BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Guide to Upgrade 6.5" Screen to 8.8" Screen HU_ENTRYNAV
      07-03-2016, 10:58 AM   #23
bill_f31
Drives: BMW F31 M Sport
Originally Posted by TePee View Post
The LCI 8,8" screen won't work with your HU Entrynav! It uses different voltage. You have to install the pre LCI screen.
Normally when you code 8,8" screen and broad display everything will work in proper way, including split screen etc.
The question is whether this is the case or not when you have Integrated Navigation?
Thank you for your answer.
I had no idea about the different voltage.
According to realoem.com, the LCI screen is compatible with the pre-LCI models,but I highly doubt it,that's why I posted the question.
It seems that since now nobody with the Integrated Navigation has installed the 8,8 screen,but someone has to take the first step. Let's see...
      07-03-2016, 02:06 PM   #24
TePee
Drives: F34 LCI MY2019
The LCI screen is not exchangeable with the pre LCI screen! I don't use realOEM but other part catalogs including BMW itself prove it too.
Check here:
http://bmwfans.info/parts-catalog/65509387453/
Pre LCI screen works with 7,5-9V. LCI screen has normal 12V.
So just buy a pre LCI screen for your Entrynav and you will be fine. Further you will save a lot of money als LCI screens are rare and much more expensive.
      07-03-2016, 02:19 PM   #25
bill_f31
Check here:
Thank you,mate. Really appreciate your help.
Do you think that the 8,8 screen will cooperate fine with the BMW Integrated Navigation system?
      07-03-2016, 02:30 PM   #26
TePee
You're welcome
Sorry I have no clue about Integrated Nav and 8,8". But it is an interesting project. As you wrote someone has to be the first one: trial & error
      08-20-2016, 05:49 PM   #27
Smee
Smee's Avatar
505
Drives: BMW M4 F83
hello i want to give this upgrade a try but i have a few questions.
what is LCI and how do i know if i have LCI or not?
65509292248 is the part number on here. i have checked Ebay and here is a link to one. http://www.ebay.co.uk/itm/1621638321...%3AMEBIDX%3AIT
when checking the pictures i can see the 9292248 as the part number but where is the 6550 part in front of it?
      08-24-2016, 05:01 PM   #28
dbravo90
dbravo90
Drives: 440i
Not familiar with coding such as "HU_ENTRYNAV" or terms but if i just ordered a 2017 440i xdrive with no navigation will this switch be possible?
      09-09-2016, 08:30 PM   #29
MarkoSK
Drives: BMW G20 330eX
Hi, I'd like to retrofit a 8.8" screen. I have a F34 LCI (built 08/2016) with Radio Professional (no nav). I should have HU_ENTRYNAV.
Can anyone tell me which screen should I get? I've seen two screens:
9292248 -> pre-LCI screen, 7.5-9 V
9387453 -> LCI screen, 12V
Which voltage does my HU use?
Thanks!
Funci1.50
mthsmr0.00
      09-10-2016, 09:44 AM   #30
TePee
I have 2016 pre LCI F34 with HU Entrynav and the correct 8,8" screen was 7,5-9V Pre LCI screen 9292248. As the LCI uses Entrynav as well I guess it should be the same.
      09-10-2016, 07:15 PM   #31
MarkoSK
Thanks, I'll try the pre-LCI screen then. What eSys and psdzdata versions did you use to code your car?
      09-20-2016, 05:31 PM   #32
catharsis
Drives: e60
just to confirm as posted elsewhere pre-LCI screen will work on an LCI F30 - confirmed by doing it :-)
      09-20-2016, 05:36 PM   #33
MarkoSK
It seems as though both screens work. The pre-LCI one however has a more blueish tint - see this post for details.
      10-10-2016, 05:25 PM   #34
taranfx
Z4 35is
taranfx's Avatar
Drives: 2011 Z4 35is || 2016 435i
My screen is base 6" screen with no navigation. Model: F30 2015. Can a car be called 2015 and parts from 2014?
      04-02-2017, 11:46 AM   #35
aus2610
England
Drives: BMW 118d Sport
Coming to this quite late in the game as I just got the car.
So I have 05/2016 118d Sport F20 with S606 Business Nav, S654 DAB Tuner, , S6NH normal bluetooth. Checked via a Vin Decode.
I am reliably informed that equates to HU_EntryNav.
It also has S698 Area code 2 for DVD...although it doesn't play DVDs..WTF?
So I understand biased on dates, etc, that I can just take off the 6.5 screen and replace with an 8.8 screen, do the two lines of recoding (via bimmercode) and the new screen will work...just bigger.
Can the OP tell me what the benefit is? Does it simply show the same screen but bigger, or is there more map on screen, more other details.
Has anyone been able to make DVDs work, even from USB?
I would love the bigger screen but the cost means I could do with knowing whether it will change anything that will make it worth doing.
Thanks
      04-02-2017, 12:01 PM   #36
Smee
Smee's Avatar
505
Drives: BMW M4 F83
It works like you have pro nav. So split screen is added
      04-21-2017, 10:14 AM   #37
i3_bob
Drives: 2015 i3 REX
10.25" screen?
Could one install the 10.25" instead of the 8.8?
My i3 has the standard NBT (s606) with the 6.5" screen - i3s with the tech package have the NBT Pro (s609?) with the 10.25" screen. Would the 10.25" screen only work with the NBT Pro?
      05-29-2017, 09:13 AM   #38
tony_i
Drives: F30
Anyone recommend any coders in the West Midlands as I have fitted the screen just need it coded in.
Also on the Pre-LCI will the 8.8 screen work straight away - I.e plug and play but just require coding so the correct size & resolution or will it only work once coded? As I've purchased a screen of Ebay - fitted the cabling to check it works. But the screen is just blank... so unsure if it will be o.k once coded or I'm got a naff screen ?
      05-29-2017, 01:19 PM   #39
isloth
Drives: F30
Which exact production date is your F30?
HU Entrynav was introduced from 7/2014 on.
hello TePee, is it safe to say I have a HU EntryNav.. my car is model year 2015, with a production date I think in 9/2014 or 10/2014. I just have a regular screen without navigation package.
      05-29-2017, 04:07 PM   #40
MarkoSK
You should be ok. Both the pre-LCI screen and LCI screen should work in your case (HU_ENTRYNAV). Click here for more details.
      05-29-2017, 04:11 PM   #41
MarkoSK
A 8" screen always requires coding if you have a smaller 6.5" screen. It will be blank unless you code it.
PS: The coding part is easy (search these forums), you just need to get a ENET cable ($20) off eBay.
      05-29-2017, 05:20 PM   #42
isloth
Drives: F30
THANK YOU MarkoSK!
      05-30-2017, 04:49 PM   #43
tony_i
Drives: F30
Cheers guys thanks for your help. ??
      05-30-2017, 05:14 PM   #44
MarkoSK
You're welcome. Read through this thread for more info.
