06-20-2018, 11:35 PM | #1 |
Rep 7,484
19" tyre pressures. Suggestions?
What are yours set to?
I tried 35 rear and 34 front and for a while it felt okay but don't think it has helped fuel economy much. Thanks |
06-21-2018, 02:42 AM | #3 |
Rep 922
After a bit of reading on these forums a while back I came to the conclusion that the most widely accepted pressures were;
36 PSI fronts 38 PSI rears That's what I run now.
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs.
06-21-2018, 03:04 AM | #4 | |
Rep 131
Is that fine for x-drive too? |
06-21-2018, 03:05 AM | #5 |
Rep 2,444
Drives: 2018 630iGT sport
Unless you're running different dimensioned wheels and tyres from stock (makes no odds if the tyres are run flat or not) , just use those stated on the plate on the drivers door shut.
06-21-2018, 03:58 AM | #6 |
Rep 922
I have X-Drive, seems to be fine for me?
spansar51.50 |
06-21-2018, 07:43 AM | #9 | |
Rep 548
I used to run the lower door card figures on mine 35 PSI front & 38 PSI rear, until speaking with you (Dr Forinor) and now run 36 PSI front, which I'm finding better.
Current: 2017 F31 335d M Sport - Estoril Blue, ACS Sports Suspension (Springs & Dampers), Black Grill, HK Sound & some other bits'n'pieces
Gone: 2015 F31 320d M Sport Xdrive Auto |
Dr Forinor266.00 |
