Posted by setha
Just take it in they will repair for free
It's not broken. He had his doors locked.
      02-14-2013, 02:37 PM   #11
dude987
Okay. So I filled up the gas tank again today and made sure the doors were unlocked. Wha-la. It worked. The outside temperature was about 27 degrees and the access door slammed shut just like it should.
Tested the door locks and sure enough if the doors are locked the access door is locked also. What I don't understand is why the access door opened when one driver door was unlocked and the passenger door was locked.
So maybe, if one door is unlocked and one door is locked the access door will open but not close shut??? I dunno.
Just glad to have it resolved for now.
      04-07-2013, 11:55 PM   #12
keremorhan
Russian Federation
Mine does not close when all doors are unlocked. I had to push and hold it closed when i pushed the lock button on the key. Now it is locked. Did not try yet but i think it would pop out again when i will push the unlock button on the key.
Nothing broken inside. I wonder if it is a temporary problem or i should take my car to dealer???
      04-08-2013, 12:37 AM   #13
bavarianride
Drives: bimmer
No need to be confused, as there is an explanation(I think). The gas access door has a spring-loaded toggle mechanism. With one push, the access panel toggles open, even if the doors are locked, but lock pin holds the panel in place(I haven't tried if a 2nd push will toggles the panel closed again). When at least one door is unlocked, the panel will pop open. If the door is locked again before the panel is pushed to close, the lock pin will block the panel to be closed.
Hopes this helps. It should be relatively straightforward to verify the above.
      04-08-2013, 12:41 AM   #14
bavarianride
Drives: bimmer
If the doors are unlocked, the gas access panel should be able to be opened and closed(toggled) with subsequent pushes of the panel. Your description seems to indicate the spring loaded toggle mechanism is malfunctioning(sounds like the lock pin is holding the panel if doors are locked, and the spring is always at "open" position). Maybe it's time to bring in to dealership to check.
      04-08-2013, 01:03 AM   #15
keremorhan
Russian Federation
I will try again and see what happens. Will inform later...
      04-08-2013, 07:26 AM   #16
Waterbelly
Drives: 2020 X3M Comp
Just took mine in to have the PPK installed on Saturday. Had the same issue with the gas tank door. SA said 5 other people had come in with the same problem - has nothing to do with door looks. They have a bunch of defective latches. Have to order in parts, etc.
      04-08-2013, 07:53 AM   #17
N-Y
Drives: 2012 BMW 328i
that door always opens when i go through the drive through car wash, when I get to the last part, when the car is getting air dried
      04-08-2013, 09:14 AM   #18
shivaswrath
Drives: 2012 335i
Yup, mine was replaced in the winter when it stayed open for like a week.
      04-08-2013, 02:03 PM   #19
PierreTT
Drives: 2013 335 iX
Same here, it is a cold related issue
      04-08-2013, 10:48 PM   #20
tkwliu
Drives: 328iA Sport
I experienced a similar issues, the latch just wouldn't shut properly. It took me a little while to figure out what happened but it was the tether that was attached to the fuel cap inside that was the problem. When refueling i must have twisted the tether and bundled together inside that when i close the outer fuel cover, the tether would obstruct part of the room needed for the hinges of the cover to close properly. Hope this helps
      04-13-2013, 06:41 AM   #21
keremorhan
Russian Federation
yes. this is the reason. funny....
