BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Help on reset short circuit lock up REM
proTUNING Freaks
      02-12-2024, 09:19 AM   #1
cscyxl01
Drives: BMW 328i
Question Help on reset short circuit lock up REM
My left real signal light in not working. I am able to use tool32 to read the status_kurzschlussabschaltung for REM_20, it shows STAT_KS_ABSCHLTUNG_FRA_H_L = 1 while FRA_H_R = 0. But there is no reset to clear in tools32.
I am able to run ESYS, but I do not know where to find related code to change. Does anyone know how to fix this?
Thanks.
      03-31-2024, 04:53 PM   #2
Alpine-F80
Alpine-F80's Avatar
Drives: 2017 M3
Wondering if you ever solved this? I’m having a similar issue with my trunk latch that was defective & causing short code. Replaced latch, cleared all codes/faults, and no codes since but latch still doesn’t work unless I manually trigger it in ISTA. I’m stumped…guess I’ll try a new REM next…
      03-31-2024, 10:24 PM   #3
cscyxl01
Drives: BMW 328i
No, I do not know how to reset it.
      04-01-2024, 04:21 AM   #4
Jimmert
Drives: BMW 420i F36
Bimmerlink also has a reset option nowadays.
      04-02-2024, 10:34 PM   #5
sdbmwcoding
Drives: BMW M3
Use ista, it’ll reset it for you. Last time I reset REM short circuit I was only able to find reading short circuit counter but didn’t remember finding a reset from what I remember. But it was a rushed job so maybe I didn’t look long enough. You can 100% reset it with ista though
      04-30-2024, 10:02 AM   #6
JuniorTech
Drives: F30 340i Msport & G05 X5 40i
Using Dr.Gini
F30 : Bowers Wilkins, ID6 Touch, RSE , 3AG, 6WB, 508, 322
G05 : 5AU, 2VW, 2VH, 5DN, 6F1, 610, 7M9, 3AK
