06-03-2010, 02:43 AM | #1 |
Rep 82
wheel rotating noise after 19" rims upgrade
Just swapped out my 18" rims and RFTs for 313 rims with PS2 tires. It looks great on my Alpine white E89. However, I am hearing more tire noises from the rear. It sounds like a rotating blade (whurr, whurr, whurr) especially more obvious at 70-100km/hr on a straight road. Also, when I release the accelerator, the sound is more distinct. Note that this is when the top is up. The sound went away when I drop the top (maybe because of other road noises that drown it out).
It may not be harmful but just so annoying. Checked on the wheel bearings. All is in order. Balanced and rotated the tires. Noise still there. Anyone encountered this? |
06-03-2010, 07:28 AM | #3 |
Rep 82
Yes. I moved from 225/40 R18 front and 18x8.5, 255/35 R18 rear
to 235/35/R19 front and 265/30/R19 rear. This is the BMW Z4 specs for 19" so I don't think that the tires are rubbing the wheel hub/wall. Also i hear that noise between 70-100km/hr. If they do rub, wouldn't it produce the same noise the moment you drive? |
06-03-2010, 11:54 AM | #4 |
Rep 1,026
If there is no wheel rub, the offset is in spec (you didn't mention the offset above) and they are all balanced, I don't have a clue.
Did you perform a dynamic wheel balance? I've experienced a wheel shudder/vibration around 60-70mph before, had the wheels re-balanced (Hunter balancing unit I believe) and the noise went away. There was no shudder/vibration at the lower speeds. Sorry I couldn't help you more. |
06-19-2010, 08:31 AM | #5 |
Rep 805
Drives: 2011 Z4 35is Melbourne Red
Try re-installing your stock wheels/tires and see if the sound goes away.
06-19-2010, 11:13 AM | #6 |
Bootleggin' 'n Gunrunnin'
137
Rep 2,372
I've done a little digging, and I think this may be your problem:
18" Z4 E89 wheel specs: Front: 8x18 ET 29 Rear: 8.5x18 ET 40 From here: Post by Ramius 19" Style 313's have specs: Front: 8x19 ET 37 Rear: 9x19 ET 39 From here: For Sale post from United BMW If we plug those specs into our handy calculator, you get: Front: 8mm less clearance on the strut side. Your tire is also 10mm wider, or 5mm wider on each side. That may cut your strut clearance by 13mm from stock. You might be rubbing in the front. Rear: 15mm less clearance on the inside! And your tire is also taller by 1/4" and 10mm wider overall (5mm per side). So that cuts your potential clearance on the inside down by 20mm. You might not have that much room to give, especially when going up to a larger wheel and tire diameter. I'd take off your wheels and inspect the inside edges for any wear. You may want to chalk the tire and wheels and then drive around some and see if it wears off.
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
06-19-2010, 11:05 PM | #7 | |
Rep 82
06-20-2010, 12:07 AM | #8 | |
Rep 1,838
those are the specs for the 3 series 313's, the Z's 313 are designed specifically for the Z. solidgold, my first reaction would be to have them rebalanced, if that doesn't fix it you might have a bent rim or bubble on tire, the last and worst case scenario, you have a bad wheel bearing.
06-20-2010, 12:29 AM | #9 | |
137
Rep 2,372
Far less technical data available over here for you new Z4 guys, unlike us E9X guys who have had a few years to compile the details....
Scott
06-21-2010, 01:32 AM | #10 | |
Rep 82
Part no : Front alloy wheels: 19x8" ET29 Wheel part number: BMW 36116787655 Rear alloy wheels: 19x9" ET40 Wheel part number: BMW 36116787656 |
06-22-2010, 09:04 PM | #12 | |
Happy Camper
612
Rep 7,869
Drives: C63 AMG & 280 SL on Weekends :
Garage List 1969 Restored Merce ... [7.50]
2011 M3 Coupe TRADED [7.34] 1987 BMW 535is [1.00] Cars from the Past [6.50] The ///M3 Engine S65 [9.59] |
Cheers, Rolf-Dieter
Life will take us to some interesting places, fortunately The ///M3 will too with a many of us know this very well, now my C6.3 AMG with 487 HP does it too ---> Click here for some good stuff I found |
07-07-2010, 05:45 AM | #14 |
Rep 82
Just swap out my 19" wheels and got 4 17" wheels to test. Drove for 5-6km between 40-90km/hr and noticed that the rotating sound is not present. Although I can still hear tire noise, it is mild and does not replicate what I hear on the 19". The 17" belongs to a 3-series with multiple complex spokes unlike the 313s I have. So it could also be the big blades on the 313s taking in more air flow as you drive. But at least it confirms that other parts of the car - camber, wheel bearings, etc do not have problems.
