02-25-2015, 02:53 PM | #23 | ||
Rep 1,349
Drives: BMW F80 M3
02-26-2015, 07:02 AM | #24 | |
Rep 6,990
So Eurocharged has a flash tune for the F30? How were they able to crack the encryption when nobody else, including Dinan, has been able to?
02-26-2015, 07:12 AM | #25 | |
Rep 6,990
02-26-2015, 08:04 AM | #26 | |
Rep 1,349
Drives: BMW F80 M3
Tube and Fin design intercoolers usually flow better. Due to having rounded tubes that generate less resistance compared to Bar and Plate that have rectangular tubes that cause more resistance which creates more turbulence and more pressure drop. Of course this effect is also responsible for cooling the air to a certain extent. FYI I tested a 5'' bar and plate vs the stock tube and fin fmic and compared a single run 60-130 gps measured time. While the IAT on the bar and plate was better it was also flowing worse. Enough flow drop to make the 60-130 .5 tenths slower. In normal circumstances you don't run your turbo at 100% dutycycle. But I was testing the turbo at 100% dutycycle to compare pressure drop on the FMICs. The stock fmic allowed 21 psi midrange and 18 psi at 6k and 17.5 psi at 6.5k rpm. The other one only 18 psi midrange, 15.5 psi at 6k and 14.5 psi at 6.5k rpm. So in the above scenario the FMIC that was cooling better also performed worse. In normal situations you run your turbo at 20-50% dutycycle and if your new fmic flows worse than stock you will get the same boost at slightly higher dutycycle (meaning your turbo has to work harder to give the same boost at the intake manifold). This would on the long run of course improve performance. Of course I agree a good FMIC and sportcat are MODS you should do to support additional power. But for most people driving on the streets doing the occasional pull through 2 or 3 gears it's not needed. That being said ofcourse I have a FMIC and sportcat on my car even with meth. Simply because I want the best for my car. However I still stick to the point that a FMIC by itself won't cause any performance gain doing a single 60-130 mph pull. Simply because the stock fmic won't heatsoak during a single run. Last edited by PeterPure; 02-26-2015 at 08:40 AM.. |
02-26-2015, 05:44 PM | #27 | |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
yea, some companies have been doing them since late december, but have pretty much been focusing on the M3/4/5's, and theyre mostly in europe, they have to remove the ecu to basically get the password that enables them to then go thru the OBD port to tune the car. I think AMS has the capability also.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
02-26-2015, 10:30 PM | #28 | ||
Rep 1,349
Drives: BMW F80 M3
02-26-2015, 11:21 PM | #29 |
Rep 1,961
02-26-2015, 11:23 PM | #30 |
Rep 1,349
Drives: BMW F80 M3
I think jasons 435i ewg runs E30 mix without issues.
02-27-2015, 02:51 AM | #31 | |
Rep 648
You're right about the DME/torque limitation, but you know when tuning on newly cracked DME's we start from scratch. We also experienced the different limitations after I mounted my own upgraded turbo. Many of those limits were discovered daily. If you're tuner gave up I'm sorry. (just for fun we raised the speed limitation to 350km/t ) Krelle
Ist der Motor kalt, Gib ihn sechs ein halb.....
02-27-2015, 10:24 AM | #32 |
Rep 176
I am definitely interested in doing this. I would prefer something like a gt30 but I am not sure if one could even fit. I am just getting into the 335i coming from stage 3 mk5 gti. I wonder what this pure stage 2 would be at w/ stock fueling. Hopefully around 400whp
02-27-2015, 12:06 PM | #33 | |
Rep 1,961
02-27-2015, 12:37 PM | #34 | |
515
Rep 1,063
02-27-2015, 03:15 PM | #35 | |
Rep 3,404
Still, modding these cars beyond the most basic of bolt-ons produces highly diminishing returns. Even with the thousands you'll spend on an intercooler, turbo, exhaust, fuel, etc., anything over 450 RWHP is a pipe-dream. In other words...an almost stock M3/4 (which will still be faster). Good luck. |
02-28-2015, 03:17 AM | #36 | |
Rep 648
Its pretty easy once you find them, but the time spend investigating... But it's a one time job and those WHO find all get's to make a lot of tunes before otters find out. PS the mike_l guy is Wong! You Can alter the exhaust side as well, otherwise I chanced turbo just to waste time /Krelle
02-28-2015, 06:04 AM | #37 | |
Rep 71
I have the PURE stage 2 turbo upgrade. Just got my car back yesterday, and from what I'm told, have the fastest F30 in the world as of today. Only due to the fact that I'm the first F30 they've worked on. And yes, they were able to fabricate the N55 high flow inlet so that it fit my car. My mods are in my sig.
Here is what they said about my car and link to thread: http://www.e90post.com/forums/showth...1092138&page=8 Quote:
02-28-2015, 09:05 AM | #38 | |
515
Rep 1,063
02-28-2015, 09:06 AM | #39 | |
515
Rep 1,063
02-28-2015, 01:10 PM | #41 | |
Rep 1,961
Before you ever say I'm wrong, you better do your damn research. Last edited by Mike_L; 02-28-2015 at 01:17 PM.. |
02-28-2015, 01:57 PM | #42 | ||
Rep 1,349
Drives: BMW F80 M3
02-28-2015, 02:55 PM | #43 |
Rep 1,961
02-28-2015, 04:56 PM | #44 | |
Rep 648
We were on it for day's /Krelle
