05-04-2020, 11:20 PM | #1 |
Rep 3
440i GC steering wheel off-center
I apologize if this is a basic question, but I am new to owning a BMW (used to drive VW) and just want to ask some experts.
I am wondering if it is normal for the steering wheel of a 440i GC to be slightly to the left when driving straight. I have had the wheels aligned 3 times within the last couple of months by different mechanics. None of them seem to think the wheel is really off-center and that the alignment is perfectly fine. Am I just too picky about the position of the wheel or does it sound like something is wrong? |
05-05-2020, 04:04 AM | #2 | |
Rep 15,858
When you say "perfectly fine", is that from the printout, and/or when actually driving? No steering pull, no drift when driving straight on a flat surface? If everything is fine, just the steering wheel slightly off, you can adjust the center position with a tweak to the track rod ends, a "one in, one out" adjustment, by turning identical amounts. Something like a quarter of a turn may be required. This tweak (done correctly) does not change the geometry, simply adjusts the steering wheel 'center' position. In fact it gives more precision to the SAS (rack mounted steering angle sensor), aligns correctly with the zero position. |
05-05-2020, 06:09 AM | #3 |
poopycat
266
Rep 791
Raise and lower the steering wheel, go drive. You'll be surprised. Well documented on your VW, too.
Doesn't hurt to check tire pressure, too. But you have had alignments. They should center the wheel, and go from there. |
05-05-2020, 11:17 AM | #5 | |
Rep 88
Brought mine back to the alignment place, the guy did a quick adjustment to the tie rod (x amount of turn on one side, x amount on the opposite side). Dead center now. Try to test it in flat surface (parking lot, etc.) so you know it's the crown/imperfection, or the steering wheel. |
05-05-2020, 11:42 AM | #6 |
Rep 3,748
I think it's how you sit on during driving. Is your head tilted... just asking
One way to check your steering wheel is to check it with the dashboard. The speedo and tach should alight with the steering wheel... this if the alignment is good. |
05-05-2020, 11:49 AM | #7 | |
poopycat
266
Rep 791
Seriously, move the wheel up and down and drive. Enlightenment. |
05-05-2020, 12:01 PM | #8 | |
Rep 3,748
I got the same issue as the OP but it is really straight... my cousin, my brother, my friend said so....but it look like 1 degree off to the left...my eyes, my neck, and my head is playing tricks on me |
05-05-2020, 12:14 PM | #9 | |
poopycat
266
Rep 791
Adjust that wheel up and all should be fine. |
05-05-2020, 06:02 PM | #10 | ||
Rep 120
05-05-2020, 08:05 PM | #11 | |
Rep 10,473
05-07-2020, 05:49 PM | #12 | |
Rep 15,858
We need to eliminate any pull issue, (whatever the cause) or camber sensitivity, before making a stand alone steering wheel 'center' adjustment. |
05-07-2020, 06:28 PM | #13 | ||
Rep 10,473
Replaced front tires as the right front developed a bubble and then hole in sidewall. Shockingly, before I even got an alignment, no pull whatsoever. |
05-07-2020, 06:44 PM | #14 |
Rep 3,748
I read that OP original post again... I don't think he said the car is pulling to the left like it is an alignment issue. He said the steering wheel is off a little to the left and the car is driving straight.
That's why I commented that his position like is head, body to the center of the seat and steering wheel. It's just your eye playing trick on him |
05-07-2020, 07:13 PM | #15 | |
poopycat
266
Rep 791
Easy check on the steering wheel adjustment, again, common on these german cars for some reason. Maybe even US cars, but I really haven't dabbled there. |
05-07-2020, 09:24 PM | #16 | |
Rep 10,473
And fwiw, BMW Dealership said it was an alignment issue during a Fall Tune Up event. |
alignment, road crown, steering pull, steering wheel |
