BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > M4 carbon fiber strut brace and other stiffening parts on F32 4 series !!
      02-05-2018, 12:30 PM   #199
dja82
Drives: 330d Xdrive F31
F31 330d install
Hi has anyone tried this on a 2014 F31 330d xdrive, is it worth it? or should I just get a normal strut brace, I have seen the back alloy strut going for reasonable prices but not the CFBR yet so may just try that for now if not too difficult
I have ordered Bilstein b14s so may be a good time to do this mod when they are being fitted?
Thanks in advance for any help
Darren
      02-13-2018, 02:26 PM   #200
zipphreak
Drives: m235xi
Finally completed all the work for the strut brace retrofit on my M235. It was a little bit of a project. Some major plastic trimming on the left and right plastic covers, along with the fender trim pieces. I drilled one hole on each side for those strut extension rods into the body and used an M10 rivnut. Similar to the large torx bolt in the fender, except the hole is already there for that one. You just have to rivnut it into place with the tool. Ground control camber plates for my 235 were retrofitted for the M4 studs. They use the same plate for the 2/3/4 series and M2/3/4. So it worked out.
Lancelot567.50
      02-16-2018, 03:50 PM   #201
Lancelot
France
568
Drives: 2017 m550i
So we finally fitted my strut hat adapters, all looks fine now, i couldn't fit these at home myself.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
      02-19-2018, 07:29 AM   #202
zipphreak
Drives: m235xi
Too bad you didn't live closer, I would've helped you out fitting them
Wait for my update on the stage 3b alternative, I'm fitting the M2 front strut braces instead of the expensive Carbon Fiber piece. I got all the parts, and I've started mocking up the fitment. It requires a pair of brackets for each side that I'm going to use 3m structural adhesive to bond to the frame.
      02-20-2018, 07:45 AM   #203
zipphreak
Drives: m235xi
Here's my semi-finished phase 3b. M2 forward strut tower braces installed
This would be an alternative to the Carbon Fiber Strut Brace.. Cost about $180 USD
      02-22-2018, 12:17 PM   #204
dotjonnL
Drives: 335iX M-Performance
Originally Posted by zipphreak View Post
Here's my semi-finished phase 3b. Strut tower brackets installed.
Your car came with provisions on the strut towers to bolt up the corner braces? I wonder if that's the same on the F30
      02-22-2018, 04:05 PM   #205
alex2018
Drives: Bmw 420 f36
Nice mods, congratulations everybody!
I have a F36 2015 Sport line and thinking about getting them done.
What was the difficulty if I can ask?
I live in France region, is it possible to help me getting these struts hat adapters? Are the ones that you designed earlier?
Geometry has to be redone after the mods, right?
Thanks a lot
      02-22-2018, 04:26 PM   #206
zipphreak
Drives: m235xi
Negative you have to buy two sets of brackets and either glue them or weld them. I used 3m panel adhesive.
https://www.amazon.com/3M-08115-Pane.../dp/B000PEW4MI
Don't forget you still need the tool and nozzles
So I bought this kit and it worked perfectly.
https://www.amazon.com/3M-08115-Adhe...6ZJZEGANRC707G
      02-22-2018, 04:28 PM   #207
zipphreak
Drives: m235xi
If you have never done suspension work it's best to ask for help or find an Indy shop to do the work.
      02-22-2018, 07:52 PM   #208
dotjonnL
Do you have the part numbers?
Thanks in advance
      02-22-2018, 08:24 PM   #209
IK6SPEED
Drives: BMW M3 / AH3
I’m having trouble seeing how these 2 side braces (if you can even call them that as flimsy as they are) can add much to this design
      02-22-2018, 08:37 PM   #210
zipphreak
Drives: m235xi
I didn't say IK6SPEED had to do it did I? And how do you even know they are "that flimsy" as your noting. They serve the purpose of providing additional bracing towards the front of the strut tower.
The m4 uses a Carbon fiber brace in a similar position, and bolts to the crosslink in the same holes. The M2 uses the stock F22 strut brace along with these side braces.... You don't have to do it I took the M4 strut brace and instead of the CF piece, I used the M2 pieces. Does the same deal. Less $$$ I am posting here for people to have as an alternative to spending 1200 on a piece of CF. Doesn't look as flashy but my hood is closed 99% of the time.
dotjonnL
Part #'s
Quantity 2: 41007346815 (side bracket L/R)
41007346817 (strut tower bracket left)
41007346818 (strut tower bracket right)
51647301929 (strut brace left)
51647301930 (strut brace right)
Quantity 6: 22326760945 (metric hex bolts)
51647294928 (front crosslink)
Quantity 2: 07149229516 (metric hex bolts)
DLag30103.50
      02-22-2018, 08:43 PM   #211
alex2018
Drives: Bmw 420 f36
Could this adhesive be used to attach the 2 additional A pillar mounts for the strut bar? what is the type btw?
Did you guys think about a rear strut bar? Would it make a noticeable difference in driving feel?
      02-22-2018, 08:47 PM   #212
zipphreak
Drives: m235xi
alex2018 The M4 A pillar mounts don't work. They add to the stack height and interfere with the hood closing mechanism, IE. your hood won't close There's a very simple solution to mounting the strut rods.. They line up perfectly to the A pillar, mark it, drill incrementally w/ a step bit, and then install a 10mm rivnut with a rivnut tool... Nice large 10mm bolts right to the frame That's what I did and it is perfectly solid. Remember every chassis is different, so this works for the F22. Can't say it works for all chassis' though, YMMV.
      02-23-2018, 12:53 PM   #213
dotjonnL
dotjonnL
Part #'s
Is the 3M panel bond strong enough to take any flex?
      02-23-2018, 01:00 PM   #214
zipphreak
Drives: m235xi
dotjonnL This is new territory, not something many people have done. I'll let you know towards the end of year.. After all my track days
If your concerned, you can always weld it Since it's not primarily a vital structural component, I chose this route. If it fails, I'll weld it.
      02-25-2018, 07:32 AM   #215
zipphreak
Drives: m235xi
I wanted to share this with you guys. I made some brackets for the left/right trim covers, since you have to cut off the OEM tabs to fit the M4 strut brace.
I used some ABS plastic sheet from Amazon, placed piece of paper on the strut brace, traced the edges/pop-rivet hole with a pencil, transferred the lines to the ABS sheet. But I only used a razor blade/exacto knife to cut it out, and dremel would've been quicker/easier/more elegant Soo I lost some blood on this project. Good Luck
      02-27-2018, 01:50 PM   #216
zipphreak
Drives: m235xi
For phase3b, where the strut tower brackets are bolted to the new braces. I swapped the two 3/8 washers i was using with an aluminum spacer. They are needed because the bolts are not fully threaded, so it just takes up that space.
https://www.mcmaster.com/
part #92510A491. One for each side.
      06-15-2018, 12:05 PM   #217
FloorThe4
Drives: 435i xdrive m-sport
I have a CF brace for sale if anyone is undertaking this project.
http://f30.bimmerpost.com/forums/sho....php?t=1506538
      06-22-2018, 02:30 PM   #218
Speedwell-Industries
Speedwell-Industries's Avatar
Drives: 2017 YMB M3
Looks great! Time to add Carbon engine cover and intake too?
      07-10-2018, 05:28 PM   #219
IK6SPEED
Originally Posted by Steve_Jr View Post
It's definitely better than just washer ... the washer was maded by custome order to mechanic who has no background information .. (no time to decribe T.T ) Originally yours it is ~ !
+ Lancelot
Is this the part and dimension needed for OEM F30 Struts and F80 Caps?
https://www.shapeways.com/product/CJ...li=marketplace
      07-19-2018, 12:47 PM   #220
Drives: 2017 YMB M3
Wow! Very well done!!! It looks great!!
Thank you for the detailed installation guide + photos
