10-22-2016, 06:40 PM | #89 | |
Rep 418
Didn't want to give up EDC
///MPPSK///MP FRONT SPLITTER///MP KIDNEY GRILLS///CF MIRRORS///CF SPOILER///CF TIPS///HUPER OPTIK 20%///NBT///AC SCHNITZER///M4 437M///ZMP///ZTR///iND///
10-26-2016, 08:42 PM | #90 |
Rep 2
10-27-2016, 11:12 AM | #91 |
Rep 418
See post #81
12-12-2016, 01:09 PM | #92 |
Rep 42
12-12-2016, 01:19 PM | #93 |
Rep 418
Any dinan, acs, h&r springs will work with the stock dampers. No need to change the dampers. You should be aware that some have argued using lowering springs without changing the dampers will cause the car to be bouncy and premature damper wear.
12-12-2016, 02:10 PM | #94 |
Rep 42
Alright thanks, i'll take a look
12-13-2016, 11:16 PM | #96 | |
Rep 1,986
http://f30.bimmerpost.com/forums/sho...0&postcount=20 |
12-14-2016, 03:40 AM | #97 | |
Rep 464
This setup will not work properly with xDrive. The wheel diameter between the F/R is too great and will cause issues with the transmission. In my case, the transmission was not shifting smoothly and after further research,some references suggest to keep the difference in wheel diameter below 3%. I went with 245/40-19 in the front to keep the % difference as close to OEM stagger as possible. I have a slight rub when turning on the driver side front inner wheel liner where it protrudes for the side view camera and park assist sensor . I am lowered ~0.5".
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
01-12-2017, 12:59 AM | #98 |
Rep 1,015
This hit me this evening for some odd reason.
For the Car Techies/Gear Heads. Are the Alignment, Camber, Caster, Cross-Camber, Cross-Caster and Toe same for F30 403m @ 225/40R19 and F80 437m @ 255/35R19 and their different ET? If not, then it would seem F30s with 437m should be setup with F80 Specs??? As I do not know tech specs for both, I am throwing it out here for those gearheads that are into these numbers. Last edited by GCinFLA; 01-12-2017 at 01:06 AM.. |
01-12-2017, 05:53 AM | #99 | |
Rep 72
01-20-2017, 12:47 PM | #101 |
Rep 418
^very nice yo!
01-20-2017, 07:29 PM | #104 |
Rep 1,986
01-21-2017, 12:37 AM | #106 | |
Rep 1,986
FWIW, you are at least the second F3x OEM 437m owner I've read on forum state they ditched the 275 rears. Was it comfort of ride or something else? Btw, your car looks great. |
01-24-2017, 07:52 PM | #107 | |
Rep 5
It looked to buggy like is that makes sense, also I am considering lowering springs, I am not sure if I am now, but car would rub on 275's, I urgently needed rear tires and I just closed my eyes and went for 265's, and looks much better, no obvious difference in ride comfort, and looks lower from the rear. I would not recommend 275's, My wheels came of a f80 m3 therefore has 275s fitted. |
Kabrich355.00 |
03-26-2017, 06:35 PM | #110 |
Rep 507
My turn to contribute
KW SC and stock RFTs |
FeelinBlessed226.50 Stoo134.00 Sheharyar_rr236.50 mtechnik3415.00 Haddock!4.50 TBN54426.50 DG20968.50 PJJD101.00 cdwalls703.00 terryd5150507.00 misguided_will56.50 BeyondAddiction3.00 |
