09-04-2015, 04:30 PM | #1 |
Rep 390
I've searched for this symptom but haven't found it.
On three or four occasions after an hour or so of driving with the A/C on the air flow drops of to near nothing. What is curious to me is that the fan sounds just as loud as ever but the volume from the vents is almost nil. What little air that is entering seems cool. I think the A/C has been in the manual mode on these occasions. I had the car at the dealer a couple of days ago for an oil change and service check but they couldn't detect anything and said there were no codes. I have an appointment in a couple of weeks but don't relish the thought of them driving my car around for an hour or more in order to replicate the problem. If someone else has experienced reduced air flow and could share the solution then I could point them in the right direction. Thanks.
Best,
Charlie 2013 328i MSport Estoril Blue, 6spd MT, Premium, Tech & Drivers Assist +, Bavsound Stage One/Ghost, Bimmertech Amp |
09-04-2015, 08:03 PM | #2 |
Rep 4,439
Drives: '23 X1 28i xDrive
Isn't that the point of AUTO climate control?
09-04-2015, 08:32 PM | #3 | |
Rep 390
Best,
09-04-2015, 09:13 PM | #5 | |
Rep 390
Best,
09-05-2015, 07:55 AM | #7 |
Rep 4,723
Probably on auto recirculate, and after a while it will stop recirculating so it does not freeze up.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
09-05-2015, 09:00 AM | #8 |
Rep 390
09-05-2015, 06:38 PM | #9 |
Rep 5
I have had this happen twice in my first 5k miles. Both times I was in manual mode on a low fan speed for an hour or so. Had to turn hvac completely off for a few minutes. Once I turned it back on it was normal again.
09-05-2015, 08:46 PM | #10 | |
Rep 390
Best,
09-07-2015, 04:06 PM | #12 |
Rep 390
I contacted the service advisor today to tell him what I had learned about this issue here on the forum. He told me there is a service bulletin which addresses relocation of the evaporator temperature sensor and that he can do the repair while I wait next Monday. He said they just did one last week so, perhaps, he learned about it since I was there on Monday.
Best,
09-08-2015, 03:50 AM | #14 |
Infidel
122
Rep 1,102
Keep us informed, I wanna know rhe Bulletin nr
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
09-08-2015, 06:25 AM | #15 | |
Rep 390
Best,
07-15-2016, 08:22 AM | #16 | ||
Rep 4,723
07-15-2016, 09:44 AM | #17 |
Rep 16,054
Classic freeze up symptom. When you turn it off the ice melts off the coils.
07-15-2016, 09:32 PM | #18 |
Rep 4,323
M3s (f80s) having similar issues - ask your SA to see what's being done for them.
07-16-2016, 12:26 AM | #19 | |
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
07-16-2016, 08:17 AM | #20 |
Rep 390
I had my car at the dealer for something else but told my SA the AC acted up from time to time even after they completed the TSB. This time they found it was down a half pound in refrigerant. I'll bring it back in a month or so and hopefully the dye they put in when they recharged it will lead them to the leak.
Best,
07-16-2016, 09:28 AM | #21 |
Rep 328
This forum is populated with many such complaints about the AC units which stop blowing air, a classic symptom of a frozen evaporator coil. My E90 also had an evaporator coil leak which cost 3k to repair.
I own a beater 2004 Mercury which never has had any problem with the AC over 12 years of constant use. The automotive industry as well as the residential and commercial HVAC industry have been switching from traditional copper tube/aluminum fin construction to all aluminum microchannel evaporator coils in an effort to combat formicary corrosion and produce cheaper coils. In the residential and commercial HVAC industry there has been a noticeable increase in leaking evaporator coils, a lot of them leaking at the point where the aluminum coil and tube transition to the copper pipe. Why Microchannel sucks: (Love his accent!) I myself just had my HVAC replaced with a new microchannel unit from Nordyne (NuTone). So far so good, I hope the early failures were just that and the industry has figured these things out. One thing with microchannel is that they don't hold much refrigerant due to the tiny channels. Therefore being 0.5 pounds low on refrigerant is a bigger deal than with a legacy system. |
07-16-2016, 12:20 PM | #22 |
Just Copacetic!
177
Rep 616
This guy is flipping hilarious to listen to! Made my day viewing this video
