01-09-2014, 10:05 AM | #177 |
Rep 40,789
It should if you used a date before 0713.
01-11-2014, 07:31 AM | #180 |
Rep 458
Arrgghh. Talk about frustrating. It looks like bimmertech have either sent me a faulty or the wrong Emulator for my car.
I tried fitting it, and it is clear the emulator is missing what look like some of the most important pins on the cable. The knurled black and thick green cable which are in the top right below. With the Emulator in place Nav is enabled, but nearly everything else is broken. There is no sound, volume controls do nothing on unit and on wheel, it won't connect via bluetooth any longer either. It also will not VO code any longer, it just reports the usual error you get when it can't find the ECU to code. I've had to remove it and put it back without the Emulator and everything (apart from Nav) is now working again. Can anyone tell me what these two connections do? |
01-11-2014, 07:42 AM | #181 |
Rep 458
Just found this for other BMW radios. Looks like these are the MOST connectors unless I am mistaken.
http://www.bavariancoding.com/wp-con...New_Series.pdf The Emulator came with no instructions, not sure if it should have done. Am I supposed to remove those two cables from the existing connector block and plug them direct into the other end of the emulator (NBT end)? |
01-11-2014, 09:35 AM | #182 |
Rep 40,789
Bro, you paid good money for this thing. You ought to get instructions and support.
Incidentally, you never updated me in iDrive Controller issue? Were those 4 FDL Codes set wrong based on the VO Date?
01-11-2014, 09:42 AM | #183 |
Rep 458
Thanks Shawn. Went back to bimmertech and they told me to move the MOST connector into the NBT side. Done that and it is now working fine.
I am going to try those FDL codes now. I've been waiting for the emulator before fixing. I think this will probably work, because the NBT has Touch in the Settings menu, so I suspect it is enabled. PS if you FDL code something, I presume if you later VO code that ECO those changes will be lost? |
01-11-2014, 09:46 AM | #184 |
Rep 40,789
Ahh, very good then.
01-11-2014, 10:14 AM | #185 |
Rep 458
Damn. I can't seem to FDL code it with the Emulator installed. It seems to do the same as when I had the MOST cable installed. I get the following error:
[HU_NBT - 63] finalizeECUCoding error [HU_NBT - 63] There was an error during TAL execution, please check the log files. [Exception - HU_NBT - 63] job failed with negative response error: code: service returned global negative response description: Service WDBI_CPS returned a negative response with response code requestOutOfRange; ECU: HU_NBT_63_ETHERNET severity: ERROR |
01-11-2014, 10:58 AM | #186 |
Rep 458
Been in contact with bimmertech. It appears they tell me I cannot code the NBT with the Emulator installed, but they can do it for me remotely!
He has had to authorise is coder to do it for me remotely, though how he will do this I have no idea. I really don't like the idea that somebody has control over what I can and cannot do on my car. Especially given I paid for £300 for this Emulator when I could have got one on eBay for £60. Has anyone come across this before? If I return it, can I flash the NBT with my own VIN. If I did that what sort of costs would I be looking at to get Maps and Apps FSC codes enabled? Last edited by steddyman; 01-11-2014 at 11:06 AM.. |
01-11-2014, 11:29 AM | #187 | |
Rep 40,789
Are you not able to FDL Code it with the Emulator disconnected? I know VO Code won't work because of VIN, but I would think FDL Coding should be possible.
01-11-2014, 11:37 AM | #188 | |
Rep 458
I will be able to FDL code it with the Emulator removed, but it takes me a while to get the Emulator out and it was dark again when I realised it wouldn't work.
When I challenged why I couldn't code the car myself, this is the response I got: Quote:
I haven't finished with this NBT yet. Office (txt's, etc) and Apps are not working currently and I will want to update the maps. I don't want to find I paid more than £300 for a device that cripples my coding options. Very annoyed at the moment. |
01-11-2014, 11:57 AM | #189 | |
Rep 40,789
tcm801 is nothing more than Total Commnder File Manager for transferring the files they need. E_F_Remote apps is nothing more than a few EDIABAS files (.prg) that they need to do their coding work. Assuming Head Unit has or will have a 9C 6NR Apps FSC Code, you need to make sure that besides just coding the 4 iTouch FDL's that for BMW Apps, A4A_REMOTE_APPS = aktiv and CONNECTED_DRIVE = aktiv is coded, and for Office, MACRO_PIM = aktiv is coded. .
01-11-2014, 12:22 PM | #190 |
Rep 458
Do you think I should return this Shawn? I am very uncomfortable with anyone having this level of control over something installed in my car.
If I do return it, what are my other options to get the system I am looking for? Do the cheap emulators you referenced before not have this problem? If I pm you are you able to let me know what sort of prices I would need to pay to get all this enabled with my cars Vin? |
01-11-2014, 01:05 PM | #191 |
Rep 88
I don't believe they can disable coding with their emulator, but that is BS if they do that. You paid premium and it should allow you to do what other emulators can. Not all socket seem to be connected with their cable, and is likely why it's preventing you from coding. The pre-wired emulator I got has wires on all socket.
I would return that junk and get it from eBay instead. Get the pre-wired ones. It'll costs you more but you won't have to splice and fight with the short cable. |
01-11-2014, 01:54 PM | #192 |
Rep 458
Bimmertech are now telling me all Emulators would disable coding due to the way they work. Anyone got experience of different Emulators that they have been able to continue coding?
01-11-2014, 02:45 PM | #193 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
I removed the legal disclaimer and changed my startup screen last night with no issues at all.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
01-11-2014, 02:50 PM | #194 |
Rep 40,789
This is ridiculous. If coding works with other Emulators, it should work with theirs too, and if it does not, one can only assume it is by design that way, because it is not a technological limitation. I don't get it.
01-11-2014, 03:33 PM | #195 | |
Rep 40,789
I doubt I would ever go OEM Activation though. For OEM FSC Codes, you are looking at around $700 for Nav, $700 for Voice, and $250 for BMW Apps. NBT also has an additional FSC Code for Text-To-Speech, but I have no idea on the cost of it.
01-11-2014, 04:03 PM | #196 |
Rep 1,976
Just return the emulator. No use in using something that's going to bring you more trouble.
The one I have never interfered with me FDL coding anything so it's not true that all emulators are like that. |
01-11-2014, 10:19 PM | #197 | |
Rep 88
I can do both VO and FDL coding on my retrofitted NBT with hardware emulator. Even if bimmertech promises to do lifetime FDL coding for you for free, I wouldn't keep it |
01-12-2014, 12:17 PM | #198 |
Rep 458
I am not happy I cannot code it myself, but Patryk and Men from Bimmertech have been more than generous and fair in helping me resolve these issues via remote coding. I can understand why there kit costs more with the support they are giving.
I think if I can get all my issues resolved then I will keep it and would actually recommend the Emulator. Still I have the following problems, don't know if anyone can help here: 1. I have rewired the USB by rotating 180 degrees on the NBT then swapping the Data+/- and 5v/Gnd signals in a USB extension cable. USB keys and Android phones work fine but for some reason any iPhone I have tried, just constantly connects and disconnects about 3 times per second. 2. The Office functions never show me any messages on the phone. All my contacts are there, but it always reports no messages. 3. The BMW Live does not work, though it is enabled. It also reports there was a problem communicating with the network. It is paired with my phone and has a 3G connection. Appreciate any help and advice. |
