04-17-2014, 11:40 AM | #23 | |
Rep 4,323
With a 6 year/100k warranty, OEM is my priority for sure...
04-17-2014, 02:50 PM | #24 | |
Rep 1,997
04-17-2014, 09:48 PM | #25 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
There are a LOT of aspects to get right for an LSD to add traction without creating new problems... for example, a 2-way diff (and to a lesser extent, 1.5-way diffs) can add significant understeer when they lock-up on deceleration; 1-way diffs don't suffer from this, but they also function like open diffs under engine braking conditions. There's also the manner in which the diff locks-up (i.e. how aggressive is the engagement force in response to input torque), whether the lock-up is variable, etc. I would be willing to bet that BMW will be releasing something that is a well-balanced product that will offer appreciable traction improvements without creating other new handling challenges. Will it be a variable unit like those fitted to the e46 M3? Or a 2-/3-clutch unit with limited lock-up like OEM LSDs of the past? I dunno, and that's what I'd like to find out. At this point, I am open to the BMW LSD as a possible alternative to the Quaife. The Quaife is a great unit, but the possibility of the BMW option better integrating with DSC/DTC/eLSD is a compelling prospect.
04-25-2014, 03:22 PM | #26 | |
Rep 4,323
Jives with this here too:http://www.f30post.com/forums/showthread.php?t=866546 They can't get me an installation guide OR hours to do it...I was like how the F am I supposed to order something if I don't know how much the install with cost?!!
04-25-2014, 09:55 PM | #27 | |
558
Rep 1,477
Drives: 335i
I did find that it's apparently a Drexler unit, though - which is a good thing, as they are regarded as being among the best available. I am somewhat doubtful at this point that there will be any specific integration with DSC/DTC/eLSD, though; maybe this really isn't necessary anyway. I've got someone working on getting some more intel - I'll update this thread with any new info.
04-26-2014, 12:08 AM | #28 | |
Vrooom :)
314
Rep 2,602
I've been trying to order an M235i since launch with the optional LSD which was suppose to be available at launch in march. But nobody at BMW, not my dealership or BMW NA customer service, knows anything about the LSD.
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
04-26-2014, 04:12 AM | #29 |
Rep 58
Drives: 435i X-Drive M Sport ('13)
Hi,
I'm asking though I know the answer, but we never know: does it fit on a xDrive car to give it a more "fun to drive" handling ? |
04-26-2014, 10:29 AM | #30 | |
Rep 4,323
04-26-2014, 10:37 AM | #31 | ||
Rep 4,323
04-26-2014, 12:25 PM | #32 |
558
Rep 1,477
Drives: 335i
Yes, the M Performance LSD is for RWD only. Bummer though, as xDrive shifts torque within a given axle electronically by making use of ABS (similar to the RWD's eLSD), so it would also really benefit from a good mechanical rear LSD... similar to the optional rear LSD on the Audi S4.
04-28-2014, 03:57 PM | #33 |
Rep 4,323
Nice review of the unit here: http://www.e90post.com/forums/showthread.php?t=591635
04-28-2014, 10:54 PM | #34 | |
558
Rep 1,477
Drives: 335i
05-10-2014, 10:08 AM | #35 |
558
Rep 1,477
Drives: 335i
Well, here's the skinny on the LSD:
http://www.f30post.com/forums/showthread.php?t=982935 After doing some research, I've discovered this is a 3-clutch unit... seems like a really solid option.
05-16-2014, 09:56 AM | #36 |
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
So what I find interesting here, is from the 3d models on that article the ring gear for the MPerf LSD is bolted, not welded
This might mean one could at some point get ahold of a ring gear for a MPerf LSD separately (this is a big might) then use that gear, along with a different LSD unit and retrofit your existing pumpkin easily... |
05-16-2014, 10:11 AM | #37 |
558
Rep 1,477
Drives: 335i
I have an appt. to get this LSD installed next Friday... $2698 (+tax) installed at Flemington BMW.
05-16-2014, 10:56 AM | #38 | |
2006 TIME Person Of The Year
9720
Rep 6,445
05-17-2014, 10:22 AM | #40 |
Rep 681
It improves traction on wet surface and snow
BMW M3 G80 Isle of Man
05-17-2014, 11:44 AM | #41 |
558
Rep 1,477
Drives: 335i
It improves traction considerably. Do you ever get the DSC/traction control light to come on while driving? If so, you'll see improvements on the street too...
05-23-2014, 07:40 AM | #42 |
Rep 195
05-23-2014, 10:32 AM | #43 |
558
Rep 1,477
Drives: 335i
It's being installed as I type this... gotta force myself to be patient for 500 miles
05-23-2014, 10:35 AM | #44 | |
Rep 639
but do report back on your results. |
