12-19-2012, 02:23 PM | #1453 | |
Rep 171
12-19-2012, 03:11 PM | #1454 | |
Rep 145
Drives: F30 320ed
I thought all F30s had this. |
12-19-2012, 07:12 PM | #1456 | |
Administrator
40659
Rep 21,237
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
12-19-2012, 07:15 PM | #1457 |
Rep 40,632
12-19-2012, 10:45 PM | #1459 |
Rep 161
12-19-2012, 11:11 PM | #1460 |
Rep 1,544
12-20-2012, 12:06 AM | #1462 | |
Rep 204
Have found the following info from the F25 X3 forum regarding disable cold/warm light check for certain bulbs. Useful for replacing the standard incandescent bulbs with LED replacements.
http://x3.xbimmers.com/forums/showpo...2&postcount=18 Quote:
In the Frmbody module > 3061 LceLciOutputChannels, 67 TFL_L or R: front LED corona rings L or R NSW_L or R: front fog lights FRA_V_L or R: front turn signals Here are other names in that channels that need to be checked: AL_L or R: brake lights? POL_L or R: are LEDs according to the settings, maybe the parking light strips on the tail lights. FL_L or R: not LED SML_L or R: not LED FRA_Z_L or R: most likely mirror turn signals as the setting is set to LED as default BIX_L or R: name looks like Bi-xenon? LCI_0: LED LCI_1: LED LCI_2: not LED LCI_3: LED LCI_4: LED LCI_5: LED LCI_6: LED LCI_7: LED LCI_8: LED Settings are similar as well WARMUEBERWACHUNG - Warm Check KALTUEBERWACHUNG - Cold Check IS_LED - Indicate the bulb is LED |
12-20-2012, 05:58 AM | #1464 |
Rep 40,632
PM sent.
12-20-2012, 12:58 PM | #1465 |
Blubb.
Rep 53
I finally managed to get everything ready. Mine is built on 10th Octobre.
What I tried: - the two settings for the turn signal in hud - the hud_nbt (I think it was there) entertainment list well, both don't work, but for the entertainment list there is at least a checkbox in the hud settings: entertainment/telephone. Unfortunately I can't check it.. Will need to read first, I guess, and see what's possible with the new ones.. |
12-20-2012, 01:00 PM | #1466 | |
Rep 40,632
12-20-2012, 01:10 PM | #1467 |
Rep 171
I've been told it does not work at all in the f30 (the HUD turn signals that is) I cannot test for myself since I don't have the HUD.
But the golden rule of this forum is; always listen to Shawn |
12-20-2012, 03:03 PM | #1469 |
_______
169
Rep 1,088
This is where it is in the F25:
To display entertainment information in your HUD (only shows when you scroll with the steering wheel roller switch) KOMBI/3000/HUD_ENTERTAINNMENT_ENABLE--->Aktiv To display incoming phone information on the HUD: KOMBI/3000/HUD_TELEFONANRUF_ENABLE--->Aktiv To display previous phone list on the HUD (activated by the telephone button on the steering wheel): KOMBI/3000/HUD_TELEFONBUNCH_ENABLE--->Aktiv To display the voice commands on the HUD (activated when you press the voice command button on the steering wheel): KOMBI/3000/HUD_SPRACHEINGABE_ENABLE--->Enable
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat |
12-20-2012, 11:56 PM | #1471 |
Rep 490
This might sound stupid, but how do you unplug the enet cable when you're done coding? It's super easy to plug in, but I have to use considerable amount of force to unplug it to a point I'm afraid I might break something
Is there a easy/easier way to do this? |
12-21-2012, 01:07 AM | #1472 | |
Rep 1,892
There is just a small clip on the connector that holds it in place because it could fall out otherwise. Just grab it and pull it down, rocking it a bit. I've coded a dozen cars and I've never run into a sticky or hard to remove connector. It's pretty well made. |
12-21-2012, 01:12 AM | #1473 | |
Rep 171
I'm with kon, it requires a considerable effort to yank it out. (all cars i used it on) however, never any problems or broke parts yet, so I wouldn't worry about it too much. |
