BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > The F30 has its limits
      10-12-2012, 12:30 PM   #23
RobUK
RobUK's Avatar
Drives: 340i MPPSK
+1 for LED indicators
PS - assume they're holding these back for the mid-life refresh/coupe/whatever... and no doubt they will NOT be a plug & play option for the earlier F30's. Cynical? Moi?
Life is a state of mind
      10-12-2012, 01:05 PM   #24
elistan
Drives: F30 328i, AP1 S2000
I would like:
- Track/channel advance button on the steering wheel, which I make use of all the time, rather than MODE which I hadly ever use.
- A power/ignition/engine status control like the lights control on the left.
- Do not automatically engage Park, ever, unless I specifically initiate the command.
- Torsen LSD.
- Customizable EPS assist levels.
Originally Posted by TheObviousChild View Post
Is that the official name of the thing that keeps you from rolling back for 3 seconds when on an incline?
No, you're thinking of "Drive-off assistant" on page 108 of the owners manual. The clutch delay valve is a bit of hardware in the clutch system (slave cylinder to be specific) that restricts the flow rate of clutch fluid during engagement. This is to lessen the shock to the drivetrain during quick shifts. It has the downside of producing a less responsive, clutch-slip-like driving experience.
      10-12-2012, 01:28 PM   #25
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
LED taillamps. dont really care about LED turn signals
      10-12-2012, 02:57 PM   #26
r3dbimmer89
r3dbimmer89's Avatar
331
Drives: P-Car
Led tail lamps/front signals, better steering feel, a real LSD (that's not going to happen), etc.
Past: BMW (22 G20 M340i, 15 F80 ///M3, 12 E92 335i, 08 E90 335i, 02 E46 325i)
Mercedes-Benz, Porsche, VW, Lexus
Present: 24 992 C2
      10-12-2012, 03:03 PM   #27
Robin_NL
S0THPAW
Robin_NL's Avatar
8716
Drives: HS M2 Competition
Originally Posted by johnbmw6 View Post
the wind noise has been solved with changes to trim and door seals.
So I have to go to my dealer asap to get the modifications?
Do you have more info on this please?
Cheers
Robin
      10-12-2012, 03:06 PM   #28
Robin_NL
S0THPAW
Robin_NL's Avatar
8716
No, it's when you accellerate fast and shift from 1st -2nd and there is some hesitation in engaging the clutch(it's a nanosecond, but it feels like ages). This is for-I've been told- less experienced MT drivers to keep some comfort in switching gears.
Cheers
Robin
      10-12-2012, 03:13 PM   #29
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Originally Posted by Robin_NL View Post
Less windnoise from windscreen/A pillar. Better(less noisy) RFT tyres, faster working satnav/iDrive at startup, better working comfort access plus trunk/boot. Better (more clear)reception of radiostations. Getting rid of the CDV(clutch delay valve) in the 6MT cars. About 50HP and 50Nm more plus a real mechanical LSD as standard please.
And that's about it.
Cheers
Robin
There must be some early issues with the F30.
I had no (real) issues with the nosiy RFT (changed to non-RFT now though), I don't feel that the wind noise from the A-pillars are a problem. The only issue I have with the CA is that it is more difficult to make it work when it rains
      10-13-2012, 12:29 AM   #30
loosenit2
loosenit2's Avatar
Drives: 12 328i Luxury
Originally Posted by tz235
The F30 is a great car. But what would you change to make it better?
LCI listen up!
More software configuration options. A lot of talk on forums about ASS remember las mode, side windows automatically folding in etc. based on my experience I agree with those suggestions, would really like to have more options for configuration of those types of functions.
Also, with the proliferation of touch screen devices it would be nice to see the iDrive system as touch screen.
      10-13-2012, 01:36 AM   #31
JOHNBMWM5
JOHNBMWM5's Avatar
Drives: 2022 LCI Marina Bay Blue/ Smok
Cheers
Robin
There is a "FIX" from BMW, it can be the Trim around the wind screen ( it's the gap between trim and door pillar) this is changed out.
The other "FIX" is door seals being replaced, now if your dealer will NOT do this after you take them out and show that the noise is unacceptable complain to BMW and take it to another dealer to fix it. They do know about it.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      10-13-2012, 03:11 AM   #32
Robin_NL
S0THPAW
Robin_NL's Avatar
8716
Aha thanks mate. I'll do that this monday. I'm good with my dealer (9 BMWs so far...) so I don't see any complications.
Cheers
Robin
      10-13-2012, 03:26 AM   #33
jsedlak
jsedlak's Avatar
Drives: F30 335i 6spd
No.
http://en.wikipedia.org/wiki/Clutch_delay_valve
Btw, you can do a CDV delete mod, usually. I've done it on my E46, and honestly I don't think it's much better.
      10-13-2012, 10:57 AM   #34
BravoX
BravoX's Avatar
Drives: 328i Sport Line
Better brakes
_______________________________________
2012 BMW 328i Sport Line, Jet Black (Sept '12)
2008 Mitsubishi Evo X, GSR Graphite Gray (traded-in)
      10-13-2012, 11:05 AM   #35
mocohead
mocohead's Avatar
54
Drives: '16 M235i 6MT & 12 128i Msport
Better brake pads on US cars
A light inside the trunk
Ability to adjust delay before ASS shuts the car off
Ability to adjust steering weight via idrive
LSD
      10-13-2012, 11:05 AM   #36
asus389
asus389's Avatar
Drives: 11 E90 328i
2011 BMW 328i  [0.00]
Do something with the front end to make it look better.
Maybe close the gap between the lights and the kidney grille more like the F10?
      10-13-2012, 11:45 AM   #37
motorsport_cat
motorsport_cat's Avatar
Drives: 1995 740iL
1995 BMW 740iL  [0.00]
Cheers
Robin
What is LSD?
///Meow
      10-13-2012, 12:00 PM   #38
SomeRandomer123
SomeRandomer123's Avatar
England
303
Cheers
Robin
What is LSD?
Whatever you want it to be.
For us, it's a Limited Slip Differential.
For you, it may be a drug...
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
      10-13-2012, 01:21 PM   #39
bmrm396
Drives: 2018 F80 M3cs
Originally Posted by sean10mm View Post
Factory installed M Sport brake option in the US of A.
Proper limited slip diff.
Short throw shifter option on 6MT.
Abandon the "lines" and remove arbitrary restrictions on optioning.
THIS!!! pleaaaaase oh please
Formerly addicted to e90post
      10-13-2012, 02:05 PM   #40
JOHNBMWM5
JOHNBMWM5's Avatar
Originally Posted by bmw8 View Post
What is LSD?
It's a great drug you can buy on any street corner.
      10-13-2012, 02:31 PM   #41
tuned2ride
Drives: E90, S5 SB, looking for a M340
*Zero* interest in a 4 cyl.
For cheaper than a 335i, I want a NA DI 6-cyl. 3.0L 270HP.
      10-14-2012, 03:23 PM   #42
fshubert
fshubert's Avatar
89
Drives: 2015 F30 335i
Cheers
Robin
The clutch delay valve needs to be removed. I hate that, auto start/stop and hill assist (the brake holding the car on a hill until I let the cluch out). It all can be reprogrammed (will do this when I do the powerkit).
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi
      10-15-2012, 01:32 PM   #43
Elk
Drives: 2012 335i
The F30 does not appear to have a CDV. There is no separate unit in the clutch line as in previous models.
Regardless, the MT continues to be a bit vague, both clutch and transmission, as with other BMWs.
      10-15-2012, 01:40 PM   #44
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Originally Posted by elistan View Post
I would like:
my Msport wheel has a thumb wheel that displays and changes the tracks on the BC screen when i scroll it.
Also why is the volume controls on the right side since near the radio itself. Why not on my left hand ..
M Sport Line Estoril Blue
