10-08-2017, 12:08 PM | #1 |
Rep 7,000
DTUK Pedal Box Plus Review
Having had a really positive experience with the DTUK CRDT 3+ tuning box I decided to buy the DTUK Pedal Box Plus.
Fitting Literally takes 5 minutes, remove the screw cover at the base of the accelerator pedal and then unscrew the torx bolt. Slide the accelerator pedal upwards and unclip the electrical connector, connect the pedal box connector in-line and slide the pedal back onto its bracket. Replace the torx bolt and cover and that's it. You can place the controller anywhere that suits you as the cable is more than long enough. The controller comes with a holder and a sticky pad so there is no need to drill holes etc Setting Up There is a setting called PerfecTune which learns the travel of the pedal so it know how far the pedal travels from top to bottom and delivers the best possible result. This takes less than a minute and is very straightforward. Once set up there are 4 modes - Off - City - Sport - Race Each mode alters how the results are delivered Within each mode (except off) you can fine tune from -3 to +3 to alter the characteristics of the Pedal Box Result Instantly you can tell that the Pedal Box works, previously when you accelerated there was a noticeable pause from when the accelerator is pressed to the car responding, now its instant. When driving you only need to press the accelerator a small amount, your pedal inputs are amplified. Comfort mode on the gearbox feels a lot more like Sport and Sport is incredible the car feels alive and raring to go. When pushing on the performance is instant, lift of the pedal and then back on and its immediate, the car is a lot more drivable and increases the enjoyment no end. It reminded me of the days when cars has cables from the accelerator instead of drive by wire. I switched it off as a comparison and at the first junction when pulling off I thought for a split second that the car had stalled as there was a pause when accelerating. I took the car to Darth Helmut as he drove it previously with the BlueSpark fitted but had not driven it with both DTUK products fitted, he was impressed and am sure will add a comment. Overall the two products have transformed the car, if the tuning box is not a route people are comfortable with the PedalBox+ is a no brainer as the improvement in drivability is amazing. https://www.diesel-performance.co.uk...Pedal+Box+Plus |
10-08-2017, 01:44 PM | #2 |
Rep 2,029
Great write up mate.
I can most certainly vouch for the package of the DTUK box and throttle tuner on Jons F10. Totally transforms the car. The tuning box on its own gives the next best thing to a stage 1 remap but adding the throttle box puts the icing on the cake and now it drives with so much response when needed. Takes away that typical FBW lag or latency. I have a stage 1 remap and the RaceChip XLR throttle on mine and I certainly advocate to anyone who has a good box or a remap to look at trying a throttle box too. |
JLR19691881.00 |
10-08-2017, 01:49 PM | #3 |
Rep 32,881
Imo if anything the accelerator response in sport is a bit too quick, so I?m not sure why there is the need for this. Surely it reduces modulation of the accelerator even more than sport mode already does?
10-08-2017, 01:53 PM | #4 |
Rep 2,029
Yep exactly that but the beauty is you can mix and match the throttle response in any chassis setting. So even in comfort mode, you can tweak the throttle to be a bit more lively. It takes out that first 1cm of f**k all that you always get. But the great thing is when driving hard, you can almost play with the throttle in a similar way you can with a nicely set up manual but still have all the perks of an auto box. Demand and position of the throttle is more harmonised.
JLR19691881.00 |
10-08-2017, 03:56 PM | #5 | |
Rep 7,000
The car is a lot more of a car and a lot better to drive than without it. |
Darth Helmut1780.00 |
10-08-2017, 04:11 PM | #6 |
Rep 4,932
Interesting thanks. I have a dtuk on the 340 and whilst certainly giving the extra power does make the delay in comfort more noticeable. If it removes that initial sleep and sudden wake up well pulling off in comfort then that's a winner.
What's it like to drive with the pedal box in sport bit the car in eco pro? |
10-08-2017, 04:17 PM | #7 | |
Rep 2,029
10-08-2017, 04:30 PM | #8 | |
Rep 7,000
I now have Race mode +3 for the dry and sport mode +1 for the wet I believe that they have a sale or return policy like the tuning boxes so you can see if you like it. I have just switched off the tuning box to see what the pedal box is like on a standard engine. |
10-09-2017, 05:38 AM | #10 |
Rep 7,000
10-10-2017, 03:52 PM | #11 |
Rep 401
Does it remember your last setting after switching off the engine?
Shame i did not know you had this Tony as i would have loved to have a look at the process and results when we met up at the RR in surrey! |
10-10-2017, 04:04 PM | #12 |
Rep 1,846
Never really heard of these. Thinking about it forgive me if I'm wrong but doesn't this just in a nutshell increase throttle percentage for a smaller demand ie, if demanding 20pc it'll output 50pc thus feels sharper and quicker because it's demanding more fuel thus more power targeting that cell in the ecu. Diesels don't have a throttle body as such but tps .
I'm pretty sure this how sport vs other modes (eco Pro/comfort etc) work apart rpm shifts points and chassis. Thanks |
10-10-2017, 05:36 PM | #13 | |
Rep 7,000
It's Jon by the way I did not have it at the RR day just fitted it last week. |
10-10-2017, 05:39 PM | #14 | |
Rep 7,000
There is now no delay the effect is instant, instant power no delay. As mentioned the car feels alive and a lot more interesting and engaging to drive |
10-11-2017, 12:50 AM | #15 |
Rep 1,797
So, for example, in comfort, you could have comfort gear change timing and gear selection, without the peddle input lag?
G20 M340i
Gone F36 435d F30 335d |
10-11-2017, 04:13 AM | #16 |
Rep 7,000
10-11-2017, 04:36 AM | #17 |
Rep 1,907
I had a similar thing fitted to my Merc (sprintbooster), brilliant bit of kit but sport mode on the beemer is very similar so surely fitting this will make the car very sensitive in sport mode?
Happy Motoring
Evdok |
10-11-2017, 05:04 AM | #18 |
Rep 2,029
10-11-2017, 06:03 AM | #19 |
Rep 1,705
This sounds like a great bit of kit. I often idly browse the threads on tuning boxes, get tempted, but conclude that for me it's a solution to a problem I don't have. Real world, my car is already plenty quick enough for me, but I am always switching up to Sport, even around town, because I find the throttle map in Comfort so irritating. What I want is an instant response when I spot a gap at a busy roundabout, or need to get up to speed quickly on a short slip road, etc. If it makes the car generally 'feel' quicker, so much the better.
10-11-2017, 06:36 AM | #20 | |
Rep 7,000
mcoops1757.00 |
10-11-2017, 06:38 AM | #21 | |
Rep 7,000
When I am in sport mode I can put the pedal box to race and have it it set on standard rather than say plus 3 You can tweak it so that it suits your style of driving etc |
evdok818.00 |
10-11-2017, 09:43 AM | #22 |
Rep 60
