09-01-2013, 03:11 PM | #243 |
Rep 1,436
09-02-2013, 01:18 AM | #245 | |
Rep 25
racelogic showes 5.8 0-100 racelogic with bms st2 map 2 + downpipe - 5.1 |
09-02-2013, 08:33 AM | #246 | |
Rep 25
yes compression is 11-1, where did you get 4.6 s? is it on map 7 ? i cannot drive on 7 map - ecu blocking the gas i think it's detonation, i'll try someday 7 map with 102 octane |
09-02-2013, 09:38 AM | #247 | |
Rep 1,436
0-60= 4.6 sec 1/4 mile= 13 sec. http://tl.acurazine.com/forums/showthread.php?t=883562 |
09-02-2013, 09:38 AM | #248 |
Rep 3,780
Too much ricey silliness diluting this thread topic. If mods read this, take all this 320i with unconfirmed BS Russian 320>328 tune stuff and create a separate thread for it.
10-10-2013, 03:43 PM | #251 |
Rep 185
Drives: 2022 X6M
10-10-2013, 07:51 PM | #252 |
Rep 37
Coworker told me to get something like this for my stock 328i, do I absolutely NEED to get the stage1 mod before I can even use the stage2? Thanks for any help.
10-11-2013, 10:14 PM | #253 |
Aviator
35
Rep 210
10-21-2013, 03:35 PM | #254 |
Rep 18
two questions:
Can someone point me to the installation guide for stage 2? It doesn't seem to be easily found And also, where to download new firmware for stage 2? Everything I find seem to be for the N54/N55 engine not the N20 |
10-23-2013, 09:43 PM | #255 | |
Rep 107
I just got stage1 and i have a e85gas station down the street and i always use 93aki....i would like to bring to +4 |
10-24-2013, 02:04 AM | #256 |
Rep 3,566
Best to buy it from the manufacturer as it's a purpose built cable.
10-24-2013, 06:40 PM | #258 |
Rep 1,248
I am a little bit confuse. I found a reseller and he is saying they only sell the stage 2 version. I was wondering why so. I thought you have to get the stage 1 to get the stage 2 or is the stage 2 already package as one unit... and is it final already or still in testing stage.
10-25-2013, 12:53 AM | #259 | |
Rep 886
10-25-2013, 02:08 AM | #260 |
Rep 1,248
10-25-2013, 02:25 AM | #261 |
Rep 886
I'm not familiar with your situation, but what I do know is that you have to modify the stage one harness and add in a few more wires to it and then it becomes a stage "two" harness. Along with the modifications to your stage one BMS harness you will also receive a new control box from BMS that your (now) upgraded harness plugs into. Those are the physical differences between the stage one and a stage two BMS tune.
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
10-25-2013, 03:33 AM | #262 |
Rep 1,248
^^ thanks for your help. But like I said I don't haver any tune whatsoever. So if I'm getting the full stage 2 am I gonna end up doing some rewiring like what you had to do or am I getting a product that's fully plug n play?
10-25-2013, 11:29 AM | #263 |
Rep 886
I believe you have to do the wiring regardless, aka the product is not plug and play when you receive it. I would contact BMS via email to confirm this though.
10-25-2013, 03:40 PM | #264 |
Rep 3,566
If the Stage1 was shipped prior to 5/31/2013 select "Needs Wires", or if it was sent after select "Has Wires". This refers to 4 extra add on wires used for Stage2. New N20 Stage2 systems (not upgrades) are listed under the N55 Stage2 tune.
