BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding Sport Display on HU_ENTRY?
      06-12-2015, 10:24 PM   #1
Adamr916
Adamr916's Avatar
Drives: 2014 328d
I found where you can turn on the sport display, was able to get it to show up on the screen but it didn't do anything after that. Is there anything else I need to code to get the full display? I just has the base iDrive with office.
      06-13-2015, 12:10 AM   #2
HFW003
HFW003's Avatar
Australia
5685
Drives: 2024 M340i xdrive
Only works with Pro Nav.
You can actually code them to show on the older head units but they don't move.
Gimmicky waste of time anyway so I wouldn't lose any sleep over it!
      06-13-2015, 07:09 AM   #3
Adamr916
Adamr916's Avatar
Drives: 2014 328d
That's what I figured, I got the gauges to show up but they didn't move, so I just coded it back
      02-24-2017, 02:58 PM   #4
Sparky28
Drives: F30 335d
I've got a 2014 F30 335d with business nav & I managed to get it working
      02-24-2017, 03:19 PM   #5
Asurans
Drives: 2015 335xd M-Sport
2015 f30 335d xdrive. Business nav. Mine worked after coding.
      03-03-2017, 12:13 AM   #6
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
2014 BMW 420da  [0.00]
That isnt correct. HU EntryNav can be coded for sports Display. Old Business Champ2 couldn´t
If you have Sport Mode
NBT > EFF_DYN_SPORT_CID > aktiv
NBT > EFF_DYN_SPORT_UNIT > aktiv
Works with Diesel and Gasoline Engine 2014 and onwards
      04-21-2017, 06:30 AM   #7
Bambazonke
Bambazonke's Avatar
Australia
210
Drives: 2017 X5 & 2020 X5
  [0.00]
Sport displays do work on the HU_CHAMP2 I have them activated on my 2012 320d
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive
      04-21-2017, 04:25 PM   #8
Turboluke
Drives: F80
How did you do that?
I've done that two changes below but got only the gauges and they don't move.
My Car is a 2012 318d with Champ2
      04-22-2017, 02:57 PM   #9
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
I did exactly as you have done but I suspect there may be additional coding done of associated modules (FEM and KOMBI) that send the signal to the CHAMP2_HU or ENTRY_HU for the gauges to move when all the vehicle ECU's are VO coded at the factory I was thinking maybe 2TB or 7AC? PM me your chassis # and I can compare my FA against yours using bmwvindecoder.com
      06-20-2017, 03:19 PM   #10
Turboluke
Drives: F80
I am pretty sure it's the engine that sends the singnals to Champ2.
BTW, thanks for your VIN Bambazonke.
The difference to my car is: your car is a 320d (TYPE: 3D36) my car is a 318d, (3K11). Your car has a 2TB, my car a 205 Gearbox. Both have have SA 7AC (Sport Line)
But the fact that your car is from 2012 and my from 2013-09 makes me believe that the smaller 318d engine is the main problem, which is not sending the signals which are needed for the Champ2 ECU. Nevertheless, I will try to VO Code SA-2TB, but I gess flashing the DDE to a newer I-Step would be the more promising way to go.
      08-04-2017, 08:04 PM   #11
Wayne-G
Wayne-G's Avatar
Drives: MG F30 330d Msport xDrive
Tried coding my early 2014 330d business Nav with Carly and the display is there but it doesn't work, any way I can get this to work?
Coded the live tyre temps too but yet again they don't work!
      11-07-2017, 02:24 PM   #12
Kofiankra
Drives: Red f30 2014
316d
Strange, as i've got a 316d sports and it works fine. i dont think the size of the engine has anything to do with it.
      12-06-2017, 07:43 AM   #13
Titan_br
Titan_br's Avatar
Brazil
Drives: M3 E92 with AA Stage 3 SC
2011 BMW M3  [0.00]
How to change the unit from KW to HP?
      12-07-2017, 05:16 PM   #14
Junebug85
Junebug85's Avatar
Drives: BMW 540i xDrive - M Sport Plus
In Vehicle Settings, change the unit under the power option. There's a few units you can change here like Miles to Km etc...
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black
      12-08-2017, 03:48 AM   #15
steve498
Drives: BMW F30
Is there a way to change the dial from X HP to Y HP? I.e. 200 to 260?
      12-08-2017, 05:36 PM   #16
Jhnblckwood
Drives: F30 2014 320i xdrive
F30 320ix hu entry displays but doesn't move.
      02-06-2018, 06:43 PM   #17
d_a_m
d_a_m's Avatar
Drives: 2013 BMW 328i
I'm also facing the same issue. Any new findings?
///437m wheels///Depo Headlights ///3M 1080 Carbon Fiber Interior Wrap///M-Sport Bumper Conversion///Dinan Suspension///M-Style Kidney Grilles
"If we knew what it was we were doing, it would not be called research, would it?"
      02-07-2018, 02:21 AM   #18
japanwings
Belgium
118
Drives: 2018 F36 Gran Coupe
Same problem, i have HU_ENTRY 318d F31, doesn't move.
I think, if possible, it needs an extra signal from KOMBI maybe.
Maybe if SPA_SPORT_ENABLE set to activ?
Cant find anything else in KOMBI for EFF, DYN, SPORT, CID or UNIT..
      02-24-2018, 06:20 PM   #19
Jhnblckwood
U need nbt, mine didn't work with entry, upgraded to nbt n works perfect.
      05-18-2018, 11:47 AM   #20
blakep8
blakep8's Avatar
Drives: 2014 Black F32 435i
Can anyone comment on if the sports displays on a base 328i with hu_entry can be coded to have the sports displays WORK?
2014 F32 435i /// M Sport Brakes /// Vorsteiner VFF103 /// Resonator Delete /// MP Carbon Front Spoiler /// MP Carbon Mirror Caps /// MP Carbon Rear Spoiler
@slowf32 on instagram
      05-18-2018, 01:34 PM   #21
Jhnblckwood
Speaking from experience it wount Work. Installed nbt n they work fine. Not possible with entry. Trust me.
      05-21-2018, 11:52 AM   #22
blakep8
blakep8's Avatar
I personally have NBT I was just coding a friends car who as entry... this is why you don't cheap out earlier
