12-01-2017, 07:42 AM | #1 |
Rep 21
clutch going bad?
Whats up guys,
I have been under the assumption that I had a turbo leak or pressure leaving the engine some how. I came to this conclusion because when I am in say 3rd or 4th gear, especially going uphill, and gas the car (say to speed up past someone) ill lose power while my RPM's shoot up and then the car will seem to regain power and then continue to accelerate, although with seemingly less power than it should have. I ordered a new ER charge pipe on black friday and will be replacing the stock this weekend as I've read this is bound to bust sooner or later. If this does not fix the problem how high is the probability its my clutch? I am on the verge of buying extended warranty so I can worry less about bigger problems like a clutch going but still do not know if it is worth extending the warranty. Thanks for your time guys |
12-01-2017, 02:37 PM | #2 |
Rep 5,369
RPMs shooting up while loosing power and in taller, high load gears like 4th and higher is a strong indicator of a failing clutch. How many miles and mods on the car?
Also, it's VERY unlikely that an extended warranty will cover a wear item like a clutch, pressure plate, and dual mass flywheel. I'd be prepared to have $2,500 ready to replace these components. |
BimmShady4352.00 |
12-04-2017, 09:29 AM | #3 |
Rep 21
59k miles, BMS CAI, BMS JB4 (plug n play)... i took out my tune which I'm gonna sell. Problem seems to be not as apparent as before when the tune was plugged in. Slowly gets worse tho as i push the car.
Going to install ER charge pipe tomorrow @home and look around for loose seals, cracks etc. Will update with results! |
12-05-2017, 09:40 AM | #4 |
Rep 351
it's definitely your clutch. installing a charge pipe isn't going to fix the problem. your clutch is slipping. have you owned the car since new? 59k miles is really early for a clutch to go out.
2013 335i M-Sport 6MT, MPE, VRSF CP and IC, BM3 Stage 1
2006 330i 6MT, Sport Package - sold |
12-06-2017, 10:06 AM | #5 |
Rep 1,782
Yeah that's the clutch. Tune has not much to do with it although it's not helping anything. I have had similar issues and I can tell you that for the most part extended warranty will not cover a clutch.
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
12-06-2017, 11:38 AM | #6 |
Rep 1,499
But BMW Ultimate Care+ does
amw896582.50 |
12-06-2017, 11:39 AM | #7 | |
Rep 1,782
12-06-2017, 12:27 PM | #8 |
Rep 1,499
It's the maintenance package. I bought my car CPO so got the +2 yr, +50,000 mile extended warranty and the +2yr, +50,000 mile maintenance plan. covers all the scheduled maintenance plus some wear items like brake pads/rotors and clutch.
https://bmwusaservice.com/ultimatecare
12-06-2017, 01:43 PM | #9 | |
Rep 1,782
12-06-2017, 03:22 PM | #10 |
Rep 351
the tune definitely exacerbates the problem. the more power he makes the more likely it is for his bad clutch to slip.
12-08-2017, 10:44 AM | #11 | |
Rep 1,782
12-08-2017, 04:02 PM | #12 | |
Rep 351
12-08-2017, 05:03 PM | #13 | ||
Rep 1,782
