01-27-2016, 07:25 AM | #1 |
Rep 11
BMW Live enabling
Hi folks
I've a f32 with retrofitted NBT with iDrive touch (with the plugin module for VIN check and to unlock video in motion) Original car equipment: Code:
Order options No. Description 1CA SELECTION COP RELEVANT VEHICLES 2PA LOCKING WHEEL BOLTS 2PM 18"M LT/ALY WHEELS DOUBLE SP. 441M/ 2TB SPORT AUTOMATIC TRANSMISSION 2VL VARIABLE SPORTS STEERING 230 EU SPECIFIC ADDITIONAL EQUIPMENT 258 RUNFLAT TYRES 337 M SPORT PACKAGE 4DX HIGH.TRIM FIN. BLUE MET. MATT 4MR INT. TR. FIN. ALUMINIUM HEXAGON 4NE BLOW-BY-HEATER 481 SPORT SEATS F DRIVER/FRONT PASSENGER 502 HEADLIGHT WASHER SYSTEM 522 XENON LIGHT 534 AUTOMATIC AIR CONDITIONING 575 ADDITIONAL 12V POWER SOCKET 6NH HANDS-FREE FACILITY W. USB INTERFAC 6VB CONTROL INFOTAINMENT 698 AREA-CODE 2 710 M LEATHER STEERING WHEEL 715 M AERODYNAMICS PACKAGE 760 INDIVIDUAL HIGH-GLOSS SATIN CHROME 775 INDIVIDUAL ROOF-LINING ANTHRACITE 8KA OELSERVICE INT. 30.000 KM/24 MONTHS 845 ACOUSTIC BELT WARNING 855 LANGUAGE VERSION ITALIAN 884 ITALIAN / ON-BOARD DOCUMENTATION 962 NUMBER PLATE HOLDER FRONT, DELETION modified the VO and writed to the car with VCM>Write FA FP Code:
1CA,230,258,2PA,2PM,2TB,2VL,337,481,4DX,4MR,4NE,502,522,534,544,548,563,575,609,614,616,698,6AK,6AL,6NR,6NS,6VB,710,715,760,775,845,855,884,8KA,962 Code:
3003 > DUN_PROFILE - aktiv 3003 > PAN_PROFILE - aktiv 3003 > ONLINE_BROWSER - beide_aktiv 3003 > ONLINE_SERVICES - nicht_aktiv 3003 > ONLINE_SERVICES_GLS - nicht_aktiv 3003 > ASSIST - nicht_aktiv 3003 > ONLINE_BROWSER_LIVE - aktiv 3003 > DATACOMM_CSIM - nicht_aktiv Tethering works because if I try to update bmw online service it connects to my iPhone. I've also tried to do this: Code:
Under FZAuftag-Header, Change the VIN number from yours to the DONOR VIN (Original VIN that your NBT came with) Make sure you put in the FULL VIN. Save it as xxx - NBT ONLY or whatever you want to call it. You would use this VO only when you use to FDL Code your NBT. BTW, before this NBT was working but without Mp3 artwork when playing music/spotify/deezer. Now I can see songs artwork but the strange thing is when the song ends the player don't start the next song, i've to manually start from the phone :dunno: |
01-27-2016, 08:30 AM | #2 |
Rep 1,976
Drives: 2020 G20 320i M Sport
You should remove 6VB or else your BMW Apps is not going to work properly. Also did you change the FA to have the the donor VIN in there and VO code HU_NBT? After you do that, try doing a BMW Assist Update on the menu and see what happens.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
01-27-2016, 09:13 AM | #3 | |
Rep 11
Read FA, save, edit adding the donor vin under FZAuftag-Header, saved, activated, coded the NBT with Code:
3003 > DUN_PROFILE - aktiv 3003 > PAN_PROFILE - aktiv 3003 > ONLINE_BROWSER - beide_aktiv 3003 > ONLINE_SERVICES - nicht_aktiv 3003 > ONLINE_SERVICES_GLS - nicht_aktiv 3003 > ASSIST - nicht_aktiv 3003 > ONLINE_BROWSER_LIVE - aktiv 3003 > DATACOMM_CSIM - nicht_aktiv Anyway I will try removing 6VB. I need to add any other ? Thanks |
01-27-2016, 12:52 PM | #4 |
Rep 11
Tried again with:
Read FA>Save>Edit>Removed 6VB>Calculate FP>Save>VCM>Write FA FP Edit FA, edit VIN number>Calculate FP>Save>Activate FA and coded NBT again two times with: Code:
3003 > DUN_PROFILE - aktiv 3003 > PAN_PROFILE - aktiv 3003 > ONLINE_BROWSER - beide_aktiv 3003 > ONLINE_SERVICES - nicht_aktiv 3003 > ONLINE_SERVICES_GLS - nicht_aktiv 3003 > ASSIST - nicht_aktiv 3003 > ONLINE_BROWSER_LIVE - aktiv 3003 > DATACOMM_CSIM - nicht_aktiv What I can do now? |
01-27-2016, 08:04 PM | #5 | |
Rep 67
Regarding the MP3 album art not showing, there are a couple of codes that you can check but I don't have them now. For music playing issue, suggest you to update your media / phone software via www.bmw.com/update first. Input your DONOR Vin in order to get the software update for your retrofitted NBT. The latest version of the bin file should be UPD05073 (90.1 MB) for MN-002/TN-002 software series. |
01-28-2016, 05:10 PM | #6 | |
Rep 11
01-29-2016, 10:47 AM | #8 |
Rep 5
01-29-2016, 10:49 AM | #9 |
Rep 74
hi,
I have almost the same problem. I had VO coded BMW live on my hu_entry. Today I retrofitted NBT and it is functioning good. At first BMW live was active and working great. But then it disappeared suddenly when I pressed "update bmw services." By the way retrofit is registered to BMW by FSC. No emulator or what so ever. Any ideas how to re-enable BMW live? |
01-30-2016, 09:00 AM | #10 | |
Rep 11
01-31-2016, 02:23 PM | #12 |
Rep 5
01-31-2016, 02:29 PM | #13 |
Rep 11
02-01-2016, 05:53 AM | #14 |
Rep 5
02-01-2016, 09:18 AM | #15 | ||
Rep 74
Do I have to upload my legal FSC code back into the NBT after I finally code with my original VIN? |
02-01-2016, 11:03 AM | #16 |
Rep 1,894
Hi all,
Nice thread, I also 'had' BMW Live, until I pressed the update button. If I'm reading this correctly, I need to: 1. Change my FA with the WBAFV31030DZ17872 and write to the car. 2. VO Code the NBT 3. Change my FA back to my original VIN and write to the car. Should VO Code my NBT again? I'm guessing I shouldn't as it'll just use my original VIN again. |
02-02-2016, 10:34 AM | #17 |
Rep 5
Today I tried again with no success. The NBT stay black when I change the VIN.
In my opinion this is not possible for me due to I have a factory installed NBT but without those live features. |
02-02-2016, 08:46 PM | #18 |
Rep 67
You need a emulator if you are coding someone else's VIN into your NBT. So if you have factory installed NBT, it's not just a direct coding but hardware is also needed.
02-02-2016, 08:54 PM | #19 | |
Rep 67
1. Edit FA and change VIN to WBAFV31030DZ17872 2. Save as a new FA (do not use this new FA for all other purposes other than enabling BMW Live) 3. Do not write the FA to the car 3. VO code NBT (make sure you've disabled VCM and MSM update in eSYS option) 4. Go to ConnectedDrive and update service 5. Edit FA and change VIN to your car's VIN 6. VO code NBT 7. Do not update service anymore (You also need a emulator for coding someone else's VIN into NBT) |
02-03-2016, 07:21 AM | #20 | |
Rep 1,894
Once I've done the above, everything else like generating DE code for the maps is unaffected? i.e. I should still use the NBT donor VIN. |
02-03-2016, 07:42 PM | #21 |
Two turbos are better than one!
119
Rep 404
I am having a hard time with getting BMW live and internet to work. My car came with :
1CA,248,249,258,2NH,2PF,2TB,2VF,2VL,302,319,322,33 7,3AG,403,423,430,431,441,459,465,481,488,494,4DX, 4MR,4NE,508,521,522,524,534,548,563,5AC,5AP,5DF,5D S,609,610,645,688,693,697,6NH,6VA,6WA,710,715,760, 775,823,838,840,845,853,876,8KC,8S4,8SM,8TH,925,99 2,993, In order to activate Bluetooth streaming, ipod control through apple cable and office integration by build was changed to : 1CA,248,249,258,2NH,2PF,2TB,2VF,2VL,302,319,322,33 7,3AG,403,423,430,431,441,459,465,481,488,494,4DX, 4MR,4NE,508,521,522,524,534,548,563,5AC,5AP,5DF,5D S,609,610,645,688,693,697,6NK,6VA,6WA,710,715,760, 775,823,838,840,845,853,876,8KC,8S4,8SM,8TH,925,99 2,993, I have followed Shawn Sheridan's directions to no avail. I can't get update services to not be greyed out. BMW live and internet options are there, bluetooth tethering is on and I have checked the option to use phone mobile data in CIC. Anyone in the same boat manage to get theirs activated?
Sapphire Black M4 Competition Last edited by rezadue; 02-03-2016 at 07:47 PM.. |
02-03-2016, 09:16 PM | #22 |
Rep 67
Yup, your FSC VIN will NOT be changed, actually it is essential as you need a valid FSC (which was generated using the NBT donor VIN) for activating both navigation and map, so you should continue to use your NBT donor VIN to generate map key in the future, in case of map update.
