BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Touch buttons deteriorating
      12-28-2012, 04:24 PM   #23
howiegu
Member
howiegu's Avatar
Drives: 22%E2%80%99 M440
Originally Posted by Bmwphile
Originally Posted by howiegu View Post
That's odd...clip your nails often?-
Do YOU think my nails are too long??
You tell me
      12-29-2012, 04:08 AM   #24
live4wknds
Drives: 2012 328i
Originally Posted by Bmwphile View Post
As requested
Attachment 800873
Are those cracks on the surface of each button or are they occurring from the backside of each? Either way, it's not good. Hopefully it's not a huge deal to have them replaced at some point.
      12-29-2012, 12:34 PM   #25
chip2058
chip2058's Avatar
Drives: 2012 328i Sportline
I have this on my two and three buttons. The dealer said they won't replace it because it was caused by external forces. I think they're fucking assholes though :-)
      12-29-2012, 12:55 PM   #26
Bmwphile
Bmwphile's Avatar
149
Drives: 2020 G20 330i
The cracks are on the surface of each button
BMWphile
2020 G20 330iM Sport (Tanzanite Blue), Visibility, Comfort, HK
2012 F30 328i Sportline (Mineral Grey)
      12-29-2012, 04:23 PM   #27
JoeyO
Drives: silver car
I still say that's a crappy two-shot injection mold. What happened is simply the black plastic didn't fully fill the entire mold as it should have. It happens sometimes. It's a bad part. Maybe their pressure was off when running that batch.
IMO what some are calling a crack is actually two injected plastic flows that never met up and joined together fully. You wouldn't notice anything unusual at first but eventually as you wear away some top layer of the black plastic, you're noticing that the black plastic isn't as solid as it should have been. Where ever you don't have the black plastic, you have the clear plastic, so hence the light is shining through.
      12-29-2012, 04:50 PM   #28
BMWrules7
Drives: 2015, 740 LdX, Alpine White
Well, dealers will fix cosmetic things during the initial 36 months without too much push back.
In the meantime, to spread the wear, by putting the most used functions on different buttons. This might help a little until it is fixed.
      12-29-2012, 05:30 PM   #29
Kankles
Rear Admiral
Kankles's Avatar
Drives: Bavarian Milk Wagon
2019 BMW M2C  [0.00]
After you go #2 do you wash your hands? If not, the acids from your feces-infected manos could void the warranty and bmw may not replace the buttons.
      12-29-2012, 08:12 PM   #30
Bmwphile
Bmwphile's Avatar
149
I do and how would they know???
BMWphile
      12-29-2012, 08:21 PM   #31
JonoNZ
JonoNZ's Avatar
680
Drives: BMW iX M60, Macan Turbo
If that happens to mine they'll be replacing them. Luckily in NZ BMW dealers don't tend to argue the point -- one advantage of the high prices we pay here.
BMW iX M60, Storm Bay with XPEL Stealth PPF, Exterior Line Titan Bronze, 1EW 22" 1023 Wheels, Amido Leather, Comfort Package, Interior Camera, Clear&Bold, Sun Protection Glazing, B&W Diamond Sound, Folding Towbar, Rear Axle Steering.
      12-30-2012, 01:31 AM   #32
Bmwphile
Bmwphile's Avatar
149
Hopefully the same across the Tasman!!
BMWphile
      12-30-2012, 04:09 AM   #33
Kankles
Rear Admiral
Kankles's Avatar
2019 BMW M2C  [0.00]
German Shepherds of course
      12-30-2012, 04:50 AM   #34
F30AM
F30AM's Avatar
Drives: F30 330d M Sport sDrive
It's faulty injection mouldings, cheap plastic plus the buttons are too stiff to push which causes stress and strain.
I'll see how mine hold out once I've loaded them. In the meantime, cut your nails, wash your hands after your toilet festivities, wear cotton gloves like Japenese taxi drivers, only use the iDrive if concerned, be a bit more delicate but push gently but firmly and hope for the best or worst!
Present: Red Tornado Golf 7R 5 Dr, DSG + Toys
      12-30-2012, 04:11 PM   #35
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
Went out to stare at the buttons...without taking one off and cutting it in half I can't tell if it's a 2 shot molded keycap or a clear part that's been painted and laser etched (which is the most common process now for backlit keyboards on laptops since it requires no special tooling)
I didn't feel like breaking my car so I didn't pry one off to be sure...but it's hard to tell if it was just a flaw in the molding like Joey suggests or something causing the paint layer to seperate like chemicals or heat.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      12-30-2012, 08:19 PM   #36
Bmwphile
Bmwphile's Avatar
149
Maybe its just the touchkeys which are faulty. Because I use the sports /comfort/ eco pro mode button and the start button more frequently with no signs of deterioration. So it can't be the way I am using the buttons or anything peculiar to my skin or natural oils. Unless these buttons are made in a different manufacturing process.
BMWphile
      03-17-2013, 02:52 PM   #37
chip2058
chip2058's Avatar
Did anyone who had this problem successfully get them replaced under warranty?
      09-05-2013, 04:52 AM   #38
Kapitein Iglo
Drives: F31
Noticed this appeared on my "1" button, starting last week.
Car is only 5 months with 15000km on it.
      09-05-2013, 01:11 PM   #39
rs277
rs277's Avatar
Drives: 2014 M235i / 2012 F30 328i
Hi, new to the forums here just got used 2012 F30 328i about a mouth ago and just notice this issue myself. Out of the 8 pre-set buttons 6 of mine are affected, going to the dealer this weekend since they want to look at it before giving me an answer about fixing the issue. Will update once I talk to them.
      09-05-2013, 01:37 PM   #40
BDWonder
Drives: 2016 M5
As requested
Attachment 800873
ohhhh duuuudeeee!!! sorry man!!
      09-05-2013, 02:27 PM   #41
Flakmunky
Amateur Brain Surgeon & Olympic Knitting Champion
Drives: E85, E92, F31, G31
Originally Posted by rs277 View Post
Black Ops.......
      09-05-2013, 04:05 PM   #42
christiaan328
Drives: Sold: F31 328i M-sport
It's happening to my 7 month old car too.
      09-26-2013, 04:04 PM   #43
rs277
rs277's Avatar
Sorry about the delay on this update I had a death in the family.
So took the car in twice for this issue, 1st time SA stated that the service manager had to ok the fix due to cost ( after waiting two hrs in the lobby I was told to come back tmw ). Being upset about wasting a day at the dealer I called BMW NA and voiced my frustration. BMW NA stated they would contact the dealer about having the issue address.
Came back to have Service manager look at the issue and he spent a min. looking at it before giving the ok to have it fix.
      09-26-2013, 04:11 PM   #44
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25084
Drives: '22 Chalk Gray Porsche C2S
I use driving gloves, soooo...nope! Interior stays hand oil free.
