12-16-2016, 08:43 PM | #155 |
Rep 255
Looks like a pretty good deal if you just pick up extra center caps! These will work! I just put a set of 18x8 BMW style 415 turbine wheels on my car with 225/45r18 tires. Same offset 34 and no issues clearing m sport brakes.
2011 X5 xDrive 50i - retired
2016 340i xDrive - retired 2020 M4 Coupe |
12-16-2016, 09:27 PM | #156 | |
Rep 8
What do have on the car in the nice months? |
12-17-2016, 06:22 AM | #157 |
Rep 255
Actually just picked it up so haven't had a chance to play with the with summer tires yet! However whatever the stock tires are for m sport and track handling, Michelin pilot super sport i believe. With the 442M orbit grey wheels which are 19x8 front 19x8.5 rear.
12-20-2016, 01:54 AM | #158 |
Rep 1,499
Hey guys I'm in the hunt for new rubber on my 2014 335i with 403 M Sport wheels 19x8" ET36 225/40/R19 front / 19x8.5" ET47 255/35/R19 rear. I read this whole thread and didn't see an answer to my question so please forgive me if this is a repeat, but what's the widest rubber I can fit on my wheels without spacers or rolling the fenders? Would love to go 245 up front and 275 in the rear.
12-20-2016, 02:15 AM | #159 | |
Rep 5,140
245/40-19 front and 255/40-19 rear or 245/35-19 front and 255/35-19 rear. F: 8x19" ET36 R: 8.5x19" ET47 |
rswitch40.00 |
12-20-2016, 02:23 AM | #160 |
Rep 1,499
SWEET!! Thanks for the quick reply!!
01-07-2017, 02:32 PM | #161 |
Rep 18
Im currently looking at this setup:
8.5x19 et 37 9.5x19 et 33 How will this fit on a F30 with stock baseline suspensions? Kinda worried about the rear as they differ too much from stock et 47. And what kind of tyres do you guys recommend? 235/35 and 265/30? |
01-09-2017, 11:58 AM | #162 |
Rep 28
Need help on OEM rim widths 18" Double Spoke Style 400M, currently have 225/45-18 front and rear and would like to have the setup below with MPSS
225/45-18 front / 255/40-18 rear, just trying to confirm if all rear rims are 8.5 wide 2016 340i Msport |
01-09-2017, 03:36 PM | #163 | |
Rep 5,140
You can fit a square setup of either 245/40-18 or 245/45-18 MPSS on your square style 400 wheels. |
02-19-2017, 07:46 PM | #164 |
Rep 21
Guys, I need some help. I have the exact same set up as 2016340iMSport, 225/45-18 square on 400M wheels.
Can I fit the following old set on my f30? Rear - 265/30-19 on 9.5x19" ET33 Front - 245/35-19 on 8.5x19" ET30 Dealer said rear is not the right fit for my car. Any suggestions? Thanks |
02-20-2017, 12:05 PM | #165 |
Rep 285
Will F Series 385 Style OEM Wheels fit my E91 Touring/Wagon?
Hi guys, I have a 2012 E91 which has the following oem alloys fitted:
Style 339 - 17 x 8 ET 34 with tires 225 45 17 (square setup) I am considering a purchase of the following wheels and tires from the F series: Style 385 - Fronts 18 x 7.5 ET45 with tires 225 40 18 Rears 18 x 8 ET 52 with tires 245 35 18 I would appreciate your advice and thoughts. |
02-27-2017, 07:21 PM | #166 | |
Rep 357
Your replies gave me the confidence I needed to order ZE40 Volk for my car, aiming for your option: F: 8.5x19", 235/40-19 (2% taller than OEM) ETA 35 R: 9.5x19", 275/35-19 (2% taller than OEM) ETA 45 Question, the rear, will it clear inside an M Performance with Adaptive M? It is not lowered but I am thinking about it. Eigher case I can also go for a 265 /35 in the rear. regards |
02-27-2017, 11:24 PM | #167 | |
Rep 5,140
With ET35-40 a rear 275/35 tire might rub though. |
rswitch40.00 |
03-02-2017, 06:28 PM | #168 |
Rep 168
I just wanted to see if 245/40/18 front and 255/40/18 rear is a good staggered size?
for apex arc8 that is 18x8.5 front and 18x9 rear. Thank you!
rswitch ..
03-03-2017, 02:33 AM | #169 |
Rep 5,140
03-04-2017, 11:59 PM | #170 |
Rep 128
Hi everyone. I have a 2017 440ix GC with M Sport package. I'm new to the rim world and looking for an easy bmw install of 20" rims with tires.
Anyone use the "BMW M PERFORMANCE LIQUID BLACK 20" STYLE 624M"set? (bmw part is 36112287896). Quote from bmwusa.com: This stunning 20” alloy wheel set in polished silver finish includes the M logo on each wheel, high speed mounted and balanced high performance summer tires (Pirelli P Zero Run-Flat), center caps, valves and sensors. The assembly comes preassembled for easy installation. This set is the largest technically possible wheel and tire combination approved by BMW for the 3 and 4 Series (F3x) models. Additionally, the style 624M wheel is not available from the factory. 4 Rims: Front axle: 8Jx20 Offset:36 H2 Rear axle: 8.5Jx20 Offset:47 H2 4 Tires: Front axle: 225/35R20 90Y XL * RSC Rear axle: 255/30R20 92Y XL * RSC https://www.shopbmwusa.com/PRODUCT/4...nterId=2327601 Expensive. Damn. |
03-05-2017, 01:07 AM | #171 | |
Rep 5,140
But I would actually recommend a square setup with four front wheels and 245 tires! 8x20" ET36, 245/35-20 There are two main reasons for a square setup. I always recommend square setups for performance and the possibility to rotate tires. With xDrive it's also easier with square tires since you don't have to care about diameter diffrence front to rear. With square tires on OEM 20" wheels you can also chose 245/35 tires which give slightly taller sidewall, which in turns give improved comfort and better wheel protection! |
03-05-2017, 01:36 AM | #172 | |
Rep 128
03-05-2017, 05:56 AM | #173 | |
Rep 5,140
You will need to buy 4 front wheels as spare parts and source the tires from a local tire shop. Partnumber for style 624 8x20" front wheels. Matt black: 36 11 6 862 774 Polished finish: 36 11 6 864 392 |
03-05-2017, 10:25 AM | #174 |
Rep 128
That all makes sense.
Last question I have, as a beginner to the topic of enhancing rims/tires, what is a GOOD dealership charge to put these on my car out-the-door? I'm asking because that's what I'm being offered, I was told "an awesome installation fee". Long story but should happen. If I went with the 4 20" and 4" Pirellis from the part#36112287896 per bmwusa.com the write up even reads this: (Notice the pre-assembly). "This stunning 20” alloy wheel set in polished silver finish includes the M logo on each wheel, high speed mounted and balanced high performance summer tires (Pirelli P Zero Run-Flat), center caps, valves and sensors. The assembly comes preassembled for easy installation." |
03-13-2017, 09:14 AM | #175 |
Rep 352
I have 624m and want to know if this setup of 245/35/20F and 255/35/20R would work on a 435i Msport? would I have any issues?
thanks!
2016 435i M-Sport | Carbon Black | 20" 624M Wheels | MPPK | MPE | M Performance Brakes | M Performance Steering Wheel II with Display | xHP | Dinan Stage 4 | Dinan Big Turbo | Dinan High Performance Intercooler | Dinan Intake | Dinan Shockware | Fabspeed Sport Cat Downpipe | Custom Quad Tips | Autotecknic Red Paddle Shifters
03-13-2017, 09:55 AM | #176 |
Rep 5,140
Yes, those tires will work with RWD!
The rear tires are 3.5% taller than OEM sizes though. |
BulsaraF36141.50 |
