BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > If getting a clear film/bra and a front lip...what is the best way to install
Studio RSR
      03-31-2015, 11:52 AM   #1
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
So I have decided to get a xpel film and also a MP CF front lip for my gc...question here is: Do I install the film to the bumper first and then put on the lip or put on the lip first and have the installer cover the bumper + lip all together?
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      03-31-2015, 01:50 PM   #2
s2k750
Drives: 2015 M3
I would do it separately. If the lip gets damaged you'll be able to replace that easily. Otherwise once it removed the bumper will most likely need to be redone.
      03-31-2015, 05:20 PM   #3
Dippydo
Drives: 2023 M8 Comp
2012 BMW  [1.00]
I would put the lip on then get the clear bra installed. This way they protect up to the lip. I would not recommend putting the lip on top of the clear bra because this lip will get damaged over time and you may want to replace it. If you need to pull the lip off it will damage the clear bra and have to redo the bumper. Since you are going CF, I would strongly recommend putting the clear bra on that as well because all the CF lips I have seen are chipped up pretty bad since they are so close to the ground and are sprayed with sand and pebbles. Just look how pitted a windshield or your headlights get over time.
      03-31-2015, 08:00 PM   #4
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Good point
2006 325xi (Sold)
      04-01-2015, 04:54 PM   #5
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Oh snap..didnt know xpel is on this forum
Thanks for the tips
2006 325xi (Sold)
      04-02-2015, 09:38 AM   #6
Dippydo
2012 BMW  [1.00]
Originally Posted by Xpel View Post
We recommend having the film installed on the bumper, then attaching the lip to the bumper and then installing film on the lip while it's mounted to the bumper. Especially if it's carbon fiber. As someone else mentioned, those look amazing but are also easy to scratch or even shatter.
You recommend attaching the lip on top of the clear bra? Wouldn't it pull off if you had to replace the lip? Or in my case I pull my lip off for winter to avoid damage to the lip and bumper.
