02-29-2016, 03:06 PM | #47 |
Rep 906
good luck buddy! keep everything well documented just in case you need to take any other actions later down the road (like possible lemon or further repairs) you should understand your lemon laws just in case because of time limitations.
2016 X3 35i M-Sport
2019 440i Coupe M-Sport - Retired 2018 330i Sedan M-Sport - Retired 2015 428i Gran Coupe M-Sport - Retired |
02-29-2016, 03:12 PM | #48 | |
Rep 67
02-29-2016, 03:16 PM | #49 |
Rep 4,323
I'd ask for a different car - a new engine shows up on your VIN and will be lovely to deal with when you trade it in.
02-29-2016, 03:16 PM | #50 |
Rep 100
Check it...
B58 Engine Recall - BMW Service Bulletin SI B11 26 15 Engine B58 Engine – Check and Replace Crankshaft Guide Bearing Model F30 3 Series Sedan with B58 engine and manual transmission. Situation The upper crankshaft guide bearing may wear out prematurely. The wear on the upper guide bearing can cause the clutch pedal to malfunction during shifting. The Engine Malfunction warning may be illuminated and a fault will be stored in the DME memory for the crankshaft sensor. Noise may be heard from the lower engine and transmission bell housing area. If the crankshaft guide bearing or crankshaft is found damaged during the inspection then the engine must be replaced. Engine damage is a rare occurrence. Affected Vehicles This Service Action involves F30 vehicles produced from July 2015 to November 2015. Vehicles which require this Service Action to be completed will show it as "Open" when checked by your local BMW dealership. Affected Vehicle VINs WBA8B7G57GNT70413 WBA8B7G58GNT70405 WBA8B7G51GNT70410 WBA8B7G56GNT70404 WBA8B7G55GNT70409 WBA8B7G54GNT70403 WBA8B7G5XGNT70406 WBA8B7G52GNT70416 WBA8B7G51GNT70407 WBA8B3G59GNA92609 WBA8B7G53GNT70411 WBA8B7G58GNT70419 WBA8B7G50GNT70401 WBA8B7G56GNT70421 WBA8B7G59GNT70414 WBA8B7G59GNT70400 WBA8B7G50GNT70415 WBA8B7G56GNT70418 WBA8B7G52GNT70402 WBA8B3G53GNA92606 WBA8B7G55GNT70412 WBA8B7G53GNT70408 WBA8B7G5XGNT70423 WBA8B7G5XGNT70440 WBA8B7G53GNT70439 WBA8B7G53GNT70425 WBA8B7G59GNT70431 WBA8B7G57GNT70430 WBA8B7G54GNT70434 WBA8B7G52GNT70433 WBA8B3G50GNA92613 WBA8B7G58GNT70436 WBA8B7G56GNT70435 WBA8B7G55GNT70426 WBA8B7G51GNT70441 WBA8B7G51GNT70424 WBA8B7G58GNT70422 WBA8B7G50GNT70432 WBA8B7G5XGNT70437 WBA8B7G55GNT70457 WBA8B7G51GNT70455 WBA8B7G53GNT70456 WBA8B7G5XGNT70454 WBA8B7G57GNT70458 WBA8B7G56GNT70466 |
02-29-2016, 03:33 PM | #53 |
Rep 548
Drives: 2011 E90 M3 ZCP
Interesting to see it's only affecting manual transmissions and only a few months of last years builds. Sounds like they caught the problem and fixed it months ago.
02-29-2016, 03:39 PM | #54 |
Rep 326
02-29-2016, 04:27 PM | #57 | |
I'll Kung Fu Panda your ass
106
Rep 2,100
'16 F30 340 XDrive - AW-Lighting & Track Packages. The FIRST drive was awesome....
02-29-2016, 04:31 PM | #58 |
Rep 326
My 6mt 340ix went into production at the end of November, but finished production on/has a production date of 12/2/2015.
02-29-2016, 04:37 PM | #59 | |
Rep 14,121
Drives: G82 M4C X-Drive
If the crankshaft guide bearing or crankshaft is found damaged during the inspection then the engine must be replaced. Engine damage is a rare occurrence. " I'm not a gearhead, but do the crankshaft guide bearings operate differently on auto vs manual?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
02-29-2016, 04:44 PM | #61 | |
Fool
1857
Rep 3,542
02-29-2016, 04:49 PM | #62 |
Rep 6,297
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
It does create some questions for all B58 motors, but my guess is the manual transmission puts some specific stress that wasn't anticipated or accounted for.
It could even be a certain batch of parts from a supplier that had a manufacturing defect. |
02-29-2016, 04:57 PM | #63 |
Rep 67
I'd be more concerned if I owned the car. if any of you own the car and go thru this recall, I'm curious what you plan on doing as far as approaching BMW with concerns for the future.
02-29-2016, 05:09 PM | #64 |
Rep 548
I'm thinking this was a defective part, considering that link above indicates that only 45 cars were affected. Seems to have been corrected a while ago.
02-29-2016, 05:16 PM | #66 | |
Rep 548
I do know for a fact that on some engine designs, having a manual transmission puts more stress on the craftshaft when the clutch is depressed and that lateral force is exerted against the flywheel/crankshaft. It's called "crank walk" if I'm not mistaken. Again, this could totally be offbase as to what's happening. |
