10-17-2017, 12:05 PM | #1 |
Rep 59
Best lowering springs for my F30...please help...
Guys.....got a few ideas on lowering springs...currently on stock m suspension...need to get rid of rear wheel poke...any advice on lowering spring to use and drop required....thank you
E30 325i SE, E36 325i SE, E46 330 CI m sport, E46 M3
E90 318i m sport, F30 320d m sport, F10 535d m sport, F33 420d m sport. |
10-17-2017, 05:26 PM | #2 |
Rep 3,030
I?m not sure that you will be able to lower the car enough to resolve the poking. You may actually rub, you may need some kind of camber kit.
I had a set of 5 series rims on my F30 back in the day that poked like that. It was easier to get another set of rims with better offset.
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
10-30-2017, 10:09 AM | #3 |
Luke Wright
166
Rep 252
You can run up to -3 degrees of camber in the rear to fix the poke. I'm running around -1.9 now. Just take it in for an alignment and tell them you want -2 camber in the rear.
10-30-2017, 11:31 PM | #4 |
Rep 1,805
Dinan with comfort pads and shockware if you have adaptive suspension. I LOVE IT.
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
