BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Stock F30 335i Axle Back Exhaust Muffler Modification and Dissection
      04-15-2013, 11:30 PM   #23
FreddyG
Drives: 2012 335i Luxury Sedan
Thanks for being the guinnea pig and trying this out! I'm looking forward to the results!
      04-16-2013, 09:12 AM   #24
Roki_014
Drives: 2024 i5 M60
Originally Posted by dd1981 View Post
As always, my curiosity gets the best of me. I planned on doing this for some time now, pretty much since I installed my M perfromance axle back.
It goes back to when I saw a few people modifying the e90/92 M3 exhaust by replacing the perforated tubes, and the result was an amazing sound for very few $$$.
The plan was to replace them on the f30 muffler and reinstall it on my 335i and see what the result would be. But due to chamber 1 and the shape of the pipe this seems pretty much out of the question, as there would be way to much custom work and too much labor involved. Im trying to keep this as simple as possible.
So plan B is to open up the muffler all the way, so that I have access to both top and bottom, and spot weld every single hole individually in chamber 1 and 3.
Ill update as I go.
e jedva cekam da cujem, sta mislis da li ce imati problema sa warranty, can they even find out you did anything since its on the inside of the exhaust, I guess they will notice it sounds different
      04-16-2013, 09:17 AM   #25
Koer
Drives: F15 X5 2014 Sec. 50i
Already welded mine in, left half of the holes open, half welded.
Sounds deeper and more gurgly!
No drone at all!
      04-16-2013, 10:13 AM   #26
Maz335i
BMW 4 Life...
Maz335i's Avatar
Drives: 2015 SO M3 (on order)
No drone at all!
Videos plz...and ASAP...
      04-16-2013, 11:37 AM   #27
buildbright
buildbright's Avatar
155
Drives: F80 M3 MG
No drone at all!
Great Job. You should not get any drone as long as you have the center chamber.
      04-16-2013, 08:12 PM   #28
Koer
Sorry for the holdup guys!
The process was only to cut into chamber 1 and remove half of the insulation and cover only half of the holes.
Living with the sound difference for a few days made me wish i had closed up the whole tube and removed the whole insulation from chamber 1. The positive side is, if you just want to go quietly about, it will only turn heads when you step on it. Considering i travel with my family all the time, the last thing i want is a lousy exhaust, i think i achieved a moderate grumpy sound with a touch of loudness, still without being intrusive at all! (with the music up you still wont hear a thing)
WARNING! the wig stuff is fiberglass composite mix, dont breathe that stuff, dont touch that stuff, dont even look at that stuff, take it out and dispose of it, it WILL become airborne after a while. You have been warned.
And finally, i dont like uploading things to youtube so have the video file instead!
Filmed it from underneath but the sound is identical standing from behind
http://ubuntuone.com/0MpZ0XSngWlqqBLfHvOV1S
All in the name of science!
      04-16-2013, 08:34 PM   #29
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Man that freakin bad a$$..... Hmmmmm.... I'm pretty handy and do all of my own mods but I've never welded..... Maybe time to buy a new tool?
I am a little curious why you only opened the 1st chamber up and not all three like the OP...
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      04-16-2013, 08:45 PM   #30
Koer
Because we used gas to cut through the muffler, leaving a huge gap to fill when soldering.. That meant a lot more $$$ to close it all up. And really i don't see a point on opening the whole thing just to get to chamber 3... and you might screw up the chamber divisions.
The sound difference is quite noticeable with the few things i did, as you can see in the video.
      04-16-2013, 08:47 PM   #31
buildbright
155
Drives: F80 M3 MG
Great Job! Sounds Good. Thanks for the wig tip.
      04-17-2013, 09:39 AM   #32
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
Čekam samo da mi ga drug vrati pa cemo svi cuti. Što se tiče garancije, neznam nisam baš siguran, nebi rekao da bi unistilo garanciju. Ofarbacu auspuh crne boje da se neprimeti gde je varen.
No drone at all!
This gives me high hopes that it will sound good. Glad someone else tried it as well. I'm definitely welding all the holes and leaving the insulation. Can't wait.
FBO-PS1 and stuff
      04-17-2013, 03:05 PM   #33
Koer
What i think could be a valid debate is wether leaving all the insulation in and soldering the holes will have any effect against taking it all out.. Maybe less drone that way? I know for a fact that leaving the holes and taking the insulation out is a bad idea..
      04-17-2013, 04:38 PM   #34
4.8 E70
Montenegro
24
Drives: Alpina B7
Bes brige za garanciju. Ja sam ponejo kola bez mufflera i nista ni su rekli. Nema nista da se brenete.
      04-17-2013, 09:09 PM   #35
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Odlično drago mi je da to čujem. Mislim da samo brinu za tune a ostalo je u redu.
FBO-PS1 and stuff
      04-26-2013, 02:29 PM   #36
buildbright
155
Drives: F80 M3 MG
Did you get yours done yet?
      04-27-2013, 05:20 PM   #37
FreddyG
What language is that?
      04-27-2013, 08:04 PM   #38
mikew2069
mikew2069's Avatar
413
Freaky Deaky Dutch
      04-27-2013, 10:25 PM   #39
Jadar
Dejan
Jadar's Avatar
Serbia
1753
I'm suppose to get it back Monday, just in time too, the weather is suppose to be really nice for the install.
Freaky Deaky Dutch
Serbian. No Dutch, but it would be awesome knowing Dutch or German.
FBO-PS1 and stuff
      04-28-2013, 08:16 AM   #40
mikew2069
mikew2069's Avatar
413
I was totally kidding - 'freaky deaky dutch' is a quote from an Austin Powers movie. I had no idea what you guys were speaking
BM3/H&R/Borla
      04-28-2013, 11:10 AM   #41
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Austin "danger" Powers lol. Serbian/Croatian sounds a ton like Polish or Checzh. Even Russian, but I can't understand a word Russians say.
FBO-PS1 and stuff
      05-03-2013, 11:23 AM   #42
Roki_014
Drives: 2024 i5 M60
any updates?
      05-03-2013, 11:51 AM   #43
The Nerd
The Nerd's Avatar
426
Drives: 22 M3 Comp xDrive
Yes it was just for sound deadening. It felt like a wig lol. Not sure what the material was. I think as for drone there will be some because even my m perf muffler gets a tad bit but only when driving in comfort or Eco when low rpm and all gears are in play. Ill post up as I go, I figure about another a week or so ill have it wrapped up.
You and are thinking alike . I want to see if this works and ill sell my m perf muffler as well. That's a nice move with the muffler tape and testing it. Reading your post and your past experience in doing this really makes me think I'm doing the right thing and it will be a success. Ill defoentely post up pics and sound clips.
So there IS some drone with the M Perf Exhaust (as mentioned above in comfort and ECO mode)???
      05-03-2013, 03:33 PM   #44
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
I believe he gutted it that's why...I don't get any drone.
SOLD: 2012 335i Mineral Gray
