06-18-2018, 04:09 PM | #1 |
Rep 86
Help with front bumper fitment!
Does anybody happen to know if i can install the 435 M-Sport front bumper straight off a M-Sport 435 onto my sport line 435 for direct replacement of my current front bumper? Or will i have to buy a front bumper designed for the sport line that has the M-sport look? Please and thank you
06-18-2018, 05:30 PM | #2 | |
Rep 10,473
However, you will need about $1000 of additional parts to replace the Sportline parts behind the Retrofitted MSports Bumper that will not work with the new MSports Bumper. Use this link from a 3 series as an idea of SOME of the various parts needed. http://f30.bimmerpost.com/forums/sho....php?t=1456769 Also, read PDFs here http://f30.bimmerpost.com/forums/sho...d.php?t=930959 Last edited by IK6SPEED; 06-18-2018 at 05:40 PM.. |
sweatyyeddie11.00 |
06-19-2018, 01:55 AM | #3 |
Rep 2,499
I think the answer you're looking for is no. There are various other components required to fit it properly, not just the bumper cover. But like IK6SPEED said, you just have to buy those supporting components and install them on your car.
If you buy one of those aftermarket kits, they come with everything you need. |
sweatyyeddie11.00 BrettKA7566.50 |
06-22-2018, 09:25 PM | #5 |
Rep 776
I'm completely happy with the fit and finish of the aftermarket Selma/GoodGo bumper I have, but I'd recommend buying an OEM foam support (Selma has poor fitment IME), OEM carrier behind the bumper (to avoid the "base" bumper support horizontally placed in the middle of the opening on M Sport bumper) and OEM intakes/vents on either side of the lower grille as mine fail to latch closed and the two halves of each vent open up when applying pressure during a hand wash.
The bumper cover itself and the fog light surrounds look OEM, as do the headlamp washer covers. My only concerns are all related to the lower air intake opening.
M240i | Mineral White | Coral Red
upsidedownfunnel1996.00 |
06-22-2018, 11:53 PM | #6 | |
Rep 2,499
06-23-2018, 12:40 AM | #7 | ||
Rep 776
I circled where you will see a black plastic bar from the base bumper through the grille on the aftermarket M Sport bumper. I also attached a photo of the totally open radiator on the OEM M Sport front end. To my knowledge, you must remove the front bumper beam to swap this plastic piece out. I forget it is there unless I look for it, but YMMV. The bumper cover is bolted below the hood, along the fenders, and under the bumper cover, so I don't expect it to sag. My body shop deals 95% with Aston Martin, Jaguar, Land Rover, and Tesla, and they said they have never seen any aftermarket bumper near this quality. It was not as simple and straightforward an install as the bumper that originally came with the vehicle, however.
