08-09-2014, 07:45 PM | #111 |
Rep 992
I know many people already have read this, but.
http://www.german**********/content....feet-of-torque If this source is reliable, n20 is a bit hopeless because putting a catless DP + any tune with slightly more aggressive map would easily reach 330 lbs-ft. Any thoughts? Edited: I see the url gets censored. Is it not a good source to refer? If so, please let me know. The title is: "BMW 2.0 liter four cylinder N20 turbo motor already having issues? Head cracks under stress above 331 pound-feet of torque?" |
08-09-2014, 08:06 PM | #113 | |
Rep 3,780
It was mostly debunked as a silly source.
BMS tuning has noted some( a couple) cars bending rods but at fairly high power levels. Quote:
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
08-10-2014, 07:15 AM | #114 |
Rep 674
I wouldn't trust this motor beyond a mild tune. It doesn't appear to be built to make the level of power that some people are looking for.
350 lb/ft tq in the N20/26 is equivalent to 525 lb/ft tq in say an N54/55, proportionally based on # of cylinders and displacement, which is a direct correlation to cylinder pressures (almost 90 lb/ft tq per cylinder & 175 lb/ft tq per liter). I don't see too many people trying to push these numbers on the N54/N55 or pretty much any stock motor for that matter, especially on pump gas. It doesn't seem like a good idea to assume the internals of the N20/26 can handle this much power, even with a good reliable tune. Just my .02 Last edited by TurboM; 08-10-2014 at 10:38 AM.. |
08-10-2014, 04:02 PM | #115 |
Rep 992
Does displacement vs max torque scale linearly? But yes, I would avoid getting close to that figures too. I guess N20 is nothing like the 1803cc 4 cylinder turbocharged motor in a group B Ford RS200 that pushed 440hp and 361 lb-ft at 23psi.(http://en.wikipedia.org/wiki/Ford_RS200)
08-11-2014, 09:34 AM | #116 | |
Rep 674
Nice reference to the 80's ford rally motor The N20/26 is far from a limited production motor meant for big HP. It is basically BMW's base motor meant to get good gas mileage without sacrificing power. Any motor running 17lbs of boost straight from the factory is not going to have a ton of room for improvement (yes, I know there are exceptions to this). I really think people need to take it easy with this motor or were going to see an increased number of failures popping up in the near future. |
08-11-2014, 10:15 AM | #117 |
Track Addict
99
Rep 242
FWIW, if you do a parts cross reference between the N20 and the S55 I think you'd be surprised at how many parts are identical between those engines, but different when comparing the N20 to the N55. It looks like BMW M took several bits of N20 technology and used it when creating the S55. The biggest difference (other than the obvious 4 vs 6 cylinders) is the connecting rods, which are made of a different material in the S55. I'm currently looking into if the S55 rods are a possible replacement for N20 rods. Size wise they are the same.
Driver, Ratchet Head Racing #93 BMW Z4
Club Organizer, Garden State Euros Motorsport Division 2014 Glacier Silver Z4 28i M Sport - See the build thread: http://e89.zpost.com/forums/showthread.php?t=950367 |
08-11-2014, 10:17 AM | #118 | |
Rep 297
08-11-2014, 10:30 AM | #119 | |
Rep 674
I'm just thinking that once people starting getting more into the stage 2 tune with alternative fuels making over 300wtq were going to start seeing a lot more issues than we are used to seeing comparative to that of the N54/55's. Only time will tell... |
08-11-2014, 12:51 PM | #121 | |
Rep 674
Keep in mind, generally speaking, the dealers want the work. They just want to make sure they are going to get reimbursed for it by BMW before proceeding. |
09-24-2014, 07:08 PM | #125 |
Rep 4,323
I bet you $50 they saw the DP (if it was still on) and that's what voided it..
09-25-2014, 01:39 PM | #126 |
Rep 1,554
I would agree with this as well. Who runs a down pipe without a tune? Very few if not any. I contemplated doing a DP but then i would have to get the JB4 to clear the code to keep the light off. No thanks...
09-25-2014, 02:58 PM | #127 |
Rep 1,436
I have dp, the JB4 is removed for a while now never had a CEL ever just a hidden code.
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
09-26-2014, 02:40 PM | #128 |
Rep 1,554
09-26-2014, 03:44 PM | #129 |
Rep 1,436
I can't conclude all the dp will not give you CEL but it's very odd as I have a friend that has ER and he didn't have CEL so far only hidden codes as well but I think it has to do that the car is assembled here and there is no absolute emission control where I live lol so maybe the sensor is meant to store it only as hidden and not show it on the screen
09-28-2014, 10:26 AM | #130 |
Rep 674
If BMW said you tampered with the software, I'm positive they've looked into the coding and since an engine replacement is $25k they definitely would comb through the issues and not just looking at the DP.
09-29-2014, 08:05 AM | #131 |
Rep 186
I have the dp, JB4 on map2 and meth... There is a few more in my country with that setup and the wagner fmic.
I am hitting way above 330 with no issues. Those dudes are definitely higher. |
09-29-2014, 06:39 PM | #132 | |
e92 - 335i
179
Rep 743
I am still a very conservative driver on a daily basis. I use the power when it's needed and on occasional spirited driving. Seraphblade, I would be interested in getting to know your meth setup. I am considering this as my next power mod. If you could PM me, that would be great. BTW, my company has a facility in SG in Jurong West. |
