08-13-2020, 10:59 PM | #1 |
Rep 5
Xenon retrofit coding issue pls help
2013 328i I retrofitted amazon headlights and Xenon kit. When I start the car in night with lights on auto and it cranks up, The xenons begin to flicker due the power being supplied being unstable. This causes them to shut off. I am able to get the lights to turn back on by switching the dial to 0 and then back on again. If I start the car in 0 and turn lights on after it is started it works fine. Is this a problem with my Xenon? the ballast? or is there any coding I can do so the lights wont turn on while the engine starts or xenon specific coding in bimmercode. I currently have monitoring off and bulb set to Halogen. Thank You
08-15-2020, 01:11 PM | #2 |
¯\_(ツ)_/¯
947
Rep 1,762
Yes, you need to code the car for xenon lights. The resistance is different compared to halogen so the car is failing the cold/hot checks. If coding doesn't work it can be due to cheap quality ballasts which will need replacement with better ones (Morimoto, Phillips, etc) and possibly capacitors.
08-15-2020, 01:30 PM | #3 |
Rep 16,106
He said he coded the warm/cold checks off. The problem is probably the high initial current draw of the HID, which is considerably higher than the stock H7 halogen, especially if the bulbs are 55w. A time delay relay would be worth looking into.
Solidjake947.00 |
08-15-2020, 01:50 PM | #4 |
Rep 5
Here is a video of the problem
https://drive.google.com/file/d/1LAF...ew?usp=sharing I bought the headlights and ballast second hand from a guy who had to return his car, I am not sure how many watts the bulbs are or what the quality is. About 1 time out of 10 on the right side I do not have the issue and the lights work fine. I have monitoring off and bulb type set to halogen. Do you think buying a different ballast/bulb would work or is there anything I could code? Thanks for the help |
08-15-2020, 02:17 PM | #5 |
Rep 16,106
There's nothing to code for HID. LED must be coded because they don't work the same as H7 halogens, which are incandescent. HID is also incandescent.
coding, halogen, halogen to xenon, headlight, help me pls, xenon |
