BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > BMW F30 335i M-Sport Before and After coil-overs
      08-21-2012, 04:06 PM   #1
Sean@PSI
Sean@PSI's Avatar
Drives: 2021 IOMG M3 Sedan
Hi everyone,
We wanted to give you a more in-depth look at the BMW F30 coilover setup from BC Racing.
Their BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle - no preset ride height here - and the patented concave lower locking ring keeps it locked in. All of the BC systems come with top-quality mounts to provide the most feedback possible from your suspension and to sharpen your steering response. The included front camber plates also allow you to get the perfect alignment setup without compromise.
BC Racing camber plates are vehicle specific and engineered to be rigid superior replacements to the OE Top hats. These plates can reach 3 degrees of camber depending on the level of drop. Each lower mount is designed with the OEM in hand to ensure OEM like fit and exact tolerance specifications matching OE manufacturers. All this while providing a strong, attractive looking coilover system that won't break the bank!
Minimum height is actually higher than stock and maximum low is 100% undrivable - so these give you the adjustment needed for any setup.
You can start to see why we are fans of their products.
Features:
  • Now available for AWD (X-drive) models - requires a 3-4 week build time.
  • Mono-tube shock design
  • Full height adjustability through shock body, not spring
  • 30 levels of dampening adjustment (compression/rebound)
  • Front camber plates are included
  • Custom spring rates available upon request
  • 1 Year warranty against manufacturer defect
  • Completely rebuildable and individual parts are available separately for purchase
Enjoy the photos!
Before (stock height):
[img]http://farm9.staticflickr.com/8302/7833568730_3cc97629fe_c.jpg[/img
After (On lowest setting):
Last edited by Sean@PSI; 05-08-2014 at 09:01 AM.. Reason: New updated info for 2014
      08-21-2012, 04:14 PM   #2
Touring
Touring's Avatar
Norway
178
Drives: i3,E21,M2,E23, Skoda Kodiaq
hmmm...a little too much?
      08-21-2012, 04:17 PM   #3
nano10
nano10's Avatar
448
Drives: 2018 F80 M3
is that going to be the daily driver height?
2018 M3 Imola Red Competition package/Executive package/M Performance suspension
      08-21-2012, 04:19 PM   #4
ianbiz
Back in a BMW
ianbiz's Avatar
Drives: 2015 335i Msport
"The car was raised to a nice drivable height that eliminated most of the "wheel gap"."
Ian
      08-21-2012, 04:22 PM   #5
Sean@PSI
Sean@PSI's Avatar
Thanks, Ian!
The car was NOT driven like this and it IS too low. But, there are always those extremist that want to push the limit of anything. These will allow you to do so.
      08-21-2012, 04:24 PM   #6
bosz
bosz's Avatar
65
Drives: F30 335i Ordered
looks broken
**JB Stage 1** 2012 F30 335i/BSM/Coral Red Interior/Diamond Black Trim/Premium Pack/BMW Apps/Ext Blue Tooth/Sirius XM/Sport Auto W/Paddle Shifters/Sport Suspension/Meisterschaft Super GT Exhaust
      08-21-2012, 04:29 PM   #7
Sean@PSI
Sean@PSI's Avatar
Originally Posted by bosz View Post
looks broken
It's just for measurement and development purposes and was raised up to a drivable height.
There are people out there that find this to be perfect and then there are others who disagree with this height.
We're just showing what it CAN do.
      08-21-2012, 04:46 PM   #8
Sean@PSI
Sean@PSI's Avatar
Here is a photo of its daily driving height. Again, "To each, his own".
DSC_9530 by Lafa Photography, on Flickr
Photo courtesy of LaFa Photography.
      08-21-2012, 04:50 PM   #9
PlannBee
PlannBee's Avatar
Cambodia
49
Drives: A Visible E36
These aren't the extreme drop versions right? But wow does that look good.
-Brandon
"I now have a Beautiful Mysterious Woman "
"My Real E36" - '96 328is 5MT/Boston Green/Beige/Wood Grain/18" Style 189/BONE STOCK
      08-21-2012, 04:56 PM   #10
Sean@PSI
Sean@PSI's Avatar
Not 100% sure about that. With these at full drop, you can't turn the steering wheel more than 75 degrees. If someone want's to go lower, I'm not sure how you would get anywhere without rubbing the fenders to the point of cracking the paint.
      08-21-2012, 04:58 PM   #11
jwilly
Drives: They're all white now.
What rake did you settle on? And why?
Have any shock dyno graphs?
Joel
      08-21-2012, 05:03 PM   #12
Sean@PSI
Sean@PSI's Avatar
Joel
The customer ended up making a few more adjustments to the ride height of the coilovers himself. Not sure on the rake.
I'm sure I can get the shock dyne graphs for you. I'm sure the guys at BC Racing NA would have no problem with it.
      08-21-2012, 05:17 PM   #13
gerbs
woof
gerbs's Avatar
Drives: M6
Indeed. Never understood this look, but to each his own!
2013 F13 ///M6 Sakhir Orange
2013 F30 335i Estoril Blue II
2008 E92 ///M3 Interlagos Blue
2007 E92 335i Montego Blue
      08-21-2012, 05:47 PM   #14
bosz
bosz's Avatar
65
Looks good here!
      08-21-2012, 06:20 PM   #15
bcl0328
Drives: 2012 328i
i really like that for some reason.
      08-21-2012, 06:20 PM   #16
MassBimmer
MassBimmer's Avatar
Drives: 2023 i4 M50
2009 BMW  [9.24]
Both drops look terrible with those stock wheels...too aggressive for the set-up
      08-21-2012, 06:45 PM   #17
Sean@PSI
Sean@PSI's Avatar
Wheels are in the works. Won't be long before the new setup is on it.
      08-21-2012, 07:05 PM   #18
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
PM sent
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      08-21-2012, 07:08 PM   #19
Sean@PSI
Sean@PSI's Avatar
Originally Posted by m3 guy View Post
PM sent
Responded!
      08-21-2012, 07:29 PM   #20
Alpine F31
Alpine F31's Avatar
Drives: MB E350 4MATIC Estate
You are correct.
      08-21-2012, 08:15 PM   #21
pkimM3r
pkimM3r's Avatar
205
aren't the point of getting coilovers to be able to rip through corners? that would just rub like crazy. I tried to do it once but every time I cornered hard in my cars, it would just rub all over the place. I would put it low enough but make sure it driveable.
      08-21-2012, 08:28 PM   #22
Sean@PSI
Sean@PSI's Avatar
It's definitely no longer that low, but it's still quite low, like in the very last picture, and does NOT rub with the OEM wheels on it. I'm sure we will be raising it once again once the new wheels arrive.
bc racing coilovers, bc racing na, coil over, f30 335 coilovers, precision sport industries
