BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Drivetrain malfunction!!!!!
European Auto Source
      04-07-2015, 09:26 AM   #133
Burnt C6
Burnt C6's Avatar
Drives: 2014 Melbourne Red 328i Sport
It happened to me the day after I got the Dinan Tune installed. I had hit a good size pot hole and it cam on. I thought that might have caused it. I got home turned it off and restarted it and the message was gone was gone. That was back in September it came back on last night right as I was pulling into the garage. It won't go off this time. It also came up with the Chassis Malfunction notification at the same time. Time to take it in and see what the hell is going on.
2014 328i Melbourne Red Sport Line Dinan Dinantronics tune,
Dinan Exhaust, Dinan Suspension, H&R Sway bars, 18x9 APEX PS-7 with Michelin Pilot Sport /AS3 245/40/18 front 265/40/18 rear. Track 18x9 APEX ARC-8 with 255/35 18 Dunlop ZII, AFE CAI, BMW M Performance Brakes 370 mm front 345 mm rear.
      04-07-2015, 10:44 AM   #134
435ivan
Drives: Bmw f32
Originally Posted by NAV8TT View Post
I was driving to work in Eco pro mode and once i entered the highway, i tried to catch up on speed so I moved the gear to DS from D position and all of a sudden the car jammed up, started shaking and a signal came up in the iDrive saying Drivetrain malfunction, drive moderately, and the car wouldn't allow me to exceed 50 mls/h. The car kept shaking till I took the next exit. It was very dangerous as I entered the highway with that speed and there was a bunch of cars going at least 75 mls/hr that had to leave the lane I'm on. Darn it. The engine light is on now. I parked the car and I'm at work now. WTF!!
I have a 435i that I just got in November. I haven't had a problem with it till a couple weeks ago that I have gotten a down pipe and the jb4 installed. That night I was doing some highway pulls and once I reached top of 6th that I shift to 7th I got the drivetrain malfunction. It pretty much just cut all power It wouldn't rev or accelerate it got down to 60mph and so I pulled over to the side turned off the engine and turned it back on and I was fine. But it has happened a few times already. I asked around and someone had told me that wen it gets too hot or reaches a certain temperature the call will pretty much put itself into a safe mode and it starts giving those malfunctions. I don't know what to do to prevent it from happening besides no more highway pulls. Has anyone found a solution?
      05-07-2015, 10:27 AM   #135
JVBFTW
Drives: 2013 320i
Originally Posted by mocohead View Post
OP what gas (brand and octane) do you use?
Have you noticed the car cranking a long time before starting in the morning?
I've noticed the cranking issue in the am, and got a drivetrain malfunction warning on Sunday. I shut the car off, then turned it back on and had no issue.
What does the cranking + this problem point to?
Car is a 2013 320i 6MT, with about 20k on it.
John V
2013 320i 6MT
      05-11-2015, 12:01 PM   #136
gobears81
Drives: 2013 328i
This morning my 2013 328i F30 gave me the following error:
"Drivetrain malfunction: Drive moderately. Maximum drivetrain output not available. Consult service center."
Looking through this forum, it sounds like there could be multiple trips to the service center needed. I'm not looking forward to this!
      06-01-2015, 02:22 PM   #137
alpinewhite3
alpinewhite3's Avatar
Drives: '15 328i
Add another drive train malfunction story to the list- 2015 328i RWD April 2015 Build. Car is 2 weeks old.
Clearly, this issue has not been fixed or resolved yet. I was on the highway in Sport mode when I pushed down the accelerator to pass someone and suddenly lost all power and car started shuddering with check engine light flashing. Pulled over and re-started the car and everything went back to normal???
Should I still bring it in? Car feels normal now but like others have said without the error code flashing will they still be able to diagnose anything? I'm worried now that the car is permanently running on reduced power.
      06-01-2015, 02:28 PM   #138
CalCarNut
CalCarNut's Avatar
Drives: 2015 F36 Jet Black Sport Line
Ah crap..keep us posted...........
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint|-GSR Stage 1|
      06-01-2015, 03:18 PM   #139
ATLBlue
Car OCD
ATLBlue's Avatar
Drives: 2017 EBII F36 430d M Sport
Got the 'Drivetrain Malfunction' alert about once every 6 weeks:
I just feel a limitation of power (I'd say 50% of maximum output) and it happens in a very smooth manner. I can keep driving at 70+ mph and take my time to park and restart the engine. Everything gets back to normal with no error code to be found when checking through the OBDII port.
I could not find any logic to this (car not running hot, not at 100% throttle...) and I have not had an issue on the track or AutoX so far. I ran the car full out for a one hour long session at the track with 90F ambient temperature last week and it did perfectly fine
Since I am running a tune and exhaust, I am not asking the dealership to look into this but the issue does not bother me much either.
2017 BMW F36 430D M Sport Estoril Blue & 2002 E46 M3 Imola Red
More about my ride @ ATLBlue's 2014 F30 Journal. Instagram Inline6_ATL
      07-08-2015, 12:23 AM   #140
pauloxxi
Drives: 2009 -328i / 2014 -320 XDrive
It did it again.
Now, it is 6700 miles, one year in service, and this the second missfire issue. This time towed to dealer. They found lot of coolant (green stuff) in the injectors and spark plug. Seems like head gasket blown off, but they are not yet sure. Car belongs to my wife, no abuse, no mods. Just frustrating and kind of ashamed for paying almost $40,000 for a unreliable piece of crap. This is my third BMW, I'm feeling the ultimate driving machine translates as final, no more, end, last one.
By the way, because the crap broke more than 100 miles and out of state, they gave me a rental car, an economic one, a KIA RIO, and they don't know yet when I should get my car back. I think I don't need to say anything more.
      09-11-2015, 02:17 PM   #141
tsakhan
Drives: 2014 328i
Driving down the freeway and all of the sudden engine gives out and car goes into "limp mode" cruise control was set at 76 MPH and suddenly it goes to 60 MPH, I almost got rear ended by another vehicle as I had no control over the vehicle power. Vehicle continues to drive but does not go over 60 MPH, shudders and shakes the acceleration is very mild to put it lightly.
My car is a 2014 328i M Sport - no mods except for MPE. This is the 3rd time its happened but previously it was fixed by simple restart, but not this time. I only have 12k miles on the car. Possible recall by BMW NA? I've submitted a complaint via NHTSA and BBB. Will speak with a Lawyer next week.
Any others have any inputs? What did you guys do? or are you guys just living with it? I am very worried as this is my first BMW and will surely be my last BMW. This type of reliability from a car stickered at $48k ?!?! insane.
      09-13-2015, 06:16 PM   #142
uwfshane
Drives: 2012 550i, 2014 328i
I've had my CPO 550i for 8 days now and have experienced the "Drivetrain Malfunction" warning twice. The first time was leaving a parking garage at the airport, and then this morning when my wife and I were leaving the neighborhood to do some shopping. I've read a few instances where this warning was caused by a low batter charge...so I hope in my case its just because the car has been sitting a lot lately without the engine running (it's been on the dealership lot for a bit, and then it spent a few more days in airport parking while I was traveling). I'm taking it in to the service center early this week, hopefully they can narrow down the issue.
      09-14-2015, 12:26 PM   #143
Straight6Driver
Drives: F30 335i
Originally Posted by elborhamy View Post
after 3 days of diagnosis, the problem is in turbo Intake solenoid valve (not exhaust) which jamming and stuck (as they described the problem), but the valve not in stock, it will arrive from Germany in 10 Days, the dealership found no problem in moving the car (They told me that it may just decrease the performance a little bit and will not harm the engine by any way), i'll keep you informed.
Can I just confirm what exactly is "intake solenoid valve" in BMW terms?
Is it DV/BOV?
      10-08-2015, 03:15 PM   #144
elborhamy
Drives: bmw f30 316i 2013
Is it DV/BOV?
Sorry, but i'm not specialist
As i understood the "intake solenoid valve" is an electrically operated on/off valve located on the intake of the turbo to operate it (the turbo as i understood not working all the time, it works when the "intake solenoid is energised").
there is another solenoid valve located at the exhaust side which causes the sound of "BSSSS" when you suddenly up ur foot from accelerator pedal at high rmp to vent the air compressed in the turbo
sorry again its all my info
      10-08-2015, 10:51 PM   #145
adew
Drives: black
im kind of scared to pick one up now....
      10-16-2015, 03:36 AM   #146
t335xi
Drives: 2013 335xi Sedan Sprt Line ppk
I've probably said it before ... but this error code is a catch all for a variety of issues. I doubt that there's much of a common denominator here other than a visit to the service dept to see what is actually going on.
      03-15-2016, 08:46 AM   #147
mbanks21
Drives: 2015 335i MSport
Just got my error this morning. Car still drove but you can def feel a lack of power. 2015 335i, first owner, only ~5k miles. Hoping to drop it off today or tomorrow at the stealer
      03-15-2016, 12:35 PM   #148
Dang3r
Schmollbraten
Dang3r's Avatar
Drives: RS 5
I had this after 14000km, it starts slowly when I'd started to overtake it seems, like the gearselector has to think over which gear to set and this took at least up to 4 secs. In order to stop the overtake maneuvres, I'd set to sport and pulled the trigger more hard. That was not a really solution, but helped at faster and more sporty driving.
At least I'd ended up at the dealer with the displayed error message and he fixed it with a software update of whatever.
Since that everything is fine and it was on warranty, also f.o.c. for me.
RS 5 - ZX12R LE - GPZ750 Turbo
Don't like my ///M? Call 0-8-0-0-E-A-T-S-H-*-T
Bobs' not your uncle and Trump is not my president!
      03-15-2016, 10:10 PM   #149
spiff56747
Drives: 2012 335i 6 speed
I had this come on - dealer said software needed to be updated. So far so good knock on wood.
      03-19-2016, 09:29 AM   #150
mbanks21
Mine had something to do with the turbo air temp sensor
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ Res Delete/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 DWS06/ H&R Sport / Motorsport Lug Conversion
      06-14-2016, 03:29 PM   #151
jlaurie
Drives: 2016 435i convertible
MY TURN :(
new built 2016 435 conv. first few hundred mile drive. was 100deg out and dry in desert. most of trip on eco plus with adaptive cruise on. after short stop and resume it happened. turned off and drivetrain malfx went off but engine light stayed on. only a few short shudders noted few days than on way back, same temp, same place in opposite direction, occured again while driving. same reset ok. engine light stays on entire time. to see service today. 900 miles on car.
seems like when its cruising at 70 or 80 around 1700 to 2000 rpm level or downhill and than must accellerate and should drop gear (automatic) from 8 to 7 (7 to 6?) that's when it seems to occ give the shudder like it's not catching or downshiffting . If I lightly repetively goose lightly and repetively a few time a little it seems I've aborted the condition a few times when it felt like it was going to start shuddering . feels like it should downshift but it doesn't quick enough or something like that?
      06-14-2016, 05:42 PM   #152
cfm56d7b
Drives: 2017 440i Gran Coupe
Originally Posted by YMB_M4_j2
this has happened to my car 4 times now. Its a cylinder misfire that causes that error. It could either be a spark plug, coil pack or injector. The dealer has replaced the coil packs and spark plugs but it continues to happen. BMWNA is involved now and they have no idea what to do fix it. They have updated software as well with no luck. Im one step away from filing a lemon law suit for it.
What's the year and model of your car? N55 engine by any chance?
      06-14-2016, 10:20 PM   #153
dwalls90
Drives: F30 M Sport
I had this error on My F30 with the N20 and they had to replace two injectors. The lease is up soon but shocking this happened under 3 years and 25K miles.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
