11-09-2015, 02:01 PM | #23 |
Rep 1,436
I am in Egypt man, they will ship anything you want
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
11-09-2015, 02:57 PM | #24 |
BMW Fanatic
331
Rep 1,076
Drilled will end up lowering your brakes' efficiency. You need to get slotted disks.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
11-09-2015, 03:13 PM | #25 | |
Rep 369
Genuine question, I know jack shit about this subject |
11-10-2015, 06:47 AM | #26 | |
BMW Fanatic
331
Rep 1,076
1) Drilled disks offer less contact surface with the pad, which leads to less brake force. 2) Drilled disks tend to warp under heat and then end up with cracks (If you see any old condition Porsche, you will notice it) 3) In Formula 1 they use vented disks like ours because it has the most contact surface I guess. Another reason why people use drilled disks is: (Didn't think/know of this up until now) "Drilled rotors are commonly used in drifting because the brakes are hardly used so they don't see the drawbacks from other forms of racing but they reduce weight". Pictures of Drilled Disks Cracks: A video to help you out:
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 Last edited by 963mw; 11-10-2015 at 06:53 AM.. |
11-10-2015, 07:45 AM | #27 | ||
Rep 369
11-13-2015, 11:03 AM | #28 |
Rep 1,436
yea that's why i went slotted+Cryo treatment
02-23-2016, 07:27 AM | #29 |
Rep 123
Hi guys,
Just installed m perf brake kit, front with 370/rear 345 rotors. I cant edit HO-Wort, no options or unable to expand the folder. Any one can help? Current brake pedal very soft, needs to step in deep in order to brake.... |
02-23-2016, 10:05 AM | #30 | |
Rep 2,079
02-25-2016, 11:37 AM | #31 |
Rep 497
07-30-2016, 03:57 AM | #32 | |
Rep 107
Thanks for the How To. I also added the HO Wort but i didnt see a change compared to my old cafd. Can you please tell which parameters have changed after adding HO Wort. My DSC Modul looks like the old one without added the SPBR. Appreciate it. |
08-01-2016, 10:57 AM | #33 | |
Rep 817
Drives: bmw M3 F80
I tested the brake before adding the SPBR option and found the braking less effective as the original. the difference is just that there are better braking with the addition |
11-15-2016, 12:09 AM | #34 | |
Rep 101
12-19-2016, 11:52 AM | #35 |
Rep 943
Drives: 2012 328i Modern Line
Subscribed
12-21-2016, 10:50 AM | #36 | |
Rep 258
Drives: F30 320i (328i ECU) M-Sport
And the coding to Sport Brakes option is obligatory.
'13 F30 320i (328i ECU) RWD M-Sport
Michelin PSS, M-Sport brakes, 320i LCI muffler F32 bottom V-bar F80 bottom reinforcement plate Koni Sport, M-Performance springs, M135i Anti-roll bars |
01-08-2017, 01:18 AM | #37 |
Rep 109
Hello guys, I purchased the unpainted (silver) 4pot calipers from a 335i owner and planning to upgrade the front brake and rotors of the 428. Does this set up require coding?
2014 F10 M5 CP | Black Sapphire Metallic | Sakhire Orange Interior | 343M Wheels | Afe CF Air Scoop | Charcoal Filter Delete | AutoTecknic CF Steering Wheel Trim
02-27-2017, 09:08 AM | #39 |
Rep 855
The M Performance brakes have larger rear calipers and the only thing I can imagine coding doing is changing the values for the proportioning valve so that it will send more pressure to the rear and create more rear brake bias. Don't think you would want to do that with the standard rear calipers.
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
02-27-2017, 11:05 AM | #40 |
Rep 35
I did this to a 320in then also changed the rears to the bigger single piston setup from the 334I You don't need to code but as someone above said you can and might see a change in pedal feel I didn't code mine and was very happy with pedal feel anyway. I have since sold the car and returned it to stock I have the 335 rears available complete for $100 plus shipping if you if you can use them They fit x drive rears which used the larger parking brake drum
03-16-2019, 10:14 AM | #41 |
Not stock
475
Rep 614
Hey guys I am posting to this because I am a bit confused.
I am following the instructions, I can't "edit" under HO-WORT I can only do "New". When I do that, I get a text icon for SPBR that looks correct to me: But then I don't have calculate FA I have "calculate FP": And after this I have no idea how to "activate the FA" and "write to car". Any help? Is calculate FP correct? Sorry for being obtuse!
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
03-16-2019, 11:31 AM | #42 | |
Rep 40,919
Use this guide to Write FA to VCM, and VO Code DSC Module: E-Sys - VO Coding Guide.pdf: https://mega.nz/#!EgIFAZKb!H12P6g_2p...j4BT5UCMxck1bw
03-17-2019, 11:11 AM | #43 | |
Not stock
475
Rep 614
Read FA (VO). Activate FA (VO). I don't remember seeing the option to "activate" - I have to check though
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e Last edited by 5mall5nail5; 03-17-2019 at 11:16 AM.. |
03-17-2019, 02:18 PM | #44 |
Rep 40,919
You have to right-click on "FA" at top, and select Activate, else you cannot code anything.
