08-07-2014, 10:13 AM | #1 |
Rep 61
One Eighty NYC angel eyes.
Hi all, have any members here bought the One Eighty angel eyes for their halogen headlights? If anybody has them would you be so kind to share experience with them?
08-07-2014, 10:28 AM | #2 |
Rep 821
Drives: BMW F80 M3 & F87 M2
I have not personally, but I know they do some great work. When I used to have my G37, one eighty was huge on the forums.
Carbon fiber for the everyday driver: rwcarbon.com 3941 E La Palma Ave Anaheim CA, 92870 info@rwcarbon.com / (714) 328-4406 Instagram/Tiktok/Facebook: @rwcarbon |
08-07-2014, 05:40 PM | #4 |
Rep 5
I actually went into the shop to have them installed. I had bi-xenon projectors installed, the style-2 angel eyes, and had the interior of the housing painted. I dropped off the car and it took about 1-2 weeks if I remember correctly. From what I was told, the housing was very difficult to remove and I would recommend you find an authorized shop around the area that could install it for you. Might be too difficult for a DIY project but who knows. Visually, it looks awesome. Makes the car so much nicer and I get complements all the time.
Here are some pictures they posted: http://f30.bimmerpost.com/forums/sho...d.php?t=892658 (The blue f-30) |
08-07-2014, 08:23 PM | #5 |
407
Rep 676
I recently saw some posts by OneEighty that they can install some of the aes that you see on the full led headlights. the ones that kind of pop out. so far the housing for halogens looks the same size as xenons so im hoping to get those as well.
also oss can always install raptors for you. they look better than the ones above. |
08-08-2014, 04:31 AM | #7 | |
Rep 180
08-08-2014, 08:30 AM | #8 |
Rep 376
$2500?!! for that just trade in the car for one with xenons... unless you are crazy upside down... or you can of course retrofit OEM xenons for around $1500 or lesss
08-09-2014, 03:51 AM | #9 |
Rep 180
Hi Kapkanimd, unfortunately i can't trade in the car so the only option is either OneEighty lights or the OEM retrofit.My only problem is that i don't know how to code, but i can do the installation part as i have read your post quite a few times now.The only thing i wouldn't install are the levelling sensors .Have you had any issues with your install or have the lights been working fine and no errors popping up.
08-09-2014, 10:37 AM | #10 | |
Rep 376
08-09-2014, 02:48 PM | #11 |
Rep 88
I've seen an F30 in my area which has this retrofitted. Not sure which vendor but it kinda looks odd. From 30 feet away, I thought something's not right with the headlight and this was when it's off. Imagine what your car would look like if one or more of these SMD LEDs fail. It's not something you can just go and buy a replacement.
08-09-2014, 02:55 PM | #12 |
Rep 88
And yeah, at $2500, the real Xenon lamp can't be beat, specially with AHL. And also, the hardest part of the retrofit is taking the lights off the car and installing the new ones in -which you'll have to do anyways, regardless of which one you choose to go.
08-12-2014, 03:46 AM | #13 |
Rep 1
Drives: BMW 428i GC, Mineral Grey
anyone know a shop in southern california that does similar work? Really like the 4-series concept corona lights (that never made production)
08-12-2014, 11:05 AM | #14 |
Rep 1,556
I will live with my halogens until I get my next car. Once you open up the housing, it will never be the same. Not worth the risk to have constant moisture inside the housing.
08-13-2014, 12:58 PM | #15 |
Rep 180
08-18-2014, 07:07 AM | #16 |
Rep 180
08-18-2014, 08:42 AM | #17 |
Rep 376
From what I have seen so far, the wiring diagrams consist of only xenon vs halogen. The adaptive function comes from the physical hardware in the headlight, and the driver's modules that go in them (giant circuit boards you put in). If you PM the last seven of your VIN I can pull up the wiring diagrams that are associated with your car to double check.
08-18-2014, 09:00 AM | #18 | |
Rep 180
08-18-2014, 09:36 PM | #19 |
Rep 350
Looking to enhance your halogens or to convert them to bi-xenon?
I believe there is a guy here called blueaudi that worked a lot on the headlights. |
08-19-2014, 03:03 AM | #20 |
Rep 992
Removing the headlights from the car is like 90% of oem xenon retrofit work, and you can still have to remove the headlights for oneighty LED as well..
Parts for an adaptive headlight are very easy to find. |
09-17-2014, 06:06 AM | #21 |
Rep 49
guys stay away from one eighty angel eyes, their shocking.
I regret putting them on my f30, the angel eyes are thin cheap looking, LEDs look dodgy and I've only had them 3 weeks and 3x LEDs are blown already. I asked oneeighty for a replacement they said theyd send replacement and just ignore any emails I sent asking what the status is... |
09-17-2014, 09:34 AM | #22 | |
Rep 180
