03-27-2023, 11:21 PM | #23 |
Rep 10
Steering rack post surgery....
Hi,
I am looking at replacing the steering rack of My 2014 BMW 328i F30. My question is, once the rack is replaced by a doner rack, is it driveable? Does the power steering work straight away? I would need to then drive it to the BMW garage to get programmed / coded (waiting on them to confirm if they will do this if I do the work myself). Thanks Lawrence |
03-28-2023, 12:22 AM | #24 | |
Rep 43
I carefully adjusted the tie rod length as same as my original eps. But the steering wheel is still off the center, by a lot! There is no way to skip a wheel alignment and do a steering recalibration in ISTA after the replacement. |
03-28-2023, 07:47 AM | #25 | |
Rep 2,047
You can do this by yourself using esys and ISTA |
03-29-2023, 12:26 AM | #26 | |
Rep 10
03-29-2023, 12:32 AM | #27 |
Rep 10
Thanks so much for your reply, is there a guide on how to programme for this specific replacement? Just wondering how difficult it is, will watch a few youtube videos....
03-29-2023, 12:59 AM | #28 |
Rep 2,047
For coding.
Connect => Read FA (VO) => Activate FA (VO) => Read (ECU) => Left click on EPS => Click on "Detect CAF for SWE" => Select the CAFD of the last displayed I-Level (the bottom one) => Select OK => Right click on EPS(the ECU itself, not the underlying CAFD) => Select CODE. For eps calibration ISTA service function. Powertrain > EPS / steering > calibration/ startup Last edited by TheNine90; 03-29-2023 at 01:11 AM.. |
03-29-2023, 10:26 AM | #29 |
Rep 43
03-29-2023, 06:28 PM | #30 | |
Rep 10
01-05-2024, 09:43 PM | #32 |
Rep 7
Once again sorry to revive a dead thread but can anyone help me with coding? I bought a used rack and switched the eps over to my car and I need it to be coded to my vehicle and I’m hoping that this will be the solution to my issue
01-05-2024, 09:59 PM | #33 |
Rep 2,047
02-14-2024, 10:29 AM | #36 |
Rep 2
Eps unit failure
The eps unit has failed in my f32 and have failed in locating a used one… is there anyone that can replace / rebuild the eps unit in the rack I currently have ? Tia
