BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Power to dashcam
      12-21-2016, 04:55 AM   #1
sd_dracula
Drives: 2020 G20 330e
Power to dashcam
Hi guys
I have ordered a Blackvue DR650S-2CH dash cam kit and I also want to install a Blackvue Power Magic Pro to my 330e.
Question, is this an issue installing it in a hybrid due to battery drain etc?
Does anyone know how to install the magic pro to the 330e? Specifically looking for what fuses I need to tap into.
Thanks.
      12-21-2016, 07:02 AM   #2
BMWZ4
BMWZ4's Avatar
1907
Drives: '23 X1/'23 Allroad Progressiv
I can't speak to your 330e battery question or what fuse # to use, but....you could try this solution and tap to your mirror. Super easy. I've tapped my mirror for my radar detector.
https://store.blendmount.com/mirrort...aps-p3625.aspx
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
      12-21-2016, 11:59 AM   #3
sd_dracula
Looks like a real clean solution.
Will this provide parking mode recording for the Vue or only recording while driving?
And will this be ok for a Blackvue DR650s-2CH to power?
      12-21-2016, 12:08 PM   #4
fusion0389
Drives: 2016 328i xDrive M Sport
Is it really as simple as the picture? No splicing or wire cutting? It appears that you just insert the metal ends of the cable into the backside of the connector for the mirror and presto, power to the dashcam. Seems too simple haha
      12-21-2016, 01:00 PM   #5
BMWZ4
BMWZ4's Avatar
1907
Yes in fact your model is available in the drop down choices. For the recording while parked not 100% sure but you can enquire on the site.
      12-21-2016, 01:02 PM   #6
BMWZ4
BMWZ4's Avatar
1907
Yes that simple. No slicing or cutting etc. Took me less than 10 minutes. If your vehicle is a 2015+ you'll be plugging into the rain sensor.
      12-21-2016, 06:56 PM   #7
sd_dracula
Awesome. Do you have to take off the mirror plastic housing where the cables are?
      12-21-2016, 07:12 PM   #8
BMWZ4
BMWZ4's Avatar
1907
Exactly. You just split the seam slightly and pull apart, pretty hard. Might feel like you'll break it but shouldn't. Mine didn't and I did 3 times!
Worst case if you broke the clips on one side of the mirror cover...order a new one. I checked before I started and I think it was around $50...
You'll be fine
      12-22-2016, 02:07 AM   #9
Y0tsuya
Drives: 2015 M235i 6MT, 2016 340i 8AT
The tap is basically a flat piece of metal held there by friction. If you're handy with a soldering iron and don't want to spend $20, just flatten then tin a piece of wire to get the same thing. That's what I did.
      12-22-2016, 06:17 AM   #10
fusion0389
I'll have to double check, but I thought my 2016 had a cable plugging into the rearview camera. Do you have any pics of the installation process you followed?
      12-22-2016, 06:42 AM   #11
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
Search for a thread by Vivalareagan when he first got his car lots of pics and detailed instructions. It's literally a 5 minute piece of cake job a child could do it.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
etinifni203.00
